0x00000101 error
weejokey
hi guys ,at least once a night i get this error after i reboot it dont seem to do it again.i read a similar problem with age of empires i think it was but i am running cod 5 when this happens is it my graphics drivers or is it more serious than that?
running Q9400 quad,260gtx and 4gb ram(added if it helps)drivers i am using is 7.15.11.7741 nvidia ,read it might be something to do with this but not to sure
    intel q9450 quad
    asus p5n-t
    corsair 4gb
    gtx 260 point of view
    Fatal1ty Professional Series
mansrm81
    HP Compaq Presario/SR5113WM
    AMD Athlon 64 X2 3600+ 1.9Ghz
    Asus M2N68-LA
    PNY Nvidia 8400 GS 256MB
    On board RealTek
    Acer X163W LCD
    1366x768
    7200 rpm
    Western Digital 160 GB IDE
    Dynex 400w
    Nothin Special
    Stock
    Wireless Logitech LX7
    Comcrap 10mb cable
dmex
ɠɛɐǨ
Hi WeeJokey,
Theres some more infomation about the 0x000000101 Error here: Bug Check 0x101: CLOCK_WATCHDOG_TIMEOUT
Basically it means one of your processor cores is malfunctioning (on its way out) :huh:
Steven
jcgriff2
Banned
I agree that a 0x101 bugcheck could mean the CPU is going or indicate other hardware issues. However, another possibility is a "deadlock". Multiple threads have areas of code locked - but it turns out that one is waiting on the other to finish and release their respective lock - which never happens... looping occurs, CPU can't respond in the time given so system BSODs.
It may be worth the trouble to produce a full kernel dump and issue windbg kd> !locks command to see if resource or object contention exists. It may be a bad driver caught in a loop.
Run the Vista Driver Verifier (DV) and see if it flags any drivers. At worst the DV will cause a BSOD and hopefully name the guilty party - or make it easier to find it in the stack text of the resulting mini kernel dump. Any driver updates or Windows Updates recently?
START | type cmd.exe | right-click on cmd.exe uptop under programs | Run as Administrator | type verifier & hit enter - the Verifier screen will appear | do the following:
Code:
[B]1. Select 2nd option - Create custom settings (for code developers)[/B]
[B]2. Select 2nd option - Select individual settings from a full list.[/B]
[B]3. Check the boxes[/B]
[B]  • Special Pool [/B]
[B]  • Pool Tracking [/B]
[B]  • Force IRQL checking[/B]
[B]4. Select last option - Select driver names from a list [/B]
[B]5. Click on the Provider heading - sorts list by Provider[/B]
[B]6. Check ALL boxes where Microsoft is not the Provider[/B]
[B]7. Click on Finish [/B]
[B]8. Re-boot[/B]
If the Driver Verifier (DV) finds a violation, it will result in a BSOD - usually a 0xc4 - but not always. It will verify your drivers 1-by-1, so it will take some time. To see the status of the Driver Verifier, bring up an elevated command prompt, type verifier - but this time select the last option on the first screen - "Display information about the currently verified drivers..". If you find your system to unstable (the verifier generally consumes CPU & RAM), turn it off" (verifier /reset) and re-boot.
Regards. . .
jcgriff2
    HP dv7-1020us
    Intel P7350 Core2 Duo @2GHz
    4096mb DDR2 SDRAM
    NVIDIA GeForce 9600M GT
    IDT
    Fujitsu 320gb SATA HDD 5400RPM
    Logitech USB
    Intel 5100
weejokey
thx guys had alook at them all and am in the middle of doing the driver verifier option atm ,if it doesn,t bsod in there what stats am i most interested in?
dont really want to go down the road of the paste stuff as i have just recieved this machine on thursday after i had a company build it so if it is the cpu then i would need to return it to them ,but any idea why it only happens once then is fine?
    intel q9450 quad
    asus p5n-t
    corsair 4gb
jcgriff2
Banned
Hi. . .
The Forum Moderator dmex may very well be right on the money with the CPU. I would defer on the hardware end as I always look at software 1st b/c that is my area of interest. I would not even attempt to do that which was suggested - I just don't know my way around hardware. There are no guarantees and plenty of opinions when it comes to BSODs.
I was in a similar position as you about 3 months ago when I bought a Vista x64 HP laptop. It froze w/in 24 hours. I returned it and the next 2 laptops as well - all within 1 month. They said a re-install of Vista would be good because the current one was "adjusting poorly to the new Intel P7350 CPU..." and that "..Vista needs a few re-installs ... to get it right.." !!! These were the same salesman (national US chain) that told me "64-bit is much better than 32-bit because it holds twice as much". I later saw that in an on-line ad for the same company. Unreal.
Given your system is < 1 week old, I fear they will claim BSODs your fault due to software installations (non-Vista). If you call or return it, I think they will just re-install Vista and send it back. They must have tested it - at least I hope they did.
If you want to run a dozen or so reports and files, I will be glad to take a look at them along with all dump files - current or future. Your call. Here are some of the items I usually gather from BSOD OPs:
Please note: In case you are unfamiliar - to get to an elevated Administrative level - command/"DOS" prompt -
START | type cmd.exe into the start search box | RIGHT-click on cmd.exe above under programs | select "Run as Administrator" - to copy/paste into the DOS screen, RIGHT-click at the very top of the black DOS screen, select Edit, select Paste - you may have to hit enter after the paste
1. Create a new folder in your Documents folder - call it Vistax64_Support - if OK w/ you.
2. Download Live SysInternals AutoRuns from Microsoft TechNet - SAVE it to the Vistax64_Support folder - http://live.sysinternals.com/autoruns.exe
-- Go to your documents folder, RIGHT-click on autoruns.exe and select run as admin. allow it to scan (status bottom-left). Save it as an ARN file (default file extension)
3. msinfo32 saved as an NFO file - START | type msinfo32 - hit enter. Save - NFO file default format
4. Vista health report - START | type perfmon /report & hit enter - 60 seconds, report will be displayed in IE7 or FFox web browser. Save as an HTML or HTM file.
5. dxdiag64 text file - START | type dxdiag - enter. DirectX Kernel viewer will appear - click on "run as x64" - bottom of screen - save as a text file
6. Bring up the elevated cmd/DOS screen - paste the following into it - 1 command at a time (11 total + copy mini dumps):
Code:
[B]whoami /ALL > "%userprofile%\documents\Vistax64_Support\whoami.txt"[/B]
[B]driverquery /v > "%userprofile%\documents\Vistax64_Support\drivers1.txt"[/B]
[B]driverquery /si > "%userprofile%\documents\Vistax64_Support\drivers2.txt"[/B]
Code:
[B]wevtutil qe Application /c:70000 /rd:true /f:text > "%userprofile%\documents\Vistax64_Support\evtx_app.txt"[/B]
Code:
[B]wevtutil qe System /c:70000 /rd:true /f:text > "%userprofile%\documents\Vistax64_Support\evtx_app.txt"[/B]
Code:
[B]ipconfig /all > "%userprofile%\documents\Vistax64_Support\ipconfigall.txt"[/B]
[B]systeminfo /fo list > "%userprofile%\documents\Vistax64_Support\systeminfo.txt"[/B]
[B]set > "%userprofile%\documents\Vistax64_Support\environvar.txt"[/B]
Code:
[B]Reg Query HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall /s > "%userprofile%\documents\Vistax64_Support\uninstall_HKLM.txt"[/B]
Code:
[B]Reg Query HKCU\Software\Microsoft\Windows\CurrentVersion\Uninstall /s > "%userprofile%\documents\Vistax64_Support\uninstall_HKCU.txt"[/B]
Code:
[B]Reg Query "HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Active Setup\Installed Components" /s > "%userprofile%\documents\Vistax64_Support\uninstall_HKLM2.txt"[/B]
Code:
[B]copy %windir%\minidump\*.* "%userprofile%\documents\Vistax64_Support"[/B]
Please go to your documents folder and zip up the entire Vistax64_Support folder and attach to your next post. If you have questions or a command doesn't work - please let me know.
Regards. . .
jcgriff2
    HP dv7-1020us
    4096mb DDR2 SDRAM
    IDT
    Logitech USB
    Intel 5100
weejokey
h guys i have done a hot cpu test over night and it shows an error at 23:40
000000| 0000 00000d4c Nov, 17 - 23:33:59 | Startig Hot CPU Tester Pro 4.4.1
000001| 1012 00000d4c Nov, 17 - 23:33:59 | Initializing DefectTrack Engine version 2.2.0
000002| 1010 00000d4c Nov, 17 - 23:33:59 | Loading options...
000003| 1011 00000d4c Nov, 17 - 23:33:59 | Reading system info...
