copeyhagen
hey all, i was a member here back in 2009 and my problem was solved by yourselves then i think, having a problem on my desktop at the moment.
I will attach the dump file tomorrow after work.
last thursday i noticed one of the fake virus alert hijackers popped up on my pc. as usual i just alt+ctrl+del to close it without touching it, then booted into safe mode and ran malware bytes, spybot s&d and avg free. looked like the problem was sorted. headed away for the weekend, came home sunday and got a bsod after a while. restarted and looked ok. then monday same thing happened again. Again i restarted and seemed ok. not sure if the bsod is related to the attempted malware?
yesterday turned on my pc and i get a bsod within about 2 minutes. I tried restoring to two weeks ago, looked ok, loaded up a game then bang, same bsod so i just left it last night.
its a desktop running vista home premium, 4 gig ram, ati hd4870 graphics card, vista should be fairly up to date.
tried removing each ram module and still kept happening, i doubt both ram modules are strawberryed? had updated my ati drivers through steam about 2 weeks ago.
the stop errors i have seen are:
0x3b
0x1e
0x0a
I also tried taking the graphics card out, cleaned all the fans, case, cpu, gfx, and put the card back in. booted it up and was running ok for 2 or 3 mins but i left it and went training. when i came back in 2 hours later there was a bsod.
I then tried using a vista repair disc i created, I ran the mem check and that found nothing (i think, both passes went to 100%), though it said "results will be posted upon startup", but of course, upon startup it bsod'd!
I tried "repairing the startup" from the repair disc but it found no problems.
the pc will boot into safe mode and not get a bsod at all? does that mean its not hardware related?
a friend in work mentioned it could be virus related and that av might have missed it, to remove avg and install the microsoft one and see if that finds anything?
i get the Driver_Irql_not_less_or_equal error too.
All ideas are much appreciated!
thanks in advance.
Rob
0x3b
0x1e
0x0a
thanks in advance.
Rob
