0x00000124 Problem when watch videos and playing games!!
Gamemaster2237
Hello eveyone, I have a problem with my computer every time I watch videos or play games BSOD shows up showing 0x00000124 other times it can happen randomly:cry:!!
Someone please help i really want the play my bf2142 again!:D
Plz tell me any info you need IM not real techie so i need directions to get them;)
MINI DUMP IS ON THE 7TH POST
    Hewlett-Packard Comany a6200n
    AMD Athlon(tm) 64 X2 Dual Core Processor 5000+ 2.60GHz
    Phoenix - AwardBIOS v6.00PG
    2.00 GB RAM
    HP w1907 Wide LCD Monitor
    1400 x 900 x 4294967296 colors
stoneys-nutz
Gamerholic
    Self Build
    Asus P5Q Premium
    2 x ASUS EAH 4870 X 2 (Quad)
    Supreme FX 2
    150 Gig WD Raptor
    300 Gig Maxtor
    300 Gig Maxtor, (External)
    CoolerMaster 1000
    Logitech G5
    Logitech G15
    20Mbps
usasma
Old and cranky
First try running the Windows 7 Upgrade Advisor (free here: http://www.microsoft.com/downloads/...90-7659-4BD9-9E51-2497C146AF15&displaylang=en )
STOP 0x124 errors are errors generated by the Windows Hardware Error Architecture (WHEA) and usually are generated by hardware (like your CPU) rather than Windows. As such they're more difficult to diagnose.
They are usually (in this order):
- hardware failures
- hardware incompatibility
- driver incompatibility
- driver corruption (there is disagreement about this, but I believe that it's possible).
Let us know what the above tool finds out and we'll move on from there. We'll also need more detailed specs on your system, so please fill that out in your profile.
Gamemaster2237
Ok I update my system spects all the way to screen resoultion
When i ran Windows 7 beta it said in devices and programs all was ok
Ram was good for 32bit system 1.88 GB
Windows mail and parental controls: need to download new progams
I remeber something I did just before the errors happen i download windows life essentials and office live add-in 1.4 then i unistalled them i hopes that i would fix them...
it didnt :(
BTW would updating/flashing my BIOS repair this problem because a program called "BIOS AGENT PLUS" said there is an update for my BIOS
Also can someone show me how to get the mini dump file because when it crashes it doesnt make a mini dump!
    2.00 GB RAM
stoneys-nutz
Gamerholic
Other people have had good results updating the bios, if you are going to do that you should know that it is fraught with danger, if it goes wrong it can be a disaster, but some times it's the only option.
If you do update your bios dont use any software to do it, update from inside the bios, this will greatly reduce the chances of errors.
So, it can be risky, but if you read around, then you will see that other users with this problem have had good results with a bios update.
Good luck and post your results.
    Self Build
    Asus P5Q Premium
    Supreme FX 2
    150 Gig WD Raptor
    300 Gig Maxtor
    CoolerMaster 1000
    Logitech G5
    Logitech G15
    20Mbps
Gamemaster2237
heres the mini dump file of the crash
SOMEONE PLZ READ THE MINI DUMP!
  • mini dump.txt
    2.00 GB RAM
