Blue Screen help.
A
Advice Pro
When I got my blue screen today I wasn't able to write down any of the message and I forgot to use the Event Viewer. there was a pop-up that read:
Code:
Problem signature:
  Problem Event Name:    BlueScreen
  OS Version:    6.0.6002.2.2.0.768.3
  Locale ID:    1033
Additional information about the problem:
  BCCode:    4e
  BCP1:    0000008D
  BCP2:    00010004
  BCP3:    05420000
  BCP4:    A5CBA578
  OS Version:    6_0_6002
  Service Pack:    2_0
  Product:    768_1
Files that help describe the problem:
  C:\Windows\Minidump\Mini022815-01.dmp
  C:\Users\Luis\AppData\Local\Temp\WER-45146-0.sysdata.xml
  C:\Users\Luis\AppData\Local\Temp\WERE2EE.tmp.version.txt
Read our privacy statement:
  http://go.microsoft.com/fwlink/?linkid=50163&clcid=0x0409
townsbg
~~тσωηsвg~~
    Windows 7 Pro x64
    Mid 2010 iMac
    Quad core 3.2 Ghz Intel I3
    8 gb
    ATI Radeon HD 5670 512 mb ram
    1920x1080 and 1440x900
    1 TB
    N/A
    Windows 2008 R2 Enterprise
    Compaq Presario SR5350F
    Pentium 2.0 gHZ Dual core E2160
    2 gb
    1440 x 900
    300 GB
A
Advice Pro
I got another BSOD today with an error message reading:
Code:
Microsoft .NET Framework
Unhandled exception has occurred in your application. If you click
Continue, the application will ignore this error and attempt to continue. If
you click Quit, the application will close immediately.
The process cannot access the file 'C:\Windows\EventSys.txt' because
it is being used by another process.
And the Details:
Code:
See the end of this message for details on invoking
just-in-time (JIT) debugging instead of this dialog box.
************** Exception Text **************
System.IO.IOException: The process cannot access the file 'C:\Windows\EventSys.txt' because it is being used by another process.
   at System.IO.__Error.WinIOError(Int32 errorCode, String maybeFullPath)
   at System.IO.File.Delete(String path)
   at Microsoft.VisualBasic.FileIO.FileSystem.DeleteFileInternal(String file, UIOptionInternal showUI, RecycleOption recycle, UICancelOption onUserCancel)
   at Microsoft.VisualBasic.MyServices.FileSystemProxy.DeleteFile(String file)
   at SF_Diagnostic_Tool.Form1.Button1_Click(Object sender, EventArgs e)
   at System.Windows.Forms.Control.OnClick(EventArgs e)
   at System.Windows.Forms.Button.OnClick(EventArgs e)
   at System.Windows.Forms.Button.OnMouseUp(MouseEventArgs mevent)
   at System.Windows.Forms.Control.WmMouseUp(Message& m, MouseButtons button, Int32 clicks)
   at System.Windows.Forms.Control.WndProc(Message& m)
   at System.Windows.Forms.ButtonBase.WndProc(Message& m)
   at System.Windows.Forms.Button.WndProc(Message& m)
   at System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m)
   at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m)
   at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
************** Loaded Assemblies **************
mscorlib
    Assembly Version: 2.0.0.0
    Win32 Version: 2.0.50727.4253 (VistaSP2GDR.050727-4200)
    CodeBase: file:///C:/Windows/Microsoft.NET/Framework/v2.0.50727/mscorlib.dll
SF Diagnostic Tool
    Assembly Version: 5.0.0.6
    Win32 Version: 5.0.0.6
    CodeBase: file:///C:/Users/Luis/Downloads/SF_Diagnostic_Tool/SF_Diagnostic_Tool.exe
    Assembly Version: 8.0.0.0
    Win32 Version: 8.0.50727.4252 (VistaSP2GDR.050727-4200)
    CodeBase: file:///C:/Windows/assembly/GAC_MSIL/Microsoft.VisualBasic/8.0.0.0__b03f5f7f11d50a3a/Microsoft.VisualBasic.dll
System
    CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System/2.0.0.0__b77a5c561934e089/System.dll
    Win32 Version: 2.0.50727.4252 (VistaSP2GDR.050727-4200)
    CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Windows.Forms/2.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
System.Drawing
    CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Drawing/2.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
System.Runtime.Remoting
    Win32 Version: 2.0.50727.4255 (VistaSP2GDR.050727-4200)
    CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Runtime.Remoting/2.0.0.0__b77a5c561934e089/System.Runtime.Remoting.dll
************** JIT Debugging **************
To enable just-in-time (JIT) debugging, the .config file for this
application or computer (machine.config) must have the
jitDebugging value set in the system.windows.forms section.
The application must also be compiled with debugging
enabled.
For example:
<configuration>
    <system.windows.forms jitDebugging="true" />
</configuration>
When JIT debugging is enabled, any unhandled exception
will be sent to the JIT debugger registered on the computer
rather than be handled by this dialog box.
z3r010
Staff member
Not much can be done without the dump files etc, I've updated the posting instructions to use the file collection tool we use on all the other sites, try that and see if you can get the stuff needed for debugging - Blue Screen of Death (BSOD) Posting Instructions
    Windows 10
    me
    Asus RAMPAGE V EXTREME
    Creative
    6 @ 2560x1440
    3x 1TB Samsung Evo 840's
    1500W ThermalTake Toughpower
    ThermalTake Level 10 GT
    Enermax Liqtech 240
    Logitech Performance MX
    Surface Ergonomic
    350 Mb/s
    WinTV NovaTD
    HP CP1515n Color Laser
    Microsoft LifeCam Cinema
    APC 750i Smart UPS
    windows 10
    Surface Pro 3
    Intel HD Graphics 4400
    12" Multi Touch
    2160 x 144
    128GB
    yes
    350 Mb/s
A
Advice Pro
There is a problem with attaching. I cannot attach via the Manage Attachments button and I can attach pictures with the paperclip button in the editor.
richc46
I think that I resolved your problem in the other thread that you posted regarding this question.
richc46
Glad that I could help. Be patient, you will be helped with your BSODs
richc46
Let me get you started. I looked at your files. Initially, it looks most likely like a driver. Enable the driver verifier. You will get BSODs, just give us the reports. Give us a total of 3. Verifier works the same in Vista as it does in Seven
Driver Verifier - Enable and Disable - Windows 7 Help Forums
richc46
I used the reports that I pointed out to you when you were posting in the other thread.
richc46
A
Advice Pro
Did you find out anything? If you didn't then I'll just download VirusTotal to scan all running processes.
richc46
I did not do anything since we last spoke. You were suppose to run driver verifier and give us the dmp reports.
richc46
While running the verifier, when you get 3 or 4 BSODs give us the reports with the SF Tool
