No HDMI sound or speak/headphones sound
  1. #71
    Maxamillon's Avatar
    Windows vista home premium 32 bit
    Local Time: 06:29 AM
      Thread Starter
    Re: No HDMI sound or speak/headphones sound
    I just have the normal light green plug-in and my hdmi to connect my graphics cards.
  2. #72
    Maxamillon's Avatar
      Thread Starter
    I think the main problem is the ATI because when ever i try to install the updates the display and audio get a "INF. cannot be found" error.
  3. #73
    Senior Member
    vista home premium
    Local Time: 08:29 AM
    Are you saying that you have only one speaker connected?
    There are six audio ports. I would try plugging into the gray, black or yellow and see if it makes any difference.
    You do have the Realtek chipset. I think you should try switching the driver from the Radeon to the Realtek and then try doing the configure.
  4. #74
    Maxamillon's Avatar
      Thread Starter
    I dont really know how to switch radeon to realket.
  5. #75
    Yard Dog's Avatar
    Senior Member
    Central Florida in a small town
    Vista Home Basic. 32 bit SP 2
    usa us florida
    Can you do this : Repair Install For Vista and just get what ever is messed up repaired ?
  6. #76
    Maxamillon's Avatar
      Thread Starter
    I dont have any vista installation cd.
  7. #77
    Senior Member
    vista home premium
    You didnt tell me how many speakers you have.
    Did you try the other ports? If so, did the Realtek software ask you if you installed a speaker whenever you plugged into a port?
    Go to Control Panel, Device manager, Sound, etc. Is the Realtek High Definition Audio listed? If it it, right click on it and scan for hardware changes.
  8. #78
    Maxamillon's Avatar
      Thread Starter
    I only have the built in speakers. I hit the check for any changes on realtek and nothing happens.
  9. #79
    Senior Member
    vista home premium
    Try your headphones in the other ports I mentioned.
    Was Realtek listed under Sound in Device Manager?
  10. #80
    Maxamillon's Avatar
      Thread Starter
    I have.
Page 8 of 9 FirstFirst ... 6789 LastLast
No HDMI sound or speak/headphones sound problems?
How do i get 2 channel sound to have different sound thru headphones & speakers? biffyman Sound & Audio 2 16 May 2010
Internal Sound is working but no sound for headphones =?Utf-8?B?UGllcnJlRGE=?= Vista installation & setup 5 29 May 2008
Internal sound is woring but no way to use headphones (no sound) =?Utf-8?B?UGllcnJlRGE=?= Vista installation & setup 0 04 Sep 2006
Internal Sound is working but no sound for headphones =?Utf-8?B?UGllcnJlRGE=?= Vista installation & setup 0 04 Sep 2006