000004| 0000 00000d4c Nov, 17 - 23:34:02 | CPU: Intel(R) Core(TM)2 Quad CPU Q9400 @ 2.66GHz
000005| 0000 00000d4c Nov, 17 - 23:34:02 | Speed: 2666MHz
000006| 0005 00000d4c Nov, 17 - 23:34:02 | -1
000007| 0005 00000d4c Nov, 17 - 23:34:02 | 32
000008| 0005 00000d4c Nov, 17 - 23:34:02 | 32
000009| 0000 00000d4c Nov, 17 - 23:34:02 | L1 Cache Size: 64KB
000010| 0000 00000d4c Nov, 17 - 23:34:02 | L2 Cache Size: 3072KB
000011| 0000 00000d4c Nov, 17 - 23:34:02 | L3 Cache Size: -1KB
000012| 0000 00000d4c Nov, 17 - 23:34:02 | Hyper-Threading: FALSE
000013| 0000 00000d4c Nov, 17 - 23:34:02 | SMP: TRUE
000014| 0000 00000d4c Nov, 17 - 23:34:02 | Scanning SMBIOS...
000015| 0000 00000d4c Nov, 17 - 23:34:02 | Could not read SMBIOS data
000016| 0000 00000d4c Nov, 17 - 23:34:02 | Total Physical Memory: -1076224000 bytes
000017| 0000 00000d4c Nov, 17 - 23:34:02 | Availabe Physical Memory: -1867960320 bytes
000018| 0000 00000d4c Nov, 17 - 23:34:02 | Total Virtual Memory: 2147352576 bytes
000019| 0000 00000d4c Nov, 17 - 23:34:02 | Availabe Virtual Memory: 2072166400 bytes
000020| 0000 00000d4c Nov, 17 - 23:34:02 | Operating System: Windows Vista Home Premium Service Pack 1
000021| 0156 00000d4c Nov, 17 - 23:34:02 | Setting Process Priority...
000022| 1111 00000d4c Nov, 17 - 23:34:16 | Diagnostic has started
000023| 1112 00000d4c Nov, 17 - 23:34:16 | Test Duration: 06:00:00
000024| 1113 00000d4c Nov, 17 - 23:34:16 | Diagnostic Method: Sequential
000025| 1114 00000d4c Nov, 17 - 23:34:16 | Error Handling: Ignore and Continue
000026| 1115 00000d4c Nov, 17 - 23:34:16 | Hyper-Threading: Disabled
000027| 0010 00000d4c Nov, 17 - 23:34:16 | -Complex Matrix : Enabled
000028| 0011 00000d4c Nov, 17 - 23:34:16 | --Thread Priority: THREAD_PRIORITY_NORMAL
000029| 0011 00000d4c Nov, 17 - 23:34:16 | --Matrix Size: 3,000x3,000
000030| 0011 00000d4c Nov, 17 - 23:34:16 | --Matrix Data Type: Double
000031| 0010 00000d4c Nov, 17 - 23:34:16 | -Calculating Pi : Enabled
000032| 0011 00000d4c Nov, 17 - 23:34:16 | --Thread Priority: THREAD_PRIORITY_NORMAL
000033| 0011 00000d4c Nov, 17 - 23:34:16 | --Pi Iterations: 10,000
000034| 0010 00000d4c Nov, 17 - 23:34:16 | -Sorting Algorithms : Enabled
000035| 0011 00000d4c Nov, 17 - 23:34:16 | --Thread Priority: THREAD_PRIORITY_NORMAL
000036| 0011 00000d4c Nov, 17 - 23:34:16 | --Insertion Sort: Enabled
000037| 0011 00000d4c Nov, 17 - 23:34:16 | --Shell Sort: Enabled
000038| 0011 00000d4c Nov, 17 - 23:34:16 | --Merge Sort: Enabled
000039| 0011 00000d4c Nov, 17 - 23:34:16 | --Heap Sort: Enabled
000040| 0011 00000d4c Nov, 17 - 23:34:16 | --Quick Sort: Enabled
000041| 0011 00000d4c Nov, 17 - 23:34:16 | --CArray Quick Sort: Enabled
000042| 0011 00000d4c Nov, 17 - 23:34:16 | Sorting Array Size: 100,000
000043| 0010 00000d4c Nov, 17 - 23:34:16 | -Prime Test : Enabled
000044| 0011 00000d4c Nov, 17 - 23:34:16 | --Thread Priority: THREAD_PRIORITY_NORMAL
000045| 0011 00000d4c Nov, 17 - 23:34:16 | --Iterations: 100,000
000046| 0010 00000d4c Nov, 17 - 23:34:16 | -Fast Fourier Transforms : Disabled
000047| 0011 00000d4c Nov, 17 - 23:34:16 | --Thread Priority: THREAD_PRIORITY_NORMAL
000048| 0010 00000d4c Nov, 17 - 23:34:16 | -Chipset : Disabled
000049| 0011 00000d4c Nov, 17 - 23:34:16 | --Thread Priority: THREAD_PRIORITY_NORMAL
000050| 0010 00000d4c Nov, 17 - 23:34:16 | -L1 Cache : Disabled
000051| 0011 00000d4c Nov, 17 - 23:34:16 | --Thread Priority: THREAD_PRIORITY_NORMAL
000052| 0010 00000d4c Nov, 17 - 23:34:16 | -L2 Cache : Disabled
000053| 0011 00000d4c Nov, 17 - 23:34:16 | --Thread Priority: THREAD_PRIORITY_NORMAL
000054| 0010 00000d4c Nov, 17 - 23:34:16 | -Memory : Enabled
000055| 0011 00000d4c Nov, 17 - 23:34:16 | --Thread Priority: THREAD_PRIORITY_NORMAL
000056| 0010 00000d4c Nov, 17 - 23:34:16 | -HD : Enabled
000057| 0011 00000d4c Nov, 17 - 23:34:16 | --Thread Priority: THREAD_PRIORITY_NORMAL
000058| 0010 00000d4c Nov, 17 - 23:34:16 | -MMX : Enabled
000059| 0011 00000d4c Nov, 17 - 23:34:16 | --Thread Priority: THREAD_PRIORITY_NORMAL
000060| 0010 00000d4c Nov, 17 - 23:34:16 | -SSE : Disabled
000061| 0011 00000d4c Nov, 17 - 23:34:16 | --Thread Priority: THREAD_PRIORITY_NORMAL
000062| 0010 00000d4c Nov, 17 - 23:34:16 | -SSE2/SSE3 : Disabled
000063| 0011 00000d4c Nov, 17 - 23:34:16 | --Thread Priority: THREAD_PRIORITY_NORMAL
000064| 0010 00000d4c Nov, 17 - 23:34:16 | -3DNow! : Disabled
000065| 0011 00000d4c Nov, 17 - 23:34:16 | --Thread Priority: THREAD_PRIORITY_NORMAL
000073| 1024 000005f8 Nov, 17 - 23:34:17 | Starting Complex Matrix Module on CPU 1
000074| 1026 000007dc Nov, 17 - 23:34:17 | Starting Calculating Pi Module on CPU 1
000066| 1024 00000458 Nov, 17 - 23:34:17 | Starting Complex Matrix Module on CPU 0
000075| 1028 000000dc Nov, 17 - 23:34:17 | Starting Sorting Algorithms Module on CPU 1
000076| 1030 00000ea0 Nov, 17 - 23:34:17 | Starting Prime Test Module on CPU 1
000067| 1026 00000d40 Nov, 17 - 23:34:17 | Starting Calculating Pi Module on CPU 0
000077| 1038 00000f48 Nov, 17 - 23:34:17 | Starting Memory Mdoule on CPU 1
000078| 1040 00000de8 Nov, 17 - 23:34:17 | Starting HD Module on CPU 1
000068| 1028 00000cec Nov, 17 - 23:34:17 | Starting Sorting Algorithms Module on CPU 0
000069| 1030 00000b14 Nov, 17 - 23:34:17 | Starting Prime Test Module on CPU 0
000079| 1042 00000c3c Nov, 17 - 23:34:17 | Starting MMX Module on CPU 1
000080| 1024 00000c18 Nov, 17 - 23:34:17 | Starting Complex Matrix Module on CPU 2
000070| 1038 00000c28 Nov, 17 - 23:34:17 | Starting Memory Mdoule on CPU 0
000071| 1040 00000550 Nov, 17 - 23:34:17 | Starting HD Module on CPU 0
000072| 1042 000004b8 Nov, 17 - 23:34:17 | Starting MMX Module on CPU 0
000081| 1026 00000df4 Nov, 17 - 23:34:17 | Starting Calculating Pi Module on CPU 2
000082| 1028 000008f8 Nov, 17 - 23:34:17 | Starting Sorting Algorithms Module on CPU 2
000083| 1030 00000f24 Nov, 17 - 23:34:17 | Starting Prime Test Module on CPU 2
000084| 1038 00000f38 Nov, 17 - 23:34:17 | Starting Memory Mdoule on CPU 2
000085| 1040 000001a4 Nov, 17 - 23:34:17 | Starting HD Module on CPU 2
000087| 1024 00000f80 Nov, 17 - 23:34:17 | Starting Complex Matrix Module on CPU 3
000086| 1042 00000f14 Nov, 17 - 23:34:17 | Starting MMX Module on CPU 2
000088| 1026 00000c88 Nov, 17 - 23:34:17 | Starting Calculating Pi Module on CPU 3
000090| 1030 00000814 Nov, 17 - 23:34:17 | Starting Prime Test Module on CPU 3
000089| 1028 000002fc Nov, 17 - 23:34:17 | Starting Sorting Algorithms Module on CPU 3
000091| 1038 00000d44 Nov, 17 - 23:34:17 | Starting Memory Mdoule on CPU 3
000092| 1040 00000240 Nov, 17 - 23:34:17 | Starting HD Module on CPU 3
000093| 1042 00000394 Nov, 17 - 23:34:17 | Starting MMX Module on CPU 3
000094| 0430 00000240 Nov, 17 - 23:40:28 | File Exception error:All or part of the path is invalid:CPU 3: an unnamed file contains an invalid path.
