can no longer clear super cookies
pacinitaly
HappyGuru Lovin2Help
thanks Rich,
I have used such.
have you clicked the URL I supplied and see the choices?
that's what I'm missing
richc46
I was wondering why you are missing the choices. Have you tested with another Browser? Have you tried removing the addons from the browser. In IE, Tools, Internet Option. Advanced Reset. This will remove addons which can be replaced as needed.
Have you tried in another user account?
Have you made a full antivirus scan and the same with malwarebytes?
How about a system restore from before the problem?
pacinitaly
I was wondering why you are missing the choices. Have you tested with another Browser? yes
Have you tried removing the addons from the browser. In IE, Tools, Internet Option. Advanced Reset.no I don't want to lose all my search providers This will remove addons which can be replaced as needed.
Have you tried in another user account? no
Have you made a full antivirus scan and the same with malwarebytes? 3x
How about a system restore from before the problem? 3 different days.
I also dont want to use a cloned drive because it's 3weeks old
thanks again Rich.
as you can see, I can see the image using a portable IE8 browser.
