Context Menu - Add Encrypt and Decrypt
How to Add Encrypt and Decrypt to the Context Menu in Vista
This will add Encrypt and Decrypt to the context menu (right click). It will allow you to encrypt or decrypt a file or folder by simply right clicking the item and selecting Encrypt or Decrypt. You will no longer have to go through the Advanced Properties of the file or folder to do it. The Encrypt feature is only available in the Vista Business, Ultimate, and Enterprise versions.
If the file or folder is not already encrypted, you will see Encrypt when you right click on the file or folder. If the file or folder is already encrypted, then you will see Decrypt when you right click on the file or folder.
If you add encrypted files to a compressed (zipped) folder, the files will be unencrypted (decrypted) when extracted, which might result in unintentional disclosure of personal or sensitive information. For that reason, you should avoid compressing encrypted files. If you create a shortcut from the encrypted file, it will not be encrypted until you do it.
EXAMPLE: Context Menu after Adding Encrypt and Decrypt
NOTE:
Only one will appear in the context menu at a time depending on if the file or folder is encrypted or not.
OPTION ONE
Using a REG File Download
1. To Add Encrypt and Decrypt
Add_Encrypt-Decrypt.reg
download
B) Go to step 3.​
2. To Remove Encrypt and Decrypt
Remove_Encrypt-Decrypt.reg
download
6. You can now delete the .reg file (on Desktop) if you want to.​
OPTION TWO
Manually in Registry Editor
1. Open the Start Menu.​
3. Click on Continue button in the UAC prompt.​
4. In regedit, go to: (See screenshot below step 5)​
HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Explorer\Advanced
5. In the right pane, right click on a empty space and click on New and DWORD (32-bit) Value.​
6. Type EncryptionContextMenu and press Enter. (See screenshot below)​
7. Right click EncryptionContextMenu and click on Modify.​
8. To Add Encrypt and Decrypt
A) Type 1 and click on OK. (See screenshot below)​
B) Go to step 10.​
9. To Remove Encrypt and Decrypt
A) Type 0 (number zero) and click on OK.​
10. Close regedit.​
  • Add_Encrypt-Decrypt.reg
  • Remove_Encrypt-Decrypt.reg