000095| 0430 000001a4 Nov, 17 - 23:40:28 | File Exception error:All or part of the path is invalid:CPU 2: an unnamed file contains an invalid path.
000096| 0430 00000de8 Nov, 17 - 23:40:28 | File Exception error:SHARE.EXE was not loaded, or a shared region was locked:CPU 1: A sharing violation occurred while accessing an unnamed file.
000097| 0430 00000550 Nov, 17 - 23:40:28 | File Exception error:All or part of the path is invalid:CPU 0: an unnamed file contains an invalid path.
000099| 1029 000008f8 Nov, 18 - 05:34:21 | Ending Sorting Algorithms Module on CPU 2
000101| 1031 00000f24 Nov, 18 - 05:34:21 | Ending Prime Test Module on CPU 2
000102| 1043 00000f14 Nov, 18 - 05:34:21 | Ending MMX Module on CPU 2
000103| 1039 00000f38 Nov, 18 - 05:34:21 | Ending Memory Module on CPU 2
000098| 1031 00000814 Nov, 18 - 05:34:21 | Ending Prime Test Module on CPU 3
000111| 1043 00000394 Nov, 18 - 05:34:21 | Ending MMX Module on CPU 3
000110| 1029 000002fc Nov, 18 - 05:34:21 | Ending Sorting Algorithms Module on CPU 3
000107| 1029 00000cec Nov, 18 - 05:34:21 | Ending Sorting Algorithms Module on CPU 0
000109| 1031 00000b14 Nov, 18 - 05:34:21 | Ending Prime Test Module on CPU 0
000100| 1043 000004b8 Nov, 18 - 05:34:21 | Ending MMX Module on CPU 0
000112| 1039 00000d44 Nov, 18 - 05:34:21 | Ending Memory Module on CPU 3
000113| 1039 00000c28 Nov, 18 - 05:34:21 | Ending Memory Module on CPU 0
000105| 1031 00000ea0 Nov, 18 - 05:34:21 | Ending Prime Test Module on CPU 1
000104| 1029 000000dc Nov, 18 - 05:34:21 | Ending Sorting Algorithms Module on CPU 1
000106| 1043 00000c3c Nov, 18 - 05:34:21 | Ending MMX Module on CPU 1
000108| 1039 00000f48 Nov, 18 - 05:34:21 | Ending Memory Module on CPU 1
000115| 1025 000005f8 Nov, 18 - 05:34:21 | Ending Complex Matrix Module on CPU 1
000114| 1025 00000f80 Nov, 18 - 05:34:21 | Ending Complex Matrix Module on CPU 3
000116| 1027 00000df4 Nov, 18 - 05:34:22 | Ending Calculating Pi Module
000117| 1025 00000c18 Nov, 18 - 05:34:22 | Ending Complex Matrix Module on CPU 2
000118| 1027 00000c88 Nov, 18 - 05:34:22 | Ending Calculating Pi Module
000119| 1027 000007dc Nov, 18 - 05:34:22 | Ending Calculating Pi Module
000120| 1027 00000d40 Nov, 18 - 05:34:22 | Ending Calculating Pi Module
000121| 1025 00000458 Nov, 18 - 05:34:22 | Ending Complex Matrix Module on CPU 0
000122| 1009 00000d4c Nov, 18 - 06:46:27 | Closing Hot CPU Tester Pro...
000123| 0000 00000d4c Nov, 18 - 06:46:27 | ************ End of Session ************
    intel q9450 quad
    asus p5n-t
    corsair 4gb
jcgriff2
Banned
Code:
[COLOR=black]000094| 0430 00000240 Nov, 17 - 23:40:28 | File Exception error:All or part of the[/COLOR]
[COLOR=black]path is invalid:[COLOR=red]CPU 3[/COLOR]: an unnamed file contains an invalid path.[/COLOR]
[COLOR=black]000095| 0430 000001a4 Nov, 17 - 23:40:28 | File Exception error:All or part of the[/COLOR]
[COLOR=black]path is invalid:[COLOR=red]CPU 2[/COLOR]: an unnamed file contains an invalid path.[/COLOR]
[COLOR=black]000096| 0430 00000de8 Nov, 17 - 23:40:28 | File Exception error:[B]SHARE.EXE was[/B][/COLOR]
[COLOR=darkred][COLOR=black][B]not loaded, or a shared region was locked[/B]:[/COLOR][COLOR=red]CPU 1[/COLOR]: [/COLOR][COLOR=black]A sharing violation occurred[/COLOR]
[COLOR=black]while accessing an unnamed file.[/COLOR]
[COLOR=black]000097| 0430 00000550 Nov, 17 - 23:40:28 | File Exception error:All or part of the[/COLOR]
[COLOR=darkorchid][COLOR=black]path is invalid:[/COLOR][COLOR=red]CPU 0[/COLOR][/COLOR][COLOR=black]: an unnamed file contains an invalid path.[/COLOR]
Hi. . .
Interesting results.
Did you ever install a program directly from an external source - DVD, USB, ext HDD? This may explain the invalid path and unnamed file - as it not there now to be found. It could be a path with an invalid character in it.
I see that a lock is mentioned - but only by CPU 1. Why not the others? If CPU 1 found it to be locked, what has a lock on it and why did CPU 1 differentiate it and not the other 3?
The Event Viewer may hold a clue here. The system and app logs were included in my last post
wevtutil qe Application. . . .
wevtutil qe System. . . .
WERCON may also have a lead (msinfo32 saved as an NFO file).
This could also be NVidia.
CPU ?
Regards. . .
jcgriff2
    HP dv7-1020us
    4096mb DDR2 SDRAM
    IDT
    Logitech USB
    Intel 5100
weejokey
the only external thing i d/l from a website for hardware was from saitek
http://www.saitek.com/uk/down/drivers2.asp
these are the sst software and drivers for vista
everthing else is xfire , teamspeak ,avg 8.0 and creative drivers for my sound card
p.s. will try the event viewr tonight
    intel q9450 quad
    asus p5n-t
    corsair 4gb
weejokey
here is the folder not to sure if the dos worked or not let me know
    intel q9450 quad
    asus p5n-t
    corsair 4gb
jcgriff2
Banned
Hi. . .
Thanks for reports.
In my last post, I was asking if you did any program installs from the DVD or USB... apologies if not clear.
I started through the files you attached - so far I came upon the following in dxdiag:
Code:
**  E D I T E D  * *
 Name: Creative SB X-Fi
Device ID: PCI\VEN_1102&DEV_000B&SUBSYS_00431102&REV_03\4&3B7303FA&0&00A8
   Driver: C:\Windows\system32\CT1MGM.ROM, [COLOR=red]2/25/2000[/COLOR] 12:49:36, 1048576 bytes
   Driver: C:\Windows\system32\CT2MGM.SF2, [COLOR=red]9/22/1999 [COLOR=black]23:18:38, 2167684 bytes[/COLOR]
[COLOR=red]   [/COLOR][COLOR=black]Driver: C:\Windows\system32\default4.sfm,[/COLOR] 1/3/2002[/COLOR] 15:44:16, 59 bytes
   Driver: C:\Windows\system32\default8.sfm, [COLOR=red]1/3/2002[/COLOR] 15:44:16, 59 bytes
   Driver: C:\Windows\system32\default.sfm,[COLOR=red] 1/3/2002[/COLOR] 15:44:16, 59 bytes
   Driver: C:\Windows\Temp\ctpxst32.exe, , 0 bytes
   Driver: C:\Windows\Temp\cttele32.dll, , 0 bytes
Please see if these files are in \windows\system32 and if dated as above. The 2 in the \windows\temp folder are odd b/c -0- bytes. I have not linked them to any errors at this time, but the dates caught my attention.
Regards. . .
jcgriff2
    HP dv7-1020us
    4096mb DDR2 SDRAM
    IDT
    Logitech USB
    Intel 5100
weejokey
yes i have those dates in system32 ,they seem a bit strange for a computer just built last week do they not?
    intel q9450 quad
    asus p5n-t
    corsair 4gb
jcgriff2
Banned
That is what I thought, too. 1999?
In the drvquery report, every driver is listed as loading from \windows\system32\drivers - except 2. One is a Microsoft Vista log file driver (clfs.sys) and is loaded from \windows\system32 - which is normal.
The other is not so normal given the # of queries I have seen. It is a kernel mode driver - uxddrv.sys - loaded from the folder c:\pcspro
Code:
uxddrv       Dynamically loaded Uxd Dynamically loaded Uxd Kernel
        Manual          24/11/2005 09:14:50
\??\C:\pcspro\uxddrv.sys                         416 bytes
I am unable to find information on this driver at this time. Do you have a folder named c:\pcspro? Please run this command from an elevated admin cmd/DOS prompt -
Code:
[B][COLOR=blue]dir c:\pcspro /a /s > %temp%\0.txt & start notepad %temp%\0.txt[/COLOR][/B]
A notepad will appear - paste contents into post if not too large; else attach text file.
