NTFS Compression - Disable or Enable
How to Disable or Enable NTFS Compression in Vista and Windows 7
NTFS Compression allows you to save some hard drive space by compressing files and folders to reduce their size.
This will show you how to enable or disable the NTFS Compression option to compress or decompresss a file or folder for all user accounts in Vista and Windows 7.
If you disable compression, no user account will be able to compress a folder or file until it is enabled again.
This is not the same as the built-in Zipped Compression used for creating ZIP files in Vista and Windows 7.
EXAMPLE: NTFS Compression Disabled
OPTION ONE
Using a REG File Download
1. To Disable NTFS Compression
Disable_NTFS_Compression.reg
download
B) Go to step 3.​
2. To Enable NTFS Compression
NOTE: This is the default setting.​
Enable_NTFS_Compression.reg
download
5. Click on Run, Continue (UAC-Vista) or Yes (UAC-Windows 7), Yes, and OK when prompted.​
7. Restart the computer to apply the changes.​
7. You can now delete the downloaded .reg file if you like.​
OPTION TWO
Manually in Registry Editor
1. Open the Start Menu, then type regedit in the search box and press Enter.​
2. If prompted by UAC, then click on Continue (Vista) or Yes (Windows 7).​
3. In regedit, navigate to the location below. (see screenshot below step 4)​
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\FileSystem
4. In the right pane, right click on NtfsDisableCompression and click on Modify.​
5. To Disable NTFS Compression
A) Type 1 and click on OK. (see screenshot below step 6)​
B) Go to step 8.​
6. To Enable NTFS Compression
A) Type 0 (number zero) and click on OK.​
7. Close regedit.​
8. Restart the computer to apply the changes.​
  • Disable_NTFS_Compression.reg
  • Enable_NTFS_Compression.reg
