Battery Life
fertedds
Since installing Vista the battery life of my laptop has gone down to 1hour where as it used to go for 3 hours. Is there anyway that I can extend this and have the best performace at the same time?
    ME
    Intel Core 2 Duo 2.40Ghz L2 FSB 1066Mhz
    Gigabyte GA965P DQ6 Rev 1 F11
    Geil PC6400 800Mhz 4GB Dual Channel Ram
    GIGABYTE GTX260
    Creative Sound Blaster XI Gamer Sound Card,
    Seagate 250Gb SATA 11, Samsung 400GB SATA
    Corsair 620W HX Series Modular
    LOGITECH G5
    LOGITECH WAVE USB
    4MB
Hi wizkid, Vista is more resource demanding, more heat is generated which causing the fan running in full blast often. Also, there always process working on the back ground such as indexing or defrag as such. So, I guess there is not much you can do about it.:(
:DHappy new year:D
Bruce
    E6850
    EVGA 122-CK-NF67-A1 680i
    4 x OCZ Platinum 1GB
    ATI Radeon HD 5850 1GB
    SB X-Fi X Audio
    Samsung 23" 5MS
    2048 x 1152
    Seasonic 600W M12
    CM Centurion 5
    air
    100Mbps
Hi Wizkid,
First thing to check is what power plan are you using
You should have an icon in the notification area which will allow you to choose between Power saving, performance and balanced, these may also be tweaked by use of Power options in control panel.
Also have a check in Mobility Centre
Explore the features: Windows Mobility Center
    2 x 1920x1080 @50Hz
    Asus M5A78L-M USB3
    32GB [4x8GB] DDR3 1600 MHz
    Samsung 32" TV
    68 MB Down 18.5 MB Up
Battery just goes dead eventually...no matter what. But first it goes weaker before it conks out. There are some tips on how to prolong battery life, like for three yrs instead of one(lifetime), and for three hours instead of two or one per session (single charge performance). In my HP Notebook : Start > Help and Support > Learning Center > Battery information and some more when you double click power icon on taskbar
    HP Pavilion dv7-1170us
    Intel Core 2 Duo T5800 @ 2.00GHz
    Compal
    NVIDIA GeForce 9600M GT
    1440 x 900
    289.09 GB
    Synaptics PS/2 Port TouchPad
    IBM enhanced (101-or 102) keyboard
    cable Wireless
I have been using the latpop for 30mins now and when I first turned it on its was 100% and now its 20% does this sound like the battery is dieing? Even with power saver turned on
    ME
    GIGABYTE GTX260
    LOGITECH G5
    LOGITECH WAVE USB
    4MB
Hi Wizkid,
Certainly doesn't sound Normal, you could try letting it completely drain and then charging for a good twelve hours without use and see if that improves matters.to be honest though I may well be on it's way out
    2 x 1920x1080 @50Hz
    Asus M5A78L-M USB3
    Samsung 32" TV
