Bsod ~ IRQL Not less or Equal
Neos
1
Hey Yall
I can't seem to figure this one out. Usually the stop error ends in 0a, but occasionally it ends in 1e.
Never refers to any system files just says IRQL Not Less or Equal.
I'm using Vista x64 OEM, never been reinstalled, computer is about 16 months old.
Thanks for any help you can provide!
kesume
1,316
Location
Lake District, England
Hi welcome to the forum.
Owing to the nature of your problems
I will request that one of our specialists have a look at your problem.
They are busy, and due to different time zones they are not always readily available.
However, I would ask you to be patient & one will attend as soon as practical. Thank you.
Meanwhile would you download this link, the expert may require you to upload reports for analysis.
Those that can help will need the information that is outlined here,
Blue Screen of Death (BSOD) Posting Instructions
If you can include that info in your next post, they will be able to read it and offer you some help.
Thank you
http://www.vistax64.com/crashes-debugging/282419-blue-screen-death-bsod-posting-instructions.html
    Hewlett-Packard SR5019UK
    M2N68-LA (Narra)
    2.50GB
    nVidia GeForce
    Realtec ALC888 Audio
    17" LCD Monitor
    160 Gb Usable Hard Drive
americancritic
1,554
Location
Arizona
    a6530f Desktop
    HP-PAVILION
    M2N68-LA (Narra3)
    LG W40 series widescreen
    1600 X 900
    300W
    Mid-Size ATX
    Microsoft Wireless Mouse 5000
    HP Multimedia Keyboard
    Processor: AMD Phenom X3 8450 Operating speed: Up to 2.1 GHz, Number of cores: 3, Socket: AM2+, Bus speed: 3600 MHz HT3 (clocked down to 2000 MHz)
    Modem: 56K WinModem/
    Supermulti: 16X DVD(+/-)R/RW 12X Ram (+/-)R DL Lightscribe SATA Drive
    Menory Card Reader: 15-in-1 Multimedia Card Reader
    Media Drive
390
Location
Rednecksville
Hello,
It seems there is a little bit of OS corruption here; the NT Kernel is corrupted:
Code:
Sys?            Thu Oct 14 11:53:03 2010 (4CB7275F)
Start off right away with some hardware tests.
Run the three Prime95 tests first: CPU - Stress Test with Prime95 - Windows 7 Forums
Also run Memtest86: RAM - Test with Memtest86+ - Windows 7 Forums
The Intel graphics adapter drivers were blamed once; regardless of whether they are actually at fault or not, it won't hurt to update them: Intel® Driver Update Utility
Code:
igdkmd64.sys    Wed Aug 25 15:35:58 2010 (4C75709E)
If the hardware tests come back clean, run driver verifier: Driver Verifier - Enable and Disable - Windows 7 Forums
...Summary of the dumps:
Code:
[font=lucida console]
Built by: 6002.18327.amd64fre.vistasp2_gdr.101014-0432
Debug session time: Wed Apr  6 21:38:19.164 2011 (UTC - 4:00)
