BSOD while installing Vista x64
Sonic81
Hello,
I'm getting BSOD while trying to install Vista x64 on my system with a USB stick, my drive partition is on GPT with UEFI enabled, I'm able to install Windows 7 and 8 x64 edition successfully without any error, can anybody help in this, PFA screenshot for the error.
    Assembled
    Intel-i5
    Gigabyte Z77-UD3H
    Coarsair Vengence 1600 MHZ 16GB
    Nvidia 9800 GT
    Creative Sound Blaster X-Fi Titanium Fatal1ty Professional
    Dell U3011
    2560x1600
    SATA II 500GB
    SATA II 2TB
    Cooler Master Silent Pro 700W
    Cooler Master HAF 912
    8 MBPS
Cytherian
You have a self-assembled system... Vista may be having trouble with one of your hardware components. This was an issue before the service pack update (see MS support issue, and stop errors). Or it's possible you may have one or more corrupt files in your installation software. You might want to try downloading the Vista ISO and burn to a DVD.
    HP Pavillion dv5t
    Intel Core Duo 2.53GHz
    4Gb
    NVidia GeForce 9600M GT 512Mb
    1280x800 32bit
    Seagate Momentus XT 500Gb
    Hitachi Travelstar HTS543225L9A300 250Gb
    Microsoft 4000
Sonic81
i'm using the Orignal ISO image downloded from MSDN, my DVD Rom drive does not detects as i'm on UEFI with GPT partition, if i disable UEFI then i can successfully install vista, there is some issue Vista is not supporting UEFI i guess.
    Assembled
    Intel-i5
    Gigabyte Z77-UD3H
    Nvidia 9800 GT
    Dell U3011
    2560x1600
    SATA II 500GB
    SATA II 2TB
    8 MBPS
Cytherian
^ Quite possible about the UEFI incompatibility... but then it's probably OK with SP1 or SP2. If not, that would be a major sore thumb for Vista.
    HP Pavillion dv5t
    4Gb
    1280x800 32bit
    Microsoft 4000
virtual6
Vista Pro
Wow, old thread resurrection!
Unfortunately, like quite a few posters seeking solutions, the OP never reported back.
Microsoft initiated support of UEFI boot on x64 systems with Windows Vista SP1.
What is your installation media?
