Vista Tutorial - Intel E8400 Temp problem
Old 04-10-2009   #1 (permalink)
Windows 7 Ultimate x64
Hey there
My Intel E8400 is looking very hot now a days. The cooler is stock. See the pic, is this normal or I need a better cooler?
Old 04-10-2009   #2 (permalink)
Vista Ultimate x64
Re: Intel E8400 Temp problem
That simply cant be right. Download CPUID the post a screenshot.
Acording to Intel, 72.4c is the max on the e8400
Old 04-10-2009   #3 (permalink)
<3 Nvidia
Windows 7 x64
Check to you've attached the cooler properly first. When I fitted one like it, I didn't connect it properly and it resulted in very hot temps.
Just make sure each connector is pushed down well.
Though a 3rd party cooler will always result in better temperatures as well.
Old 04-10-2009   #4 (permalink)
here's cpuid
OMG 99degree
Old 04-10-2009   #5 (permalink)
<3 Nvidia
Windows 7 x64
Quote  Quote: Originally Posted by stew2 View Post
Intel said all E8xxx CPUs that the max TJ temp is 100c from what I've read.
And it looks like your sensors are a bit messed up, especially as it shows -27c for min.
Old 04-10-2009   #6 (permalink)
Vista Ultimate x64
The e8400 has the folliwing max temps:
Tcase Max 72.4c, Tjunction Max 105c
Your Tjunction reading is at 94c so id be worried if that was correct.
Old 04-10-2009   #7 (permalink)
Vista Ultimate x64
Yeah Everlong18 i updated it. Its been a long day lol.
Old 04-10-2009   #8 (permalink)
So what should I do now? What steps I need to follow?
Old 04-10-2009   #9 (permalink)
<3 Nvidia
Windows 7 x64
No worries
Old 04-10-2009   #10 (permalink)
Vista Ultimate x64
Basically your coolings not good enough. Your motherboard, hard drive and cpu temps are way to high. You should invest in more fans and make sure your cooling solution is optimized.
1. Have more fans taking air in than out
2. Intake fans at the front of case with outake at the back
3. Clean out the dust from your pc
4. Invest in a better case if its the case thats causing high temps
OCing e8400 with asus mobo Overclocking & Cooling
Max overclock with E8400 Overclocking & Cooling
Windows Vista strange settings on temp folder AppData\Local\Temp\1 Vista security
Successful OC e8400 @ 4.00Ghz Overclocking & Cooling
Intel E8400 General Discussion