System Uptime: 0 days 0:15:48.809
Probably caused by : win32k.sys ( win32k!NtGdiCloseProcess+1fb )
DEFAULT_BUCKET_ID:  COMMON_SYSTEM_FAULT
BUGCHECK_STR:  0xA
PROCESS_NAME:  lpremove.exe
FAILURE_BUCKET_ID:  X64_0xA_win32k!NtGdiCloseProcess+1fb
SystemProductName = Inspiron 537
Debug session time: Wed Apr  6 21:21:35.368 2011 (UTC - 4:00)
System Uptime: 0 days 0:00:57.962
Probably caused by : ntkrnlmp.exe ( nt!KiUnwaitThread+2d )
BUGCHECK_STR:  0x1E_c0000005
PROCESS_NAME:  verclsid.exe
FAILURE_BUCKET_ID:  X64_0x1E_c0000005_nt!KiUnwaitThread+2d
Debug session time: Wed Apr  6 21:19:42.844 2011 (UTC - 4:00)
System Uptime: 0 days 0:02:33.577
BUGCHECK_STR:  0xA
PROCESS_NAME:  wow_helper.exe
Debug session time: Wed Apr  6 21:16:11.311 2011 (UTC - 4:00)
System Uptime: 0 days 0:07:39.059
BUGCHECK_STR:  0xA
FAILURE_BUCKET_ID:  X64_0xA_nt!KiUnwaitThread+2d
Debug session time: Wed Apr  6 21:07:38.191 2011 (UTC - 4:00)
System Uptime: 0 days 0:03:05.894
*** WARNING: Unable to verify timestamp for MpFilter.sys
*** ERROR: Module load completed but symbols could not be loaded for MpFilter.sys
Probably caused by : MpFilter.sys ( MpFilter+1a6fa )
BUGCHECK_STR:  0x3B
PROCESS_NAME:  mscorsvw.exe
FAILURE_BUCKET_ID:  X64_0x3B_MpFilter+1a6fa
Debug session time: Wed Apr  6 21:03:35.490 2011 (UTC - 4:00)
System Uptime: 0 days 0:30:33.321
Probably caused by : ntkrnlmp.exe ( nt!ObpIncrementHandleCount+6c3 )
BUGCHECK_STR:  0x3B
FAILURE_BUCKET_ID:  X64_0x3B_nt!ObpIncrementHandleCount+6c3
Debug session time: Wed Apr  6 20:31:59.703 2011 (UTC - 4:00)
System Uptime: 0 days 0:00:53.406
Probably caused by : win32k.sys ( win32k!MultiUserGreCleanupHmgOwnRemoveAllLocks+85 )
BUGCHECK_STR:  0xA
FAILURE_BUCKET_ID:  X64_0xA_win32k!MultiUserGreCleanupHmgOwnRemoveAllLocks+85
Debug session time: Wed Apr  6 20:30:04.731 2011 (UTC - 4:00)
System Uptime: 0 days 0:03:20.479
*** ERROR: Symbol file could not be found.  Defaulted to export symbols for msrpc.sys -
Probably caused by : msrpc.sys ( msrpc!I_RpcFreePipeBuffer+bff0 )
BUGCHECK_STR:  0xA
FAILURE_BUCKET_ID:  X64_0xA_msrpc!I_RpcFreePipeBuffer+bff0
*** WARNING: Unable to verify timestamp for Sys?
*** ERROR: Module load completed but symbols could not be loaded for Sys?
Debug session time: Wed Apr  6 20:25:34.610 2011 (UTC - 4:00)
System Uptime: 0 days 0:12:15.367
Probably caused by : Sys? ( nt+5a490 )
BUGCHECK_STR:  0x19_22
Debug session time: Wed Apr  6 20:12:23.843 2011 (UTC - 4:00)
System Uptime: 0 days 0:00:44.546
Probably caused by : win32k.sys ( win32k!HmgNextOwned+83 )
BUGCHECK_STR:  0xA
FAILURE_BUCKET_ID:  X64_0xA_win32k!HmgNextOwned+83
Debug session time: Wed Apr  6 19:52:03.290 2011 (UTC - 4:00)
System Uptime: 0 days 0:01:29.993