Regards. . .
JC
    HP dv7-1020us
    4096mb DDR2 SDRAM
    IDT
    Logitech USB
    Intel 5100
weejokey
hi jc the company who built it are called pcspecialists so seems like a folder they put in here is the text file
Volume in drive C has no label.
Volume Serial Number is 0C02-C7B6
Directory of c:\pcspro
05/10/2008 11:09 <DIR> .
05/10/2008 11:09 <DIR> ..
17/10/2008 13:56 748 1core30min.wsc
17/10/2008 13:56 752 2core30min.wsc
17/10/2008 13:57 753 3core30min.wsc
17/10/2008 13:57 752 4core30min.wsc
30/10/2008 12:15 842 BurnIn.wsc
30/10/2008 12:16 26,012 center.wav
30/10/2008 12:15 4,194 CfrWstRep.ini
30/10/2008 12:15 53,248 Client.dll
30/10/2008 12:15 312,320 D3DXU.dll
09/10/2008 15:53 44,016 default.cfg
30/10/2008 12:16 1,543 default.wsc
09/07/2008 19:21 57,472,234 EVE.wmv
30/10/2008 12:16 26,786 left.wav
30/10/2008 12:16 26,786 leftf.wav
30/10/2008 12:16 39,188 lefts.wav
30/10/2008 12:17 1,010,473 m0.x
30/10/2008 12:17 1,349,963 m1.x
30/10/2008 12:17 1,176,408 m2.x
30/10/2008 12:15 49,152 MBTest.dll
30/10/2008 12:17 29,112 right.wav
30/10/2008 12:17 29,112 rightf.wav
30/10/2008 12:17 40,740 rights.wav
30/10/2008 12:17 333,244 speaker.avi
30/10/2008 12:17 22,912 sub.wav
10/07/2008 16:04 90,112 testu.dll
30/10/2008 12:15 786,486 UltraX.bmp
30/10/2008 12:17 6,380 ux0.uxd
30/10/2008 12:18 1,710,280 ux1.uxd
30/10/2008 12:18 1,267,500 ux2.uxd
30/10/2008 12:18 53,248 uxdcmnci.dll
30/10/2008 12:18 390,144 uxdcmnCvi.dll
30/10/2008 12:15 102,912 UxdCmnFl.dll
30/10/2008 12:18 73,728 uxdcmnim.dll
30/10/2008 12:18 90,112 uxdcmnmdt.dll
30/10/2008 12:18 139,264 uxdcmnpi.dll
30/10/2008 12:18 27,648 uxdcmnports.dll
30/10/2008 12:18 86,016 uxdcmnpt.dll
30/10/2008 12:18 15,872 uxdcmnptw.dll
30/10/2008 12:18 65,536 uxdcmntv.dll
30/10/2008 12:18 61,440 uxdcmnuk.dll
30/10/2008 12:18 2,336 uxddrv.sys
30/10/2008 12:18 90,112 uxdemt.dll
30/10/2008 12:18 57,344 uxdext.dll
30/10/2008 12:18 382,464 uxdfunc.dll
30/10/2008 12:18 12,288 uxdsmart.dll
28/10/2008 14:48 103,451,122 WOTLK_WEB_1280_EN_SUB_XVID_PEGI.avi
30/10/2008 12:16 132 WST.wsc
30/10/2008 12:16 267 WSTMB.wsc
14/10/2008 12:15 2,440,064 wstpro.chm
30/10/2008 12:12 2,835,968 WSTPro.exe
30/10/2008 12:16 565 WSTPro.exe.manifest
30/10/2008 12:18 153 wst_eng.wsc
30/10/2008 12:18 152 wst_ger.wsc
53 File(s) 176,290,935 bytes
Total Files Listed:
2 Dir(s) 108,198,096,896 bytes free
    intel q9450 quad
    asus p5n-t
    corsair 4gb
jcgriff2
Banned
Hi. . .
They left alot of baggage behind! But other OEMs leave much more.
Not sure what uxddrv.sys does, it is in the listing from your last post w/ 30 Oct 2008 file date:
Code:
The linkage date is 24 Nov 2005 as driverquery shows:
Code:
24/11/2005 09:14:50
I went through the Event Viewer System log and found the 1st ~300 entries to be from the OEM:
» 9 Oct 2008 -16.53.32 - clearing of Event logs
» " " 16.53.47 - system shutdown initiated
» 11 Oct - 17.18.20 - System back up; Windows/driver loading continues
» " " 17.20.42 - system restart
» " " 17.27.48 - events end
» 13 Nov 2008 - 16.28.01 - 1st event logged after your initial boot
The there are 1000's of these errors:
Code:
Event[19706]:
  Log Name: System
  Source: Microsoft-Windows-DistributedCOM
  Date: 2008-11-13T17:40:33.000
  Event ID: 10016
  Task: N/A
  Level: Error
  Opcode: N/A
  Keyword: Classic
  User: S-1-5-21-2472493952-838534139-617126339-1003
    Description:
The machine-default permission settings do not grant Local Activation permission
for the COM Server application with CLSID
{BC866CF2-5486-41F7-B46B-9AA49CF3EBB1}
 to the user J*/ SID (S-1-5-21-2472493952-838534139-617126339-1003) from
address LocalHost (Using LRPC). This security permission can be modified using the
 Component Services administrative tool.
This is the type of install I was looking for earlier - from drive d:
Code:
[FONT=Lucida Console]Install;file:D:\x86\Setup.exe[/FONT]
[FONT=Lucida Console]Date: 2008-11-13T21:34:21.000[/FONT]
[FONT=Lucida Console]InstallDate    REG_SZ    20081113[/FONT]
[FONT=Lucida Console]InstallLocation    REG_SZ    [COLOR=blue]C:\Program Files\Activision\Call of Duty - World at War\[/COLOR][/FONT]
[FONT=Lucida Console]Install[COLOR=red]Source[/COLOR]    REG_SZ    [COLOR=red]D:\[/COLOR][/FONT]
The program install is followed by
Code:
add Service SaiH80C1 for Device Instance ID HID\VID_06A3&PID_80C1\6&23E39885&0&0000
add Service HidUsb for Device Instance ID USB\VID_06A3&PID_80C1\5&19448E6D&0&4
add Service SaiNtBus for Device Instance ID ROOT\SAITEK_MAGIC_BUS\0000
add Service SaiMini for Device Instance ID SAITEKMAGICBUS\SAITEKKEYBOARD\1&A2CA95B&1&0000
add Service SaiMini for Device Instance ID SAITEKMAGICBUS\SAITEKMOUSE\1&A2CA95B&1&0000
add Service SaiMini for Device Instance ID SAITEKMAGICBUS\SAITEKHOTKEYS\1&A2CA95B&1&0000
add Service kbdhid for Device Instance ID HID\SAITEKKEYBOARD\2&2CC463A3&0&0000
add Service kbdclass for Device Instance ID HID\SAITEKKEYBOARD\2&2CC463A3&0&0000
add Service mouhid for Device Instance ID HID\SAITEKMOUSE\2&36C29A16&0&0000
add Service mouclass for Device Instance ID HID\SAITEKMOUSE\2&36C29A16&0&0000
add Service HidServ for Device Instance ID HID\SAITEKHOTKEYS\2&34FF1239&0&0000
(each had a driver install)
About 1 hour later:
@ 21:12:24 on 13/11/2008 - BSOD - but not with a 0x101 -
0x000000d1 (0x00000000, 0x00000002, 0x00000000, 0xa9cb700a)
0xd1 = DRIVER_IRQL_NOT_LESS_OR_EQUAL = a kernel-mode driver attempted to access pageable memory when it should not have (process IRQL that was too high). A 0xd1 is usually caused by drivers that have used improper addresses. Parm 4 0xa9cb700a is the address of the object that referenced the memory address in parm 1 - 0x0 - an invalid address.
