Black screen with mouse cursor
ZK99
I have a laptop with Vista Home Premium 32-bit. I was using chkdisk and now it will not boot anymore. It only goes so far as to have a black screen and a mouse cursor. If I leave it like that it will eventually reboot and then comes back to the black screen with the mouse cursor. I was wondering if it is possible to repair my system without reinstalling the entire operating system. I don't have a CD or DVD, just a recovery partition.
richc46
Welcome
It sounds like you may have a hard drive problem. Can you boot in safe mode?
You can restore the computer but ensure that all data is backed up, also make sure that you run the built-in Diagnostics to check if hardware is running fine.
Madhur B
Dell Social Media Team
Hi ZK99,
As richc46 mentioned boot to safe mode and check if you are able to login to safe mode.
If yes, then try to clean boot to check if would work, providing the link to do a clean boot for reference: How to perform a clean boot to troubleshoot a problem in Windows Vista or Windows 7
If no, run the built-in diagnostics provided by the manufacturer on the computer to check if the hard drive is working fine.
Please post back with the results.
    AMD FX-4100
    Gigabyte
    4Gb
    ATI 5450
    1600*900
    10Mbps
ehjay
I'm going to hijack this post if that's alright.
I'm also having a black screen w/cursor problem. It seems to occur after updating the "Update for Windows Vista (KB27-----)" files. There are 4 of them and all of them cause this problem. Safe mode boots the same way as well. The only option I've found to get things working again is to just restore my computer from before I've updated.
Any solutions at all?
Cheers guys,
Andrew.
Madhur B
    AMD FX-4100
    Gigabyte
    4Gb
    ATI 5450
    1600*900
    10Mbps
ehjay
Hey thanks for the reply. I have once done the statup repair. I think it said there were no errors or something like that.
I think I will just hide the updates. I didn't know you could do that. Thank you for your help.
I've read a lot of people having the black screen issue. What has caused this for people in the past?
Thanks again,
Andrew.
Madhur B
Hi ehjay,
The blinking cursor when the computer starts can happen due to many reasons; one of them could be that updates might cause instability to the Operating System.
Please reply if you have any further questions.
    AMD FX-4100
    Gigabyte
    4Gb
    ATI 5450
    1600*900
    10Mbps
