For about the past 3 weeks my computer has been crashing. it started first that my computer would go black with random lines down the screen and then do nothing and sit like that until i unplugged the power and then it turned into bsod's. I was told it was most likely a ram issue so i purchased new ram and now my computer doesn't do the line issue, but i still get constant BSOD's. I've run multiple virus checking things with AVG and it finds the same issues every time, these 2 trojans. it says they are removed, but then i restart the computer as prompted, and run the scan again and they are still there. used windows malware removal tool as well and it found the same trojans and said it fixed them and after restarting as prompted, again they are still there. If it is these trojans causing the issue, how do i get rid of them??? Please help. Here is the grab all asked for. Windows vista x64.
Edit: Sorry i thought i had attached it --> View attachment 27780
- Q6600 Intel quad core
- GA-EP45-DS3L
- 4gb of crucial memory
- Graphics Card(s)
- AMD 6700 HD