A complete list of BSODs. . . the last 8 are 0xd1 - the very 1st BSODs
Code:
[FONT=Lucida Console][COLOR=blue]0x00000101 (0x00000031, 0x00000000, 0x8ad14120, 0x00000002)[/COLOR][/FONT]
[FONT=Lucida Console]21:51:37 on 17/11/2008 [/FONT]
[FONT=Lucida Console][COLOR=blue]0x00000101 (0x00000031, 0x00000000, 0x803d1120, 0x00000001)[/COLOR][/FONT]
[FONT=Lucida Console]21:40:40 on 17/11/2008 [/FONT]
[FONT=Lucida Console]21:05:50 on 17/11/2008 [/FONT]
[FONT=Lucida Console][COLOR=red]0x000000d1 (0x00000000, 0x00000002, 0x00000000, 0x983de00a)[/COLOR][/FONT]
[FONT=Lucida Console]15:17:48 on 17/11/2008 [/FONT]
[FONT=Lucida Console][COLOR=#ff0000]0x000000d1 (0x00000000, 0x00000002, 0x00000000, 0xaf1bd00a)[/COLOR][/FONT]
[FONT=Lucida Console]11:15:33 on 17/11/2008 [/FONT]
[FONT=Lucida Console]21:23:53 on 16/11/2008 [/FONT]
[FONT=Lucida Console][COLOR=green]no bugcheck[/COLOR][/FONT]
[FONT=Lucida Console]15:03:14 on 16/11/2008 [/FONT]
[FONT=Lucida Console]19:51:28 on 15/11/2008 [/FONT]
[FONT=Lucida Console]21:35:11 on 14/11/2008 [/FONT]
[FONT=Lucida Console]20:53:36 on 14/11/2008 [/FONT]
[FONT=Lucida Console][COLOR=#ff0000]0x000000d1 (0x00000000, 0x00000002, 0x00000000, 0x9d7e500a)[/COLOR][/FONT]
[FONT=Lucida Console]19:45:04 on 14/11/2008 [/FONT]
[FONT=Lucida Console]15:54:20 on 14/11/2008 [/FONT]
[FONT=Lucida Console]15:42:11 on 14/11/2008 [/FONT]
[FONT=Lucida Console]15:27:48 on 14/11/2008 [/FONT]
[FONT=Lucida Console]15:14:33 on 14/11/2008 [/FONT]
[FONT=Lucida Console][COLOR=#ff0000]0x000000d1 (0x00000000, 0x00000002, 0x00000000, 0xa09ba00a)[/COLOR][/FONT]
[FONT=Lucida Console]10:41:42 on 14/11/2008 [/FONT]
[FONT=Lucida Console][COLOR=#ff0000]0x000000d1 (0x00000000, 0x00000002, 0x00000000, 0x999b500a)[/COLOR][/FONT]
[FONT=Lucida Console]00:29:23 on 14/11/2008 [/FONT]
[FONT=Lucida Console][COLOR=#ff0000]0x000000d1 (0x00000000, 0x00000002, 0x00000000, 0x995de00a)[/COLOR][/FONT]
[FONT=Lucida Console]00:15:33 on 14/11/2008 [/FONT]
[FONT=Lucida Console][COLOR=#ff0000]0x000000d1 (0x00000000, 0x00000002, 0x00000000, 0x995dd00a)[/COLOR][/FONT]
[FONT=Lucida Console]00:09:22 on 14/11/2008 [/FONT]
[FONT=Lucida Console][COLOR=#ff0000]0x000000d1 (0x00000000, 0x00000002, 0x00000000, 0x8efa900a)[/COLOR][/FONT]
[FONT=Lucida Console]22:31:48 on 13/11/2008 [/FONT]
[FONT=Lucida Console][COLOR=#ff0000]0x000000d1 (0x00000000, 0x00000002, 0x00000000, 0x995e400a)[/COLOR][/FONT]
[FONT=Lucida Console]21:31:36 on 13/11/2008 [/FONT]
[FONT=Lucida Console][COLOR=#ff0000]0x000000d1 (0x00000000, 0x00000002, 0x00000000, 0x8fdbf00a)[/COLOR][/FONT]
[FONT=Lucida Console]21:21:56 on 13/11/2008 [/FONT]
[FONT=Lucida Console][COLOR=#ff0000]0x000000d1 (0x00000000, 0x00000002, 0x00000000, 0xa9cb700a)[/COLOR][/FONT]
[FONT=Lucida Console]21:12:24 on 13/11/2008 [/FONT]
Finding all of this makes even less of a case for return to OEM in my opinion. The logs show the OEM running w/o incident. Then you receive it and for 5 hours the system is up & functional, installing 100+ Windows Updates, drivers, etc... before the 1st 0xd1 BSOD. However, there are the DCOM errors. How or if they contribute here, I don't know. Given the invalid path results from the CPU test, I think the manufacturer will re-format, re-install Vista, test the system, possibly install different graphic drivers and probably find nothing wrong, leaving you without your system for a time and a potential £35 fee for return. I don't know the comany, but doubt they will invest the time as you and I have here to investigate the matter.
Assuming this is the OEM website -
PCSPECIALIST.CO.UK - Custom PCs, Custom Computers, Custom PC, Custom Built Computers, Gaming PC
Per #3, for a 0xd1:
"Error code 000000d1 – Again, this could be a graphics card problem. Please try downloading the latest graphics drivers (Advanced Micro Devices Inc. or Welcome to NVIDIA - World Leader in Visual Computing Technologies) and if these don’t work, please contact us. "
Per #5 - Returns:
"5. If we agree to have a computer back acting on your advice of a possible fault, and once we receive the computer back, there is no fault found, you will be charged £35 inc VAT to cover our cost of collecting the computer from yourself and returning the computer to you. We do not currently charge for labour costs. The same will apply to computers with faulty hardware not originating from our company, and also for computers that have developed a fault due to being adjusted by anyone other than us. Due to previous experience, we will not dispatch the computer back to you until this money has been paid in full if a charge is incurred. "
One way that may help in the decision making process is to re-install Vista yourself - invoke system recovery. It will take about an hour of system time. Then re-run the CPU test b4 you add anything to the system and see if the invalid path error is there. Did you purchase the kb, mouse, etc... (in the services mentioned above) from the OEM?
One other item that I have seen repeatedly in un-solved mysterious BSODs for months now are the system services PnkBstrA & B. They have something to do with anti-cheat gaming, so I am told. I have never linked them conclusively to a BSOD, but being among the first to load they remain on my suspect list. What do they do for you? I am not a gamer myself.
Regards. . .
JC
    HP dv7-1020us
    4096mb DDR2 SDRAM
    IDT
    Logitech USB
    Intel 5100
weejokey
hi jc
the siatek one is my gaming keyboard which i initally installed and it kept crashing the computer as soon as you preesed a button i tried to reinsatall it about 4 timesall with the same error reporting,most of the crashes have happened when this has not even been connected to the system(or drivers)awaiting response on this from saitek themselves as they can't explain it either.
Code:
Install;file:D:\x86\Setup.exeDate: 2008-11-13T21:34:21.000 InstallDate REG_SZ 20081113InstallLocation REG_SZ C:\Program Files\Activision\Call of Duty - World at War\InstallSource REG_SZ D:\
have i installed this wrong?that was the day cod 5 was released on pre order
the PnkBstrA & B. could well be the punkbuster files for anti cheating which may i add have not tampered with :D
in all that you have found do you think a reinstall will sort all this out?
as i have the vista disk here
    intel q9450 quad
    asus p5n-t
    corsair 4gb
jcgriff2
Banned
Hi. . .
I didn't mean to insinuate that you did anything wrong w/ program install from d: drive. If legit DVD install (I don't mean vs. an illegal one) - should not be a problem at all. MS Office and many others are installed from DVD. I have come across many who have downloaded a program (whether freeware or not), have transferred it to DVD or USB then perform a direct install from it. The program installs, but records the fact it came from drive d:, e:, etc... and keeps searching for a module left behind on that drive - when in fact it is gone. That's all I meant.
As for PnkBstrA & B - as mentioned, I don't know anything about them or whether they could be contributing factor to BSODs - I have simply noticed their presence in many user service listings from BSOD threads. I don't even know what COD 5 is! I have heard the name and seen the modules, but if it were on a screen in front of me, I wouldn't know it. There is certainly nothing wrong with gaming, I just have never been one that could sit still long enough to enjoy it like many others. My time is primarily spent w/ my children 7,10,14,18, Technical Forums and my other career interest of Accounting Policy & Corporate Finance.
And YES, I would advise the re-install of Vista. It bothers me to still see the 0xd1 bugchecks come up as you now confirm earlier system crashes linked to the items that I found to be most likely related to those 0xd1 crashes. If all has been un-installed, why are the 0xd1 bugchecks still appearing? I also wonder if the 0xd1 and 0x101 are connected as they have been alternating in appearance in BSODs.
I think a fresh install followed by the CPU test would be the best course of action. If the test shows the same error after your re-install, then the error would be something I think should have been caught by the OEM. BTW, did I have the right link for the OEM? I ask as I would like to check their forums to see if any other reports of a similar error to yours.
Please let me know how re-install goes.
Any ? - just ask.
Regards. . .
JC
EDIT: I would like any mini kernel dump files that you have as I would like to process them. This way, any post-Vista install BSOD dumps can be processed to see if same probable cause named.
They are in c:\windows\minidump - you will probably have to copy them out to another folder before zipping them up. Attach to net post. ... JC
    HP dv7-1020us
    4096mb DDR2 SDRAM
    IDT
    Logitech USB
    Intel 5100
weejokey
cant seem to get them attached jc ,had an email from pcspecailists(yes that is there site jc)stating that i should try reinstalling the game and if that doesn't work then try taking out one of the meory dimms at a time
really appreciate your help on this m8 thx
    intel q9450 quad
    asus p5n-t
    corsair 4gb
jcgriff2
Banned
pcspecialists then believe the CPU error related to the game install or RAM?
Hard to believe since CPU invalid path/filename error came from their own folder!
I'll send you my email for attachments.
Just curious - did they say they thoroughly tested system prior to shipping it?
Thanks. . .
JC
    HP dv7-1020us
    4096mb DDR2 SDRAM
    IDT
    Logitech USB
    Intel 5100
jcgriff2
Banned
Hi. . .
