Control Panel - Enable or Disable
How to Enable or Disable the Control Panel in Vista and Windows 7
This will show you how to Enable or Disable the Control Panel in all user accounts on the computer.
This will add or remove the Control Panel shortcut icon from the Start menu and Windows Explorer. If a user tries to open the Control Panel while disabled, they will get a Restrictions message. (See example below)
If you did not disable the Control Panel, then it may have been done by some kind of malware or spyware. You should do a complete scan of your computer for a virus and other malware to be safe.
EXAMPLE: Control Panel Disabled Restrictions Message
OPTION ONE
Using a REG File Download
1. To Enable Access to the Control Panel
Enable_Control_Panel.reg
download
B) Go to step 3.​
2. To Disable Access to the Control Panel
Disable_Control_Panel.reg
download
5. Click on Run, Continue (UAC-Vista) or Yes (UAC-Windows 7), Yes, and then OK when prompted.​
6. Log off and log on, or restart the computer to apply the changes.​
7. When done, you can delete the downloaded .reg file if you like.​
OPTION TWO
2. In the left pane, click on User Configuration, Administrative Templates, and Control Panel. (See screenshot below)​
3. In the right pane, right click on Prohibit access to the Control Panel and click on Properties. (See screenshot above)​
4. To Enable the Control Panel
A) Dot Disabled or Not Configured. (See screenshot below step 6)​
B) Go to step 6.​
5. To Disable the Control Panel Icon
A) Dot Enabled.​
6. Click on OK.​
7. Close the Local Group Policy Editor window when done.​
OPTION THREE
Manually in Registry Editor
1. Open the Start Menu, then type regedit in the search box and press Enter.​
2. If prompted by UAC, then click on Continue (Vista) or Yes (Windows 7).​
3. In regedit, navigate to the location below. (See screenshot below step 4C)​
NOTE: If you do not have Explorer, then right click on Polices and click on New and Key. Type Explorer and press Enter.​
4. To Disable Access to the Control Panel
A) In the right pane, right click on a empty area and click on New and DWORD (32-bit) Value.​
B) Type NoControlPanel and press Enter.​
C) Right click on NoControlPanel and click on Modify.​
E) Go to step 6.​
5. To Enable Access to the Control Panel
A) In the right pane, right click on NoControlPanel and click on Delete. (See screenshot below step 4C)​
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Policies\Explorer
D) In the right pane, repeat steps 6A and 6B if NoControlPanel is there to.​
6. Close regedit.​
7. Log off and log on, or restart the computer to apply the changes.​
  • Enable_Control_Panel.reg
  • Disable_Control_Panel.reg
