User Account Control (UAC) - Elevate Privilege Level
How to Elevate All Administrator Accounts UAC Privilege Level
This will show you how to change all administrator account's UAC Privilege Level to keep UAC on and not prompt an admnistrator, have UAC ask administrator for password, or the default of asking an Administrator to Continue for permission. UAC will still be on and work as usual for the Standard and Guests account types. For more information, see:
This will still leave Protected Mode: ON in Internet Explorer to.
To Have UAC Progam Exceptions to not have UAC ask for your permission on certain programs in Vista only, then you can use the Norton UAC Tool for this. This program will not work in Window 7.
This can only be done while logged on to an administrator account.
OPTION ONE
Using a REG File Download
1. To Elevate Administrators Privilege Level for no Prompting by UAC
NOTE: When you elevate the administrator accounts privilege level, the Security Center in Vista will give you an alert warning notification in the notification area of the taskbar until you undo this. To turn this alert off, see: How to Disable or Enable the Security Center Alert Warning Notification in Vista.​
Elevate_Administrator_Priviledge.reg
download
B) Go to step 4.​
2. To Have UAC Prompt Administrators for a Password
NOTE: This will act just like it does in a Standard account by UAC asking you for the administrator's password before continuing.​
Administrator_UAC_Require_Password.reg
download
B) Go to step 4.​
3. To Have UAC Prompt Administrators for a Continue or Yes
NOTE: This is the default setting for UAC asking the administrator to click on Continue (Vista) or Yes (Windows 7) to give permission.​
Restore_Default_Settings.reg
download
4. Click on Save, and save the .reg file to the Desktop.​
5. Right click on the downloaded .reg file and click on Merge.​
6. Click on Run, Continue (UAC-Vista) or Yes (UAC-Windows 7), Yes, and then OK when prompted.​
7. Log off and log on, or restart the computer to apply the changes.​
8. When done, you can delete the downloaded .reg file if you like.​
OPTION TWO
Through Local Security Policy
NOTE: This method is only available for the Vista Business, Ultimate, and Enterprise editions.
1. Open the Local Security Policy editor.​
2. In the left pane, click on Local Policies. (See screenshot below step 5)​
3. Click on Security Options.​
4. In the right pane, double click on User Account Control: Behavior of the elevation prompt for administrators in Admin Approval Mode.​
5. To Elevate Administrators Privilege Level for no Prompting by UAC
A) Click on the drop down arrow and change the setting to Elevate without prompting. (See screenshot below step 8)​
B) Go to step 8.​
6. To Have UAC Prompt Administrators for a Password
A) Click on the drop down arrow and change the setting to Prompt for credentials. (See screenshot below step 8)​
B) Go to step 8.​
7. To Have UAC Prompt Administrators for a Continue or Yes
A) Click on the drop down arrow and change the setting to Prompt for consent. (See screenshot below step 8)​
8. Click on OK to apply.​
9. Close the Local Security Policy window. Your Done.​
OPTION THREE
Manually Using Registry Editor
1. Open the Start Menu.​
3. If prompted by UAC, then click on the Continue (Vista) or Yes (Windows 7).​
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Policies\System
5. In the right pane, right click on ConsentPromptBehaviorAdmin and click on Modify.​
6. To Elevate Administrators Privilege Level for no Prompting by UAC
A) Type 0 (Number) and click on OK. (See screenshot below step 8)​
B) Go to step 9.​
7. To Have UAC Prompt Administrators for a Password
A) Type 1 and click on OK. (See screenshot below step 8)​
B) Go to step 9.​
8. To Have UAC Prompt Administrators for a Continue or Yes
A) Type 2 and click on OK.​
9. Close regedit.​
10. Log off and log on, or restart the computer to apply the changes.​
  • Elevate_Administrator_Privilege.reg
  • Restore_Default_Settings.reg
  • Administrator_UAC_Require_Password.reg
I use Vista Home Premium and successfully followed method 2 above. That method seems to turn off the UAC. But what I'd like to do is avoid the prompt for certain programs such as yahoo messenger and adobe suites and leave the UAC on for everything else. Is this possible?
Hi pRose DC,
It would be nice to have exceptions for programs in UAC like in a firewall program., but that is not an option in Vista. It's all or none. :(
Sorry,
    1TB Samsung 990 PRO M.2,
    4TB Samsung 990 PRO PRO M.2,
    Galaxy S23 Plus phone
Hi
I am trying to install Symantec Antivirus software under Vista Home Premium and get the following error message:
This version of Symantec AntiVirus requires elevated privileges in order to install.
I have tried the download and manual options described in:
How to Elevate Administrators UAC Privilege Level in Vista
but still cannot install Symantec.
Any ideas?
Hi TrevB,
I hate to say this, but I would avoid installing any Symantec Norton antivirus program on Vista until they can fix the problem. There has been so many reported problems with Norton and Vista it isn't even funny anymore. I would recommend using something like the free Avast antivirus instead. It may have just saved you a headache later by not installing.
http://www.avast.com/eng/avast_4_home.html
Thanks for the advice. I have downloaded and installed Avast without incident.
Thanks again.
TrevB
Hi TrevB,
I hate to say this, but I would avoid installing any Symantec Norton antivirus program on Vista. There has been so many reported problems with Norton and Vista it isn't even funny anymore. I would recommend using something like the free Avast antivirus instead. It may have just saved you a headache later by not installing.
Your welcome TrevB.
Glad to hear it went well. Thank you for the feedback.
Your welcome Killerchronic and beauparc.
I'm glad that it has helped you.
Me too, I'm getting the nag notification after rebooting. Is this reg edit any different to turning off UAC, as I understand from another tutorial both UAC and the nag can be easily turned off? Or is it turning it off for the administrator but not for other users? :confused:
Turning UAC back on has changed that reg field back from 0 to 2.
Hi cpemma,
This tutorial does not turn off the UAC. It just elevates the default Administrator account so it will not get a UAC permissions prompt, but still leave most of UAC on for better security than just turning UAC off completely.
I use a standard account on Windows Vista Home Premium and I, unfortunately, have UAC.
I tried Method 2 but it doesn't seem to work.
A note that says "Error" pops up every time I try to merge the download(s) and even through the manuel way.
I need help, please.
Chris.
Hi Chris,
This will have to be done while logged on to a administrator account. It will not work from within a Standard account. It will also not elevate the Standard accounts, only the administrator accounts.
Sorry, :(
Your welcome Chris. Sorry about that.
I still have to choose the Run As Administrator option for various programs to get full use, eg Command Prompt, DVD Maker or I get errors that appear to be corrected by running the app as Administrator. I thought this elevate thing effectively makes the Run As Adminstrator the default - have I misunderstood or am I doing something wrong?
G
Hello MadKingSoup, and welcome to Vista Forums.
This only elevates the privilege level with UAC. It does not affect havng to use Run as administrator with some programs for them to work properly. :(
Sorry,