I received your email w/ attached zip file containing 8 mini kernel dumps. Thank you.
I immediately downloaded the zip file and was going to leave it until tomorrow (Mon), but got curious - wanted to see if there were 23 dump files to match the 23 BSODs that I found in the Event Viewer System Logs. I found just 8 dump files -- then noticed the dates -
Code:
[COLOR=red]10/03/2008[/COLOR]  04:00 PM           139,192 [COLOR=red]Mini100308-01[/COLOR].dmp
[COLOR=red]10/09/2008[/COLOR]  12:54 PM           139,192 [COLOR=red]Mini100908-01[/COLOR].dmp
[COLOR=red]10/09/2008[/COLOR]  01:00 PM           139,192 [COLOR=red]Mini100908-02[/COLOR].dmp
[COLOR=blue]11/13/2008[/COLOR]  09:22 PM           179,360 Mini111308-01.dmp
[COLOR=blue]11/13/2008[/COLOR]  09:31 PM           179,360 Mini111308-02.dmp
[COLOR=blue]11/13/2008[/COLOR]  09:44 PM           179,360 Mini111308-03.dmp
[COLOR=blue]11/14/2008[/COLOR]  12:29 AM           179,360 Mini111408-01.dmp
[COLOR=blue]11/14/2008[/COLOR]  12:43 AM           179,360 Mini111408-02.dmp
[COLOR=blue]11/22/2008[/COLOR]  12:07 AM           150,864 Mini112208-01.dmp
What was the actual date that you accepted delivery of your new system?
The Event Viewer logs show an initial event where the system time changes from 11 Oct 2008 to 13 Nov 2008, just after logging an event calling for a time adjustment of +2854867 seconds. If my math is correct, that comes out to 33.042 days. That would make these two timestamps one in the same.
If you received and initially booted your new system on 13 November 2008, then the 3 BSODs occurred while the system was still with the OEM.
I processed the 1st dump file date = 3 October 2008:
Bugcheck = 0x101 (0x31, 0x0, 0x803d1120, 0x1), with the probable cause listed as "unknown image". The process running at the time of the crash was WSTPro.exe - found in the c:\pcspro folder listing in your previous post, with an interesting date of its own:
Code:
Dump Summary
Code:
Built by: 6001.18000.x86fre.longhorn_rtm.080118-1840
Debug session time: Fri Oct  3 10:57:57.898 2008 (GMT-5)
System Uptime: 0 days 3:51:59.782
BugCheck 101, {31, 0, 803d1120, 1}
Probably caused by : Unknown_Image ( ANALYSIS_INCONCLUSIVE )
PROCESS_NAME:  WSTPro.exe
The dump shows the NT Kernel and GUI win32k at work, but the bugcheck issued under NT.
STACK_TEXT:
Code:
8c965918 81abc321 00000101 00000031 00000000 [COLOR=red]nt![/COLOR]Ke[COLOR=blue]BugCheck[/COLOR]Ex+0x1e
8c96594c 81abc02d 93eac41b 000000d1 8c9659dc [COLOR=red]nt![/COLOR]KeUpdateRunTime+0xd5
8c96594c 81ac0176 93eac41b 000000d1 8c9659dc nt!KeUpdateSystemTime+0xed
8c9659dc 81a9c2ce 8c965a2c 00000002 fcf9b000 nt!KeFlushMultipleRangeTb+0x11a
8c965abc 81aa13d8 c07e7ce0 00000004 00000002 nt!MiFlushTbAsNeeded+0x61
8c965afc 81af3024 fcf98000 93600dc0 00000021 nt!MiAllocatePagedPoolPages+0x655
8c965b58 81a4014a 00000021 00003f18 00003f18 nt!MiAllocatePoolPages+0x1f
8c965bb0 81af14cd 00000000 00000021 00003f18 nt!ExpAllocateBigPool+0x97
8c965c14 93f3357a 00000021 00003f10 35316847 nt!ExAllocatePoolWithTag+0x116
8c965c28 93f1a9e7 00003f10 35316847 00000000 [COLOR=red]win32k![/COLOR]Win32AllocPool+0x13
8c965c3c 93f33a75 00003f10 35316847 8c965cc4 [COLOR=red]win32k![/COLOR]PALLOCMEM+0x18
8c965c58 93f1ad18 00003f10 00000005 00000001 win32k!AllocateObject+0x97
8c965c90 93f0afb6 00000378 00000000 00000000 win32k!SURFMEM::bCreateDIB+0x21d
8c965cf4 93f0ae89 ffb258b8 00000006 0108003e win32k!hsurfCreateCompatibleSurface+0xf7
8c965d50 81a5ba7a ffb258b8 000000de 00000012 win32k!GreCreateCompatibleBitmap+0x122
8c965d50 77349a94 ffb258b8 000000de 00000012 nt!KiFastCallEntry+0x12a
WARNING: Frame IP not in any known module. Following frames may be wrong.
0012ef6c 00000000 00000000 00000000 00000000 0x77349a94
Assuming this to be the very 1st BSOD, pcpros does appear to be involved somehow. So... What was the actual date that you accepted delivery of your new system?
More later - it is now 03:45am here! Go to go.
Regards. . .
JC
dbug log
Code:
Opened log file 'A:\D\#Dumps\#__Forums_Vistax64\weejokey_Vistax64_11-18-08\$99-dbug.txt'
Microsoft (R) Windows Debugger Version 6.9.0003.113 AMD64
Loading Dump File [A:\D\#Dumps\#__Forums_Vistax64\weejokey_Vistax64_11-18-08\Mini100308-01.dmp]
Symbol search path is: SRV*a:\symbols*http://msdl.microsoft.com/download/symbols
Executable search path is:
Windows Server 2008 Kernel Version 6001 (Service Pack 1) MP (4 procs) Free x86 compatible
Kernel base = 0x81a04000 PsLoadedModuleList = 0x81b1bc70
Loading Kernel Symbols
Loading User Symbols
Loading unloaded module list
Followup: MachineOwner
0: kd> !analyze -v;r;kv;lmtn;lmtsmn;.bugcheck;.logclose;q
CLOCK_WATCHDOG_TIMEOUT (101)
An expected clock interrupt was not received on a secondary processor in an
MP system within the allocated interval. This indicates that the specified
processor is hung and not processing interrupts.
Arguments:
Arg1: 00000031, Clock interrupt time out interval in nominal clock ticks.
Arg2: 00000000, 0.
Arg3: 803d1120, The PRCB address of the hung processor.
Arg4: 00000001, 0.
