BSOD with fresh vista install...
vivendi
Hey, i have this strange problem. I installed Vista 32bit Business Edition (legit version, just for the record) on my Toshiba Satellite laptop.
Everything seems fine after the installation is done. I can use my desktop etc. No problems at all.
The first thing i did was installing the Windows updates so i get all the latest patches and drivers for my laptop.
There is a first group of ~72 updates Vsita downloads and installs and after that it requires a reboot. So i rebooted my computer to finish the updates but that's when the trouble begins.
I get to the part where you see the green processbar, loading my OS, but after that i quickly get a BSOD and then my computer reboots... The BSOD just stays up for less than a second, so it's impossible to see the error message and then my machine reboots. And this happends over and over again...
I've also tried to format and reinstall everything again. But the same thing happend to me... I have no idea why and what is causing this problem... Cause it always worked before...
Do you guys have any idea what the problem could be...???
pooch
Old Dog
Hi Vivendi,
Welcome to the forum.
Is your install disc complete with SP1? If not have a look here;
http://www.vistax64.com/tutorials/151606-vista-sp1-slipstream-installation-dvd.html
This will show you how to make a DVD with SP1 incorporated which you should then use to install Vista
I hope this helps
Pooch
    Self build
    Asus M3A32-MVP Deluxe
    8 gig Samsung PC800 RAM
    NVidia 9600gt
    AD1988b
    1680 : 1050 1280 : 1024
    Drive #1 - SAMSUNG HD252HJ (250 GB)
    Drive #2 - Hitachi HDT721010SLA360 (1000 GB)
    Drive #3 - SAMSUNG HD250HJ (250 GB)
    Drive #4 - SAMSUNG HD103UJ (1000 GB) External eSATA
    Enermax Chakra
    Easy Line Laser Mouse
    Standard
    I have also used Fedora, Suse, Ubuntu Linux
    And all other Windows from 95 to date except ME