Probably caused by : ntkrnlmp.exe ( nt!KiPageFault+20b )
BUGCHECK_STR:  0xA
PROCESS_NAME:  wmpnscfg.exe
FAILURE_BUCKET_ID:  X64_0xA_nt!KiPageFault+20b
Debug session time: Wed Apr  6 19:49:33.348 2011 (UTC - 4:00)
System Uptime: 0 days 0:14:25.108
BUGCHECK_STR:  0xA
PROCESS_NAME:  wermgr.exe
Debug session time: Wed Apr  6 19:08:38.273 2011 (UTC - 4:00)
System Uptime: 0 days 0:02:49.976
Probably caused by : ntkrnlmp.exe ( nt!KeInsertQueueApc+a3 )
FAILURE_BUCKET_ID:  X64_0x1E_c0000005_nt!KeInsertQueueApc+a3
Debug session time: Wed Apr  6 19:04:52.258 2011 (UTC - 4:00)
System Uptime: 0 days 0:03:15.961
Probably caused by : ntkrnlmp.exe ( nt!KeStackAttachProcess+1df )
BUGCHECK_STR:  0x1E_c0000096
FAILURE_BUCKET_ID:  X64_0x1E_c0000096_nt!KeStackAttachProcess+1df
Debug session time: Wed Apr  6 19:00:34.153 2011 (UTC - 4:00)
System Uptime: 0 days 9:21:01.648
Probably caused by : ntkrnlmp.exe ( nt!KiApcInterrupt+1f3 )
FAILURE_BUCKET_ID:  X64_0x1E_c0000005_nt!KiApcInterrupt+1f3
Debug session time: Wed Apr  6 09:38:34.955 2011 (UTC - 4:00)
System Uptime: 0 days 0:10:43.709
Probably caused by : ntkrnlmp.exe ( nt!ObpDecrementHandleCount+81 )
BUGCHECK_STR:  0x3B
PROCESS_NAME:  MpCmdRun.exe
FAILURE_BUCKET_ID:  X64_0x3B_nt!ObpDecrementHandleCount+81
Debug session time: Wed Apr  6 09:26:54.715 2011 (UTC - 4:00)
System Uptime: 0 days 0:04:15.251
Probably caused by : ntkrnlmp.exe ( nt!KiUnwaitThread+19 )
BUGCHECK_STR:  0xA
FAILURE_BUCKET_ID:  X64_0xA_nt!KiUnwaitThread+19
Debug session time: Wed Apr  6 09:21:09.923 2011 (UTC - 4:00)
System Uptime: 0 days 6:33:09.542
BUGCHECK_STR:  0xA
PROCESS_NAME:  WerFault.exe
Debug session time: Wed Apr  6 02:46:12.935 2011 (UTC - 4:00)
System Uptime: 0 days 0:03:02.622
BUGCHECK_STR:  0xA
Debug session time: Wed Apr  6 02:41:20.589 2011 (UTC - 4:00)
System Uptime: 0 days 0:03:52.167
BUGCHECK_STR:  0xA
Debug session time: Wed Apr  6 02:35:41.464 2011 (UTC - 4:00)
BUGCHECK_STR:  0xA
Debug session time: Wed Apr  6 02:29:56.694 2011 (UTC - 4:00)
System Uptime: 0 days 0:56:20.432
*** WARNING: Unable to verify timestamp for igdkmd64.sys
*** ERROR: Module load completed but symbols could not be loaded for igdkmd64.sys
Probably caused by : igdkmd64.sys ( igdkmd64+5726c )
BUGCHECK_STR:  0xA
FAILURE_BUCKET_ID:  X64_0xA_igdkmd64+5726c
Debug session time: Wed Apr  6 01:31:44.448 2011 (UTC - 4:00)
System Uptime: 0 days 0:11:40.152
Probably caused by : win32k.sys ( win32k!MultiUserGreCleanupHmgOwnRemoveAllLocks+65 )
BUGCHECK_STR:  0x7f_8
PROCESS_NAME:  NIS_Delta_Patch
FAILURE_BUCKET_ID:  X64_0x7f_8_win32k!MultiUserGreCleanupHmgOwnRemoveAllLocks+65
Debug session time: Wed Apr  6 01:18:42.674 2011 (UTC - 4:00)
System Uptime: 0 days 0:02:49.377