Debugging Details:
BUGCHECK_STR:  CLOCK_WATCHDOG_TIMEOUT
CUSTOMER_CRASH_COUNT:  1
DEFAULT_BUCKET_ID:  VISTA_DRIVER_FAULT
CURRENT_IRQL:  1c
STACK_TEXT:
8c965918 81abc321 00000101 00000031 00000000 nt!KeBugCheckEx+0x1e
8c96594c 81abc02d 93eac41b 000000d1 8c9659dc nt!KeUpdateRunTime+0xd5
8c965c28 93f1a9e7 00003f10 35316847 00000000 win32k!Win32AllocPool+0x13
8c965c3c 93f33a75 00003f10 35316847 8c965cc4 win32k!PALLOCMEM+0x18
STACK_COMMAND:  kb
SYMBOL_NAME:  ANALYSIS_INCONCLUSIVE
FOLLOWUP_NAME:  MachineOwner
MODULE_NAME: Unknown_Module
IMAGE_NAME:  Unknown_Image
DEBUG_FLR_IMAGE_TIMESTAMP:  0
FAILURE_BUCKET_ID:  CLOCK_WATCHDOG_TIMEOUT_ANALYSIS_INCONCLUSIVE
eax=81afc920 ebx=00000000 ecx=81b041f8 edx=000002da esi=81afc93c edi=8c965590
eip=81ad1163 esp=8c965900 ebp=8c965918 iopl=0         nv up ei pl nz na pe nc
cs=0008  ss=0010  ds=0023  es=0023  fs=0030  gs=0000             efl=00000206
nt!KeBugCheckEx+0x1e:
81ad1163 8be5            mov     esp,ebp
ChildEBP RetAddr  Args to Child
8c96594c 81ac0176 93eac41b 000000d1 8c9659dc nt!KeUpdateSystemTime+0xed (FPO: [0,2] TrapFrame @ 8c96595c)
8c965c28 93f1a9e7 00003f10 35316847 00000000 win32k!Win32AllocPool+0x13 (FPO: [Non-Fpo])
8c965c3c 93f33a75 00003f10 35316847 8c965cc4 win32k!PALLOCMEM+0x18 (FPO: [Non-Fpo])
8c965c58 93f1ad18 00003f10 00000005 00000001 win32k!AllocateObject+0x97 (FPO: [Non-Fpo])
8c965c90 93f0afb6 00000378 00000000 00000000 win32k!SURFMEM::bCreateDIB+0x21d (FPO: [Non-Fpo])
8c965cf4 93f0ae89 ffb258b8 00000006 0108003e win32k!hsurfCreateCompatibleSurface+0xf7 (FPO: [Non-Fpo])
8c965d50 81a5ba7a ffb258b8 000000de 00000012 win32k!GreCreateCompatibleBitmap+0x122 (FPO: [Non-Fpo])
8c965d50 77349a94 ffb258b8 000000de 00000012 nt!KiFastCallEntry+0x12a (FPO: [0,3] TrapFrame @ 8c965d64)
start    end        module name
80409000 80411000   kdcom    kdcom.dll    Sat Jan 19 02:31:53 2008 (4791A769)
80411000 80471000   mcupdate_GenuineIntel mcupdate_GenuineIntel.dll Sat Jan 19 02:29:43 2008 (4791A6E7)
80471000 80482000   PSHED    PSHED.dll    Sat Jan 19 02:31:21 2008 (4791A749)
80482000 8048a000   BOOTVID  BOOTVID.dll  Sat Jan 19 02:27:15 2008 (4791A653)
8048a000 804cb000   CLFS     CLFS.SYS     Sat Jan 19 00:28:01 2008 (47918A61)
804cb000 805ab000   CI       CI.dll       Sat Jan 19 02:31:08 2008 (4791A73C)
805ab000 805ec000   storport storport.sys Sat Jan 19 00:49:49 2008 (47918F7D)
805ec000 80600000   smb      smb.sys      Sat Jan 19 00:55:27 2008 (479190CF)
80604000 80680000   Wdf01000 Wdf01000.sys Sat Jan 19 00:52:21 2008 (47919015)
80680000 8068d000   WDFLDR   WDFLDR.SYS   Sat Jan 19 00:52:19 2008 (47919013)
8068d000 806d3000   acpi     acpi.sys     Sat Jan 19 00:32:48 2008 (47918B80)
806d3000 806dc000   WMILIB   WMILIB.SYS   Sat Jan 19 00:53:08 2008 (47919044)
806dc000 806e4000   msisadrv msisadrv.sys Sat Jan 19 00:32:51 2008 (47918B83)
806e4000 8070b000   pci      pci.sys      Sat Jan 19 00:32:57 2008 (47918B89)
8070b000 8071a000   partmgr  partmgr.sys  Sat Jan 19 00:49:54 2008 (47918F82)
8071a000 80729000   volmgr   volmgr.sys   Sat Jan 19 00:49:51 2008 (47918F7F)
80729000 80773000   volmgrx  volmgrx.sys  Sat Jan 19 00:50:00 2008 (47918F88)
80773000 8077a000   pciide   pciide.sys   Sat Jan 19 00:49:42 2008 (47918F76)
8077a000 80788000   PCIIDEX  PCIIDEX.SYS  Sat Jan 19 00:49:40 2008 (47918F74)
80788000 80798000   mountmgr mountmgr.sys Sat Jan 19 00:49:13 2008 (47918F59)
80798000 807a0000   atapi    atapi.sys    Sat Jan 19 00:49:40 2008 (47918F74)
807a0000 807be000   ataport  ataport.SYS  Sat Jan 19 00:49:40 2008 (47918F74)
807be000 807cb000   nvstor   nvstor.sys   Wed Jun 06 16:34:41 2007 (46671A61)
807cb000 807e8000   nvstor32 nvstor32.sys Thu Aug 09 14:11:36 2007 (46BB58D8)
807e8000 807fe000   tdx      tdx.sys      Sat Jan 19 00:55:58 2008 (479190EE)
81a04000 81dbd000   nt       ntkrpamp.exe Sat Jan 19 00:30:58 2008 (47918B12)
81dbd000 81df0000   hal      halmacpi.dll Sat Jan 19 00:27:20 2008 (47918A38)
82405000 82439000   mv61xx   mv61xx.sys   Fri Jun 15 03:43:38 2007 (4672432A)
82439000 8245f000   SCSIPORT SCSIPORT.SYS Sat Jan 19 00:49:44 2008 (47918F78)
8245f000 82491000   fltmgr   fltmgr.sys   Sat Jan 19 00:28:10 2008 (47918A6A)
82491000 824a1000   fileinfo fileinfo.sys Sat Jan 19 00:34:27 2008 (47918BE3)
824a1000 82512000   ksecdd   ksecdd.sys   Sat Jan 19 00:41:20 2008 (47918D80)
82512000 825f9000   tcpip    tcpip.sys    Sat Jan 19 00:56:48 2008 (47919120)
82603000 8270e000   ndis     ndis.sys     Sat Jan 19 00:55:51 2008 (479190E7)
8270e000 82739000   msrpc    msrpc.sys    Sat Jan 19 00:48:15 2008 (47918F1F)
82739000 82773000   NETIO    NETIO.SYS    Sat Jan 19 00:56:19 2008 (47919103)
82773000 8278e000   fwpkclnt fwpkclnt.sys Sat Jan 19 00:55:44 2008 (479190E0)
8278e000 82799000   tunnel   tunnel.sys   Sat Jan 19 00:55:50 2008 (479190E6)
82799000 827a8000   intelppm intelppm.sys Sat Jan 19 00:27:20 2008 (47918A38)
827a8000 827b5080   1394BUS  1394BUS.SYS  Sat Jan 19 00:53:27 2008 (47919057)
827b6000 827c8000   HDAudBus HDAudBus.sys Tue Nov 27 18:18:41 2007 (474CA5D1)
827c8000 827f2000   ks       ks.sys       Sat Jan 19 00:49:21 2008 (47918F61)
82809000 82918000   Ntfs     Ntfs.sys     Sat Jan 19 00:28:54 2008 (47918A96)
82918000 82951000   volsnap  volsnap.sys  Sat Jan 19 00:50:10 2008 (47918F92)
82951000 82959000   spldr    spldr.sys    Thu Jun 21 20:29:17 2007 (467B17DD)
82959000 82968000   mup      mup.sys      Sat Jan 19 00:28:20 2008 (47918A74)
82968000 8298f000   ecache   ecache.sys   Sat Jan 19 00:50:47 2008 (47918FB7)
8298f000 829a0000   disk     disk.sys     Sat Jan 19 00:49:47 2008 (47918F7B)
829a0000 829c1000   CLASSPNP CLASSPNP.SYS Sat Jan 19 00:49:36 2008 (47918F70)
829c1000 829ca000   crcdisk  crcdisk.sys  Sat Jan 19 00:50:29 2008 (47918FA5)
8e00a000 8e6abf00   nvlddmkm nvlddmkm.sys Wed Jun 18 21:36:16 2008 (4859B810)
8e6ac000 8e74b000   dxgkrnl  dxgkrnl.sys  Sat Jan 19 00:36:36 2008 (47918C64)
8e74b000 8e758000   watchdog watchdog.sys Sat Jan 19 00:35:29 2008 (47918C21)
8e758000 8e772000   serial   serial.sys   Sat Jan 19 00:49:34 2008 (47918F6E)
8e772000 8e77c000   serenum  serenum.sys  Sat Jan 19 00:49:29 2008 (47918F69)
8e77c000 8e786000   usbohci  usbohci.sys  Sat Jan 19 00:53:21 2008 (47919051)
8e786000 8e7c4000   USBPORT  USBPORT.SYS  Sat Jan 19 00:53:23 2008 (47919053)
8e7c4000 8e7d3000   usbehci  usbehci.sys  Sat Jan 19 00:53:21 2008 (47919051)
8e7d3000 8e7eb000   cdrom    cdrom.sys    Sat Jan 19 00:49:50 2008 (47918F7E)
8e7eb000 8e7fa200   ohci1394 ohci1394.sys Sat Jan 19 00:53:33 2008 (4791905D)
8e803000 8e8fde00   nvmfdx32 nvmfdx32.sys Fri Oct 12 19:15:46 2007 (47100022)
8e8fe000 8e906000   ASACPI   ASACPI.sys   Wed Oct 18 01:44:46 2006 (4535BF4E)
8e906000 8e934000   msiscsi  msiscsi.sys  Sat Jan 19 00:50:44 2008 (47918FB4)
