BSOD 124 and 101
ilikefree
    Lenovo Thinkpad T400
    LENOVO 64734VM
    Conexant 20561 SmartAudio HD
    15 inch
    1x 180GB Intel 530 series SSD
    1 x 120GB Hitachi 5400rmp
    Medium for New Zealand
    Only ever used a laptop.
    Also use USB Freeview TV Card
    Lenovo Docking Station
    External Speakers
    Other bits a pieces as needed
Lottiemansion
Your file indicates a hardware issue but not what type or device.
What other issues have you suffered from? Any help you can give me would help you too..
Probably caused by : hardware
Followup: MachineOwne
    HP-Pavilion m9280.uk-a
    ASUS NVIDIA Geforce GTS450
    HP w2408 24.0" (Dual monitor)
    1920 * 1200, 1920 * 1200
    BluRay & DVD Weiters
    40 Meg
julobaco
Thank you for looking at it. Basically BSOD will show randomly when you boot to the windows. The strange thing is that in safe mode Windows working OK. I thought there will be problem with drivers and not hardware. Because it is laptop I don't many options how test each component :( What I can test is RAM and HDD with Hirens boot CD which I have.
Do you have any other ideas?
Thank you.
Lottiemansion
As one of your older crashes refers to CLASSPNP.SYS, try the solution below: -
Go into your bios and check the hard drive configuration. Once I reverted back to IDE the system booted as normal. You may have to do the opposite!!! At all times my system hung at classpnp.sys as advertised. Let me know if this fixed
From here
Answers.microsoft.com/en-us/windows/forum
    40 Meg
julobaco
The BIOS in this laptop is very basic. I don't have option to change anything except boot priority and few settings like disable Wi-Fi... I am testing RAM with Memtest86+ now and no errors yet... I will let you know.
Lottiemansion
Hi again,
Can you let me know the make & model of the laptop for investigation purposes?
    40 Meg
axe0
BSOD Kernel Dump Analyst
Power User
The make and model: FUJITSU SIEMENS AMILO Pi 3525
If Daemon Tools is a requirement, follow below but skip the Daemon tools removal part.
Please follow everything below if Daemon tools is not a requirement.
Daemon tools, Alcohol 120% and Power Archiver Pro uses SCSI Pass Through Direct (SPTD), which is a well known cause for BSOD's.Please remove Daemon Tools and run the SPTD pass through remover.
  1. Uninstall Daemon Tools
  2. Download the SPTD standalone installer and follow these steps:
    • Double click the executable to open it
    • Click on the button shown below
If the button is grayed out, like in the image, there is no more SPTD installation on your system, and you can close the window
    Dell Inspiron 15R 5521
    Intel(R) Core(TM) i7-3537U CPU @ 2.00GHz
    Dell Inc. 0C46Y8 (U3E1)
    8192MB (2X4096) 1600MHZ DDR3 (11-11-11-28)
    Intel(R) HD Graphics 4000
    Generic PnP Monitor
    1366x768
    Primair Crucial MX200 250GB SATA III 6.0Gbps
    Secundair ST1000LM024 HN-M101MBB 1TB SATA II 3.0Gbps
    Sharkoon FireGlider
    Creative Sound Blaster Tactic3D Rage V2 headset
    Bitdefender Total Security 2016
julobaco
Hi guys, sorry for delay with posting update. After 2 tests which were passed (RAM and HDD) I decided to update BIOS from 1.04 to 1.10 and it seems there are no more BSOD... I have also returned this laptop to owner and we will see if BSOD was definitely solved with BIOS update. Thank you guys.
