Solved Bsod irql_not_less_or_equal
4
Vista 32 - Just got the BSOD IRQL_NOT_LESS_OR_EQUAL. Any ideas on how to correct this would be greatly appreciated. Thanks
    HP Pavillion a6400f PC
    Intel Dual Core Desktop Processor E2200
    Unknown
    Unknown
    Unknown
    Staples 22 inch
4
Thanks for the reply. I did run that program and attached it to my original message. Let me know if that doesn't show up. Thanks again.
    Unknown
    Unknown
    Unknown
    Staples 22 inch
Lottiemansion
1,948
Location
Sheffield
You have posted the "Run file" & not the resultant "Zip file".
Please run it again as directed & post the results. OK?
    HP-Pavilion m9280.uk-a
    ASUS NVIDIA Geforce GTS450
    HP w2408 24.0" (Dual monitor)
    1920 * 1200, 1920 * 1200
    BluRay & DVD Weiters
    40 Meg
4
Thanks for the direction....It may be fixed.....I thouroughly cleaned the inside of the PC this morning, fans, boards, GPU etc. an the system has been stable ever since. It had been crashing every hour or so. I will give it until tomorrow before I mark as resolved and if it crashes again I will rerun the program as you suggested. Thanks again.
    Unknown
    Unknown
    Unknown
    Staples 22 inch
4
The cleaning seems to have fixed the problem...Thanks All
    Unknown
    Unknown
    Unknown
    Staples 22 inch
oe812
1
#8
New to this forum. All else failed to resolve my BSOD. The error messages are:
Error Dialog Box stated the following:
Prob event BLUESCREEN
OS version 6.0.6002.2.2.0.768.3
Locale ID 1033
BC Code a
Can not resolve this. Any suggestions.
    Sony Vaio
usasma
Old and cranky
1,364
Location
Southeastern CT, USA
#9
4
#10
I have this error on startup on a computer I'm working on... I cannot get the error information (It requires Windows to run, and the computer hits the error on the initial load then resets), and it is happening even with a complete hard drive wipe...is there any way I can get a solution?
    E-machines
    Pentium 4 3.0
    1 GB
    Intel GMA 950
    Sigmatel AC '97
    19"
    160 GB SATA
    Small tower
    6 MBPS
