Just started getting BSOD this week 2x while playing a game and one just on a website. i have vista home 64 bit. Posting log of dumps now, thx for the help.View attachment 27927View attachment 27926
well the only software that i used that caused a bsod with the verifier on was peerblocker, does this mean it caused the 3 bsod's or something in windows? Peerblocker was fully updated.
there was no event in windows "problems and solutions" for the bsod or even a code when the bsod happened, it just said stuff about the driver. its still the same 3 events from the sf tool.
yes bsod happened 2x, i read it , just had stuff about bad or unlicensed driver. i had to power down to restart. Once it happened i restarted and ran peerblocker again and it bsod'ed again
Well if you are certain that it happens only with peerblocker, the reports would show a peerblocker driver. Go to the peeerblocker website and update the driver. If that does not work you must uninstall peerblocker. That is the advice that I would give if the report showed peerblocker as the cause.
