Peterin089
I have problem with BSOD. My computer offten restart and I losse my data. :sa:
I read in BSOD that I have problem with APC info Mismatch.
Here is output from Winddbg:
Code:
Microsoft (R) Windows Debugger Version 6.11.0001.404 X86
Loading Dump File [C:\Windows\Minidump\Mini032911-01.dmp]
Symbol search path is: *** Invalid ***
* Symbol loading may be unreliable without a symbol search path. *
* Use .symfix to have the debugger choose a symbol path.
* After setting your symbol path, use .reload to refresh symbol locations.
Executable search path is:
* Symbols can not be loaded because symbol path is not initialized. *
* The Symbol Path can be set by: *
* using the _NT_SYMBOL_PATH environment variable. *
* using the -y <symbol_path> argument when starting the debugger.
* using .sympath and .sympath+ *
Unable to load image \SystemRoot\system32\ntkrnlpa.exe, Win32 error 0n2
*** WARNING: Unable to verify timestamp for ntkrnlpa.exe
*** ERROR: Module load completed but symbols could not be loaded for
ntkrnlpa.exe
Windows Server 2008/Windows Vista Kernel Version 6002 (Service Pack 2) MP (2
procs) Free x86 compatible
Machine Name:
Kernel base = 0x83a01000 PsLoadedModuleList = 0x83b18c70
Debug session time: Tue Mar 29 22:20:59.171 2011 (GMT+2)
System Uptime: 1 days 23:19:30.475
ntkrnlpa.exe
Loading Kernel Symbols
Loading User Symbols
Loading unloaded module list
Unable to load image \SystemRoot\System32\Drivers\Ntfs.sys, Win32 error
0n2
*** WARNING: Unable to verify timestamp for Ntfs.sys
Ntfs.sys
* Bugcheck Analysis
BugCheck 24, {1904aa, d8b698bc, d8b695b8, 83abe3d7}
*** WARNING: Unable to verify timestamp for fltmgr.sys
fltmgr.sys
*** WARNING: Unable to verify timestamp for AsDsm.sys
AsDsm.sys
*** WARNING: Unable to verify timestamp for eamon.sys
eamon.sys
***** Kernel symbols are WRONG. Please fix symbols to do analysis.
*** Your debugger is not using the correct symbols ***
*** In order for this command to work properly, your symbol path ***
*** must point to .pdb files that have full type information. ***
*** Certain .pdb files (such as the public OS symbols) do not ***
*** contain the required information. Contact the group that ***
*** provided you with these symbols if you need this command to ***
*** work. ***
*** Type referenced: nt!_KPRCB ***
*** work. ***
*** Type referenced: nt!KPRCB ***
*** work. ***
*** work. ***
*** work. ***
*** work. ***
*** work. ***
*** work. ***
Probably caused by : Ntfs.sys ( Ntfs+1122f )
Followup: MachineOwner
- F3SG
- Asus F3000Sg Series Notebook
- 3GB
- Graphics Card(s)
- GeForce 9300 M
- Realtek digital output
- 15.4 'WXGA+
