I accidently turned my Dell laptop off while it was performing windows updates. When I restarted the laptop it goes to the login screen and then goes blank (i cant enter the username/password).
I have tried the following:
1. Starting in safe mode (same issue)
2. Using the boot dvd and trying the different options in there (Repair, Restore to safe point, Memory check).
3. Using the boot dvd I have tried several different restore points, including the original store point.
4. I have looked through every forum and every post I can find and cannot find any suggested resolutions.
Does anyone have any suggestions on what I can try next (other than reinstalling the OS)
My laptop is a Dell Latitude E6500 running Windows Vista (32 bit i think)
