A system change was made by a known application
Daisymay
Could someone please help me with a Windows Defender pop up. It says:-
A system change was made by a known application.
Change type: Application execution
Application C:\windows\System32\mswsock.dll
I have tried Start/cmd/run as administrator/typed netsh winsock reset/exit. (It was successful)
Then Start/cmd/run as administrator/typed netsh int ip reset/exit
(It said C:windows\system32 netsh int ip reset. Resetting Echo Request failed. Access denied.
Resetting interface OK .
Is there anything I can do about "Resetting Echo Request failed. Access denied?"
I know I can stop it by unchecking the box in Windows Defender "Changes made to your computer by software that is permitted to run."
But then I will not be aware of any other changes that are made.
Any help would be much appreciated.
    HPG6000
    2GB
Jacee
Security
This could have come from your Anti-Virus program, or Spybot s&d (if you're using that app) ... If you're still connected to the Internet, then don't try to 'fix' anything within the Winsock.
    Intel(R) Core(TM)2 Quad CPU
    INTEL/D975XBX2
    ATI Radeon HD 2600 Pro
    Samsung SyncMaster 914v
    1280 x 1024
    2/500GB each ... ST3500630AS ATA Device.
    One is not connected
    Rocketfish 700 W
    G.Skill Gigabyte Chassis
    Microsoft PS/2 Mouse
    DSL
    ATI HDMI Audio