8e934000 8e93f000   TDI      TDI.SYS      Sat Jan 19 00:57:10 2008 (47919136)
8e93f000 8e956000   rasl2tp  rasl2tp.sys  Sat Jan 19 00:56:33 2008 (47919111)
8e956000 8e961000   ndistapi ndistapi.sys Sat Jan 19 00:56:24 2008 (47919108)
8e961000 8e984000   ndiswan  ndiswan.sys  Sat Jan 19 00:56:32 2008 (47919110)
8e984000 8e993000   raspppoe raspppoe.sys Sat Jan 19 00:56:33 2008 (47919111)
8e993000 8e9a7000   raspptp  raspptp.sys  Sat Jan 19 00:56:34 2008 (47919112)
8e9a7000 8e9bc000   rassstp  rassstp.sys  Sat Jan 19 00:56:43 2008 (4791911B)
8e9bc000 8e9cc000   termdd   termdd.sys   Sat Jan 19 01:01:06 2008 (47919222)
8e9cc000 8e9d7000   kbdclass kbdclass.sys Sat Jan 19 00:49:14 2008 (47918F5A)
8e9d7000 8e9e2000   mouclass mouclass.sys Sat Jan 19 00:49:14 2008 (47918F5A)
8e9e2000 8e9e3380   swenum   swenum.sys   Sat Jan 19 00:49:20 2008 (47918F60)
8e9e4000 8e9ee000   mssmbios mssmbios.sys Sat Jan 19 00:32:55 2008 (47918B87)
8e9ee000 8e9fb000   umbus    umbus.sys    Sat Jan 19 00:53:40 2008 (47919064)
8ea00000 8ea34000   usbhub   usbhub.sys   Sat Jan 19 00:53:40 2008 (47919064)
8ea34000 8ea45000   NDProxy  NDProxy.SYS  Sat Jan 19 00:56:28 2008 (4791910C)
8ea45000 8ea9e000   ADIHdAud ADIHdAud.sys Wed Aug 15 17:29:53 2007 (46C37051)
8ea9e000 8eacb000   portcls  portcls.sys  Sat Jan 19 00:53:17 2008 (4791904D)
8eacb000 8eaf0000   drmk     drmk.sys     Sat Jan 19 01:53:02 2008 (47919E4E)
8eaf0000 8eb2f000   HdAudio  HdAudio.sys  Wed Nov 01 21:43:11 2006 (45494D2F)
8eb2f000 8eb46000   usbccgp  usbccgp.sys  Sat Jan 19 00:53:29 2008 (47919059)
8eb46000 8eb47700   USBD     USBD.SYS     Sat Jan 19 00:53:17 2008 (4791904D)
8eb48000 8eb51000   hidusb   hidusb.sys   Sat Jan 19 00:53:17 2008 (4791904D)
8eb51000 8eb61000   HIDCLASS HIDCLASS.SYS Sat Jan 19 00:53:16 2008 (4791904C)
8eb61000 8eb67380   HIDPARSE HIDPARSE.SYS Sat Jan 19 00:53:16 2008 (4791904C)
8eb68000 8eb71000   kbdhid   kbdhid.sys   Sat Jan 19 00:49:17 2008 (47918F5D)
8eb71000 8eb79000   mouhid   mouhid.sys   Sat Jan 19 00:49:16 2008 (47918F5C)
8eb79000 8eb82000   Fs_Rec   Fs_Rec.SYS   Sat Jan 19 00:27:57 2008 (47918A5D)
8eb82000 8eb89000   Null     Null.SYS     Sat Jan 19 00:49:12 2008 (47918F58)
8eb89000 8eb90000   Beep     Beep.SYS     Sat Jan 19 00:49:10 2008 (47918F56)
8eb90000 8eb99000   rasacd   rasacd.sys   Sat Jan 19 00:56:31 2008 (4791910F)
8eba3000 8ebaf000   vga      vga.sys      Sat Jan 19 00:52:06 2008 (47919006)
8ebaf000 8ebd0000   VIDEOPRT VIDEOPRT.SYS Sat Jan 19 00:52:10 2008 (4791900A)
8ebd0000 8ebd8000   RDPCDD   RDPCDD.sys   Sat Jan 19 01:01:08 2008 (47919224)
8ebd8000 8ebe0000   rdpencdd rdpencdd.sys Sat Jan 19 01:01:09 2008 (47919225)
8ebe0000 8ebeb000   Msfs     Msfs.SYS     Sat Jan 19 00:28:08 2008 (47918A68)
8ebeb000 8ebf9000   Npfs     Npfs.SYS     Sat Jan 19 00:28:09 2008 (47918A69)
8ec0a000 8ec52000   afd      afd.sys      Sat Jan 19 00:57:00 2008 (4791912C)
8ec52000 8ec84000   netbt    netbt.sys    Sat Jan 19 00:55:33 2008 (479190D5)
8ec84000 8ec8d000   ws2ifsl  ws2ifsl.sys  Sat Jan 19 00:56:49 2008 (47919121)
8ec8d000 8eca3000   pacer    pacer.sys    Sat Jan 19 00:55:53 2008 (479190E9)
8eca3000 8ecb1000   netbios  netbios.sys  Sat Jan 19 00:55:45 2008 (479190E1)
8ecb1000 8ecc4000   wanarp   wanarp.sys   Sat Jan 19 00:56:31 2008 (4791910F)
8ecc4000 8ed00000   rdbss    rdbss.sys    Sat Jan 19 00:28:34 2008 (47918A82)
8ed00000 8ed0a000   nsiproxy nsiproxy.sys Sat Jan 19 00:55:50 2008 (479190E6)
8ed0a000 8ed21000   dfsc     dfsc.sys     Sat Jan 19 00:28:20 2008 (47918A74)
8ed21000 8ed2e000   crashdmp crashdmp.sys Sat Jan 19 00:49:43 2008 (47918F77)
8ed2e000 8ed38000   dump_diskdump dump_diskdump.sys Sat Jan 19 00:49:43 2008 (47918F77)
8ed38000 8ed55000   dump_nvstor32 dump_nvstor32.sys Thu Aug 09 14:11:36 2007 (46BB58D8)
8ed55000 8ed5f000   Dxapi    Dxapi.sys    Sat Jan 19 00:36:12 2008 (47918C4C)
8ed5f000 8ed6e000   monitor  monitor.sys  Sat Jan 19 00:52:19 2008 (47919013)
8ed6e000 8ed89000   luafv    luafv.sys    Sat Jan 19 00:30:35 2008 (47918AFB)
8ed89000 8edc2000   mrxsmb10 mrxsmb10.sys Sat Jan 19 00:28:40 2008 (47918A88)
8edc2000 8ede9000   srv2     srv2.sys     Sat Jan 19 00:29:14 2008 (47918AAA)
93e60000 94061000   win32k   win32k.sys   Sat Jan 19 00:36:46 2008 (47918C6E)
94080000 94089000   TSDDD    TSDDD.dll    unavailable (00000000)
940a0000 940ae000   cdd      cdd.dll      unavailable (00000000)
98606000 986b5000   spsys    spsys.sys    Thu Jun 21 20:33:02 2007 (467B18BE)
986b5000 986c5000   lltdio   lltdio.sys   Sat Jan 19 00:55:03 2008 (479190B7)
986c5000 986d8000   rspndr   rspndr.sys   Sat Jan 19 00:55:03 2008 (479190B7)
986d8000 98743000   HTTP     HTTP.sys     Sat Jan 19 00:55:21 2008 (479190C9)
98743000 98760000   srvnet   srvnet.sys   Sat Jan 19 00:29:11 2008 (47918AA7)
98760000 98779000   bowser   bowser.sys   Sat Jan 19 00:28:26 2008 (47918A7A)
98779000 9878e000   mpsdrv   mpsdrv.sys   Sat Jan 19 00:54:45 2008 (479190A5)
9878e000 987ae000   mrxdav   mrxdav.sys   Sat Jan 19 00:28:44 2008 (47918A8C)
987ae000 987cd000   mrxsmb   mrxsmb.sys   Sat Jan 19 00:28:33 2008 (47918A81)
987cd000 987e5000   mrxsmb20 mrxsmb20.sys Sat Jan 19 00:28:35 2008 (47918A83)
99005000 99051000   srv      srv.sys      Sat Jan 19 00:29:25 2008 (47918AB5)
99069000 99147000   peauth   peauth.sys   Mon Oct 23 04:55:32 2006 (453C8384)
99147000 99151000   secdrv   secdrv.SYS   Wed Sep 13 09:18:32 2006 (45080528)
99151000 9915d000   tcpipreg tcpipreg.sys Sat Jan 19 00:56:07 2008 (479190F7)
9915d000 99173000   cdfs     cdfs.sys     Sat Jan 19 00:28:02 2008 (47918A62)
991ac000 991d4000   fastfat  fastfat.SYS  Sat Jan 19 00:28:00 2008 (47918A60)
991fb000 991fb920   uxddrv   uxddrv.sys   Thu Nov 24 04:14:50 2005 (4385848A)
Unloaded modules:
991e9000 991fb000   WUDFPf.sys
    Timestamp: unavailable (00000000)
    Checksum:  00000000
991d4000 991e9000   WUDFRd.sys
    Checksum:  00000000
9919a000 991ac000   USBSTOR.SYS
    Checksum:  00000000
99173000 9917d000   hiber_storpo
    Checksum:  00000000
9917d000 9919a000   hiber_nvstor
    Checksum:  00000000
99051000 99069000   parport.sys
    Checksum:  00000000
829ca000 829d7000   crashdmp.sys
    Checksum:  00000000
829d7000 829e1000   dump_storpor
    Checksum:  00000000
829e1000 829fe000   dump_nvstor3
    Checksum:  00000000
8eb90000 8eba3000   i8042prt.sys
    Checksum:  00000000
Unloaded modules:
    Checksum:  00000000
    Checksum:  00000000
    Checksum:  00000000
    Checksum:  00000000
    Checksum:  00000000
    Checksum:  00000000
    Checksum:  00000000
    Checksum:  00000000
    Checksum:  00000000
    Checksum:  00000000
Bugcheck code 00000101
Arguments 00000031 00000000 803d1120 00000001
Closing open log file A:\D\#Dumps\#__Forums_Vistax64\weejokey_Vistax64_11-18-08\$99-dbug.txt
    HP dv7-1020us
    4096mb DDR2 SDRAM
    IDT
    Logitech USB
    Intel 5100
