Hi folks. I started having problems with not being able to get the drop-down menus when clicking on the arrows then not being able to pull down or scroll down pages. Then yesterday three crashes with blue screen. Should I eliminate the mini-dump files which it says explain the problem?
C:\Windows\Minidump\Mini053011-03.dmp
Or these files?
AppData\Local\Temp\WER-67049-0.sysdata.xml
AppData\Local\Temp\WERE040.tmp.version.txt
I also cannot run dr web cureit, which I hoped might put me on the right track. When I try, I get another crash.
Thanks for any help.
Or these files?
- hp g60
- amd athlonx2
- 4 gb
- Graphics Card(s)
- nvidia
- 220 gb
