Control Panel - Add Registry Editor
How to Add or Remove "Registry Editor" to the Control Panel in Windows
This will show you how to add Registry Editor (regedit) to the Control Panel Vista, Windows 7, and Windows 8.
EXAMPLE: Registry Editor Added to the Classic View Control Panel
EXAMPLE: Registry Editor Added to the Control Panel Home
NOTE:
You will need to click on the System and Maintenance link first.
1. To "Add Registry Editor" to Control Panel
A) Click/tap on the download button below to download the file below.​
Add_Regedit_ControlPanel.reg
download
B) Go to step 3.​
2. To Remove "Registry Editor" from Control Panel
NOTE: This is the default setting.​
Remove_Regedit_ControlPanel.reg
download
3. Save the .reg file to the Desktop.​
4. Double click/tap on the downloaded .reg file to Merge it.​
5. Click/tap on Run, Yes, Yes (UAC-Windowws 7/8) or Continue (UAC-Vista), and OK when prompted.​
6. When finished, you can delete the .reg file if you like.​
  • Add_Regedit_ControlPanel.reg
  • Remove_Regedit_ControlPanel.reg