Probably caused by : ntkrnlmp.exe ( nt!KiSwapContext+e8 )
PROCESS_NAME:  igfxsrvc.exe
FAILURE_BUCKET_ID:  X64_0x1E_c0000005_nt!KiSwapContext+e8
Debug session time: Wed Apr  6 01:07:17.884 2011 (UTC - 4:00)
System Uptime: 0 days 0:01:07.462
BUGCHECK_STR:  0xA
PROCESS_NAME:  AtBroker.exe
Debug session time: Wed Apr  6 01:01:59.836 2011 (UTC - 4:00)
System Uptime: 0 days 0:01:55.461
Probably caused by : win32k.sys ( win32k!HmgFree+10a )
BUGCHECK_STR:  0xD3
FAILURE_BUCKET_ID:  X64_0xD3_win32k!HmgFree+10a
Debug session time: Wed Apr  6 00:58:16.141 2011 (UTC - 4:00)
System Uptime: 0 days 0:01:03.719
DEFAULT_BUCKET_ID:  VISTA_DRIVER_FAULT
BUGCHECK_STR:  0xA
Debug session time: Wed Apr  6 00:55:48.966 2011 (UTC - 4:00)
System Uptime: 0 days 0:03:21.698
*** WARNING: Unable to verify timestamp for ataport.SYS
*** ERROR: Module load completed but symbols could not be loaded for ataport.SYS
Probably caused by : ataport.SYS ( ataport+6a98 )
BUGCHECK_STR:  0xA
PROCESS_NAME:  svchost.exe
FAILURE_BUCKET_ID:  X64_0xA_ataport+6a98
Debug session time: Wed Apr  6 00:51:04.174 2011 (UTC - 4:00)
System Uptime: 0 days 0:01:11.877
Probably caused by : win32k.sys ( win32k!HmgNextOwned+5d )
BUGCHECK_STR:  0xA
FAILURE_BUCKET_ID:  X64_0xA_win32k!HmgNextOwned+5d
Debug session time: Tue Apr  5 22:47:34.461 2011 (UTC - 4:00)
System Uptime: 0 days 0:05:24.161
PROCESS_NAME:  control.exe
FAILURE_BUCKET_ID:  X64_0x1E_c0000005_nt!ObpDecrementHandleCount+81
Debug session time: Tue Apr  5 22:40:23.289 2011 (UTC - 4:00)
System Uptime: 0 days 0:01:27.992
Probably caused by : win32k.sys ( win32k!HmgFree+92 )
BUGCHECK_STR:  0xA
FAILURE_BUCKET_ID:  X64_0xA_win32k!HmgFree+92
Debug session time: Tue Apr  5 22:37:19.173 2011 (UTC - 4:00)
System Uptime: 0 days 0:05:29.875
Probably caused by : ntkrnlmp.exe ( nt!ObpCreateUnnamedHandle+122 )
PROCESS_NAME:  dllhost.exe
FAILURE_BUCKET_ID:  X64_0x1E_c0000005_nt!ObpCreateUnnamedHandle+122
Debug session time: Tue Apr  5 22:18:32.455 2011 (UTC - 4:00)
System Uptime: 0 days 0:02:01.158
Probably caused by : ntkrnlmp.exe ( nt!KiChainedDispatch+289 )
FAILURE_BUCKET_ID:  X64_0x1E_c0000005_nt!KiChainedDispatch+289
[/font]
    Jonathan King
    AMD Athlon Dual Core Processor 4850e overclocked @ 2.92 GHz
    ASRock A780 FullDisplayPort
    6.0GB Dual-Channel DDR2 290MHz Crucial Technology
    ATI 3200 (onboard), nVidia 7200 GS (PCIe)
    17" Cybervison ds69T, 17" Starlogic
    1024x768
    WD 320GB SATA, Hitachi 1TB SATA
    Antec ea-430d 430W
    Antec 300
    stock cpu, 120mm rear, 140mm top
    Microsoft Wired Desktop 500 (USB)
    Microsoft Wired Desktop 500 (PS/2)
    9.32 Mb/s download; 0.36 Mb/s upload
    Other OS's:
    Windows 7 Professional x64, Windows Professional x86, Ubuntu x64
