Flip 3D - Add to Context Menu
How to Add Flip 3D to the Desktop Context Menu in Vista and Windows 7
This will show you how to add Flip 3D, also known as Switch between windows or Window Switcher, to the Desktop right click context menu in Vista.
With this, you can now right click on the desktop, or in Windows Explorer window, and click on Windows Switcher to open and use Flip 3D.
Keyboard Shortcut Keys for Flip 3D
NOTE:
Press the key combinations below in blue to activate.
  • Windows Key + Tab = Press and hold Windows Key, then press Tab (or roll mouse scroll wheel) to scroll through the open windows. Choose the open window you want by releasing the Windows Key when the window is at the front.
  • Ctrl + Windows Key + Tab = Scroll through the open windows by pressing the Tab key, arrow keys, or roll the mouse scroll wheel. Click on the window you want to see, or press Enter when it is up front.
HARDWARE REQUIREMENTS FOR: WINDOWS AERO
See: Windows Help and Support: Troubleshoot problems with Windows Aero
NOTE: The Windows Aero color scheme is not available for the Vista Home Basic or Windows 7 Home Starter editions. :(
  • 1 GHz 32-bit or 64-bit processor
  • 1 GB of system memory
  • A graphics card with support for DirectX 9 graphics with at least 128 MB of memory.
  • The graphics card must support Pixel Shader 2.0 and the Windows Display Driver Model (WDDM).
  • You must be have True Color (32 bit) set instead of High Color (16 bit).
  • The Desktop Window Manager Session Manager and Themes Services need to be set as Started and Automatic.
  • Refresh or update your WEI score.
  • The Windows Aero color scheme selected and turned on.
  • The Enable desktop composition and Animate controls and elements inside windows options enabled in Visual Effects.
  • Using a Aero theme.
EXAMPLE: Flip 3D
EXAMPLE: Context Menu Before and After Flip 3D is Added
NOTE:
It will have the name Windows Switcher in the context menu for Flip 3D. This is for when you right click on the desktop or in Windows Explorer.
METHOD ONE
Using a REG File Download
1. To Add Flip 3D to the Context Menu
Add_Window_Switcher.reg
download
B) Go to step 3.​
2. To Remove Flip 3D from the Context Menu
NOTE: This is the default setting.​
Remove_Window_Switcher.reg
download
5. Click on Run, Continue (UAC-Vista) or Yes (UAC-Windows 7), Yes, and then OK when prompted.​
6. When done, you can delete the .reg file (on Desktop).​
METHOD TWO
Manually in Registry Editor
1. Open the Start Menu, then type regedit in the search boxand press Enter.​
2. If prompted by UCA, then click on Continue (Vista) or Yes (Windows 7).​
3. In regedit, navigate to the location below. (see screenshot below step 4A)​
HKEY_CLASSES_ROOT\Directory\Background\shellx\ContextMenuHandlers
4. To Add Flip 3D to the Context Menu
A) In the left pane, right click on ContextMenuHandlers and click on New, then on Key. (see screenshot below)​
B) Type Windows Switcher and press Enter. (see screenshot below step 4C)​
C) In the right pane, right click on (Default) and click on Modify. (see screenshot below)​
D) Type {3080F90E-D7AD-11D9-BD98-0000947B0257} and click on OK. (see screenshot below)​
E) The registry will now look like this. (see screenshot below)​
F) Go to step 6.​
5. To Remove Flip 3D from the Context Menu
A) In the left pane, right click on Windows Switcher and click on Delete. (see screenshot above)​
B) Click on Yes to confirm the deletion.​
6. Close regedit.​
  • Add_Window_Switcher.reg
  • Remove_Window_Switcher.reg
Your welcome teamster776, and welcome to Vista x64 Forums. :party:
    1TB Samsung 990 PRO M.2,
    4TB Samsung 990 PRO PRO M.2,
    Galaxy S23 Plus phone
Your welcome cicciox64, and welcome to Vista x64 Forums. :party:
Shawn,
That is a GREAT addition. The 3-D Flip is a great feature that I was disappointed Microsoft didn't give a quicker way to access. I wish the Microsoft team would concentrate on adding features like this INSTEAD of removing or relocating (burying) good feature like the Find context menu in Explorer. Your hack improves productivity while the later only causes confusion, frustration and a waste of time. [End of rant]
Thanks for tip. Is there a way we could also add this to the right click menu on IE?
Bob,
I'm not sure, but I will look into it for you.
UPDATE:
Sorry Bob,
I cannot find a way to add it to the IE7 context menu. :(
I would think that it would be just as easy to use from Quick Launch or the context menu from the Desktop though.
Your welcome Charlie, and welcome to Vista Forums. :party:
Hi Shawn
I noticed a little mistake in the Tute post there buddy.
I always do the Manual mode when making reg edits and I was following your instructions as shown here:
4.[/b] In regedit, go to: (See screenshot below step 5A)
HKEY_CLASSES_ROOT\Directory\shellx\ContextMenuHandlers
I couldn't get the command to show in the context menu and I checked and double checked, I even went to the CLSID to make sure it was the correct one for Windows Switch, it was.
Then I noticed where the mistake is...you forgot to have the subkey "Background" in the Manual instructs...oops.
So that manual method should read "HKEY_CLASSES_ROOT\Directory\Background\shellx\ContextMenuHandlers"
Later bud!
    Personal Build
    Intel E6750 Core 2 Duo
    Asus Commando MoBo (P965/ICH8R)
    4G's Crucial Ballistix Tracer DDR2 PC26400 RAM
    BFG 8800GTS OC2 320MB
    Creative Sound Blaster X-FI Platinum FATAL1TY (next)
    2 x 22" w2207 LCD Monitors
    1- 1680 x 1050, 1 - 1920 x 1080
    3 x 500G SATA II WD Caviar HDD's
    EnerMax NoiseTaker II 600W
    NZXT Lexa Classic (modified, dual doored & windowed)
    Zalman 9700 CPU cooler, 4-120mm fans, 1-90mm
    Logitech Optical Trackman trackball
    NZXT Lexa Classic Case, Zalman 9700 CPU Cooler, 2 DVD Burners c/w LightScribe (Sony, TSST), Enermax NoiseTaker II 600W PSU with Custom Chrome cable sleeving, Hauppauge HDTV TV Tuner Card, 5.1 Logitech Z5500 speakers, 15 in 1 Multi-card reader
Oops. :o
Thank you Chappy for bringing this to my attention. The tutorial has been updated to fix the ommision. :geek:
Your welcome Vista2007.
Hi vista2007
The Flip 3d option is only available under the Aero theme I believe, and won't work in Basic or Classic mode.
@Brink
NP my friend!
I'm simply relieved to know that you're Human too...I had heard that you were some kinda "Alien" type and that scared me a bit...
    Personal Build
Hi Dave,
It's included in the Warning box to have the Windows Aero color scheme selected. ;)
Don't worry, we aliens are non-hostile and very friendly. :geek:
Thank you,
Your welcome Parkhurst, and welcome to Vista Forums.
