Can only use IE and non web based programs
Jageraid
:pHello I am currently having issues with useing anything web base games or google chrome. But IE works and I can use the internet with that. I have flush my IP and DNS but that didnt fix anything.
Error 2 (net::ERR_FAILED): Unknown error.
That is the message I get when I try to use google chrome.
If I try starting up League of Legends or World of Warcraft I get this message
(Could not connect to the HTTP server. Please check that your internet connections is enable and that your firewall is not blacking access.
I dont run a fire wall
I have ventrillo and IE working for internet right now.
Anything that has a web based application will say that it is not connected to the internet.
Also I am sure I have the last IE installed.
    AMD Phenom 2 x4 810 2611 MHz
    Gigabyte
    8189 MB GSkill
    Nvidia GeForce GTX 260
Jageraid
Update:
I currently uninstalled the latest Internet Explorer and went to the one I had before. Still have same issue.
    Gigabyte
    8189 MB GSkill
Yard Dog
Run full scan ( updated definition base ) of your anti virus program and then run full scan of free version of malwarebytes antimalware, using latest version and updated data base.. We want to rule out a virus or malware issue . Post back how that goes please.
    Emachine ET 1161-05
    AMD Athlon 64 LE-1640
    Acer E181H ([email protected]) 128MB GeForce 6150SE nForce 430 (
    1280x768 pixels
    ST316081 5AS SCSI Disk Device
    Tower
    Fan Speed 1247 RPM
    PS/2 Compatible Mouse
Jageraid
Hello Yard Dog, and thank you for the reply.
Currently Running- Trend Micro House call
-Lava Soft Ad Aware
-And Malwarebytes Anti Malware
I will reply once they are completed with scanning
    Gigabyte
    8189 MB GSkill
Yard Dog
Leave results. I will see it later or someone else will continue on with getting you solved and sorted out.
    Emachine ET 1161-05
    1280x768 pixels
    Tower
    Fan Speed 1247 RPM
Jageraid
Malwarebytes found 1 items PUP.CNET.adware
the other 2 are still scanning Ad ware found the issue
iSkipped items:
Description: c:\users\jageraid\downloads\ilividsetupv1 (1).exe Family Name: Win32.PUP.Bandoo[800] Engine: 1 Clean status: Success Item ID: 0 Family ID: 0 MD5: 76b65d5b9b8e68d2ac9e8c0fb12cbd6c
Description: c:\users\jageraid\downloads\ilividsetupv1.exe Family Name: Win32.PUP.Bandoo[800] Engine: 1 Clean status: Success Item ID: 0 Family ID: 0 MD5: 76b65d5b9b8e68d2ac9e8c0fb12cbd6c
Description: HKCR:AppID\GIFAnimator.DLL: Family Name: Win32.PUP.Bandoo Engine: 1 Clean status: Success Item ID: 5367032 Family ID: 5366997
    Gigabyte
    8189 MB GSkill
Yard Dog
    Emachine ET 1161-05
    1280x768 pixels
    Tower
    Fan Speed 1247 RPM
Jageraid
Ok got rid of the other malware via Ad Aware
I did the following SFC and after a restart as well was unable to fix one.
CSI 00000181 [SR] Cannot repair member file [l:22{11}]"CbsCore.dll" of Microsoft-Windows-ServicingStack, Version = 6.0.6002.18005, pA = PROCESSOR_ARCHITECTURE_AMD64 (9), Culture neutral, VersionScope = 1 nonSxS, PublicKeyToken = {l:8 b:31bf3856ad364e35}, Type neutral, TypeName neutral, PublicKey neutral in the store, hash mismatch
2012-04-09 10:36:22, Info CSI 00000183 [SR] Cannot repair member file [l:22{11}]"CbsCore.dll" of Microsoft-Windows-ServicingStack, Version = 6.0.6002.18005, pA = PROCESSOR_ARCHITECTURE_AMD64 (9), Culture neutral, VersionScope = 1 nonSxS, PublicKeyToken = {l:8 b:31bf3856ad364e35}, Type neutral, TypeName neutral, PublicKey neutral in the store, hash mismatc
    Gigabyte
    8189 MB GSkill
Yard Dog
Do you have your Install disk to use to repair that ? reference the tutorial of SFC ? If SFC Cannot Finish or Repair a File:
NOTE: This is for when after you run the SFC scan below, it cannot finish or repair a file. There is no guarantee that SFC can repair the system files if they are corrupted or damaged to much. If SFC still cannot repair them after this, then you might try running Check Disk (chkdsk), System Restore, a Repair Installation, or a clean reinstall of Vista.
Run check disk first please : http://www.vistax64.com/tutorials/67612-check-disk-chkdsk.html
    Emachine ET 1161-05
    1280x768 pixels
    Tower
    Fan Speed 1247 RPM
Jageraid
Going to hit up a clean install problem still here.
    Gigabyte
    8189 MB GSkill
Yard Dog
    Emachine ET 1161-05
    1280x768 pixels
    Tower
    Fan Speed 1247 RPM
Jageraid
Did the clean install full version of vista.
    Gigabyte
    8189 MB GSkill
Yard Dog
How is everything ?
    Emachine ET 1161-05
    1280x768 pixels
    Tower
    Fan Speed 1247 RPM
Yard Dog
A repair install would have been my first preference , but, I am glad to see that you have your machine working as it should. Please feel welcome to visit to learn or to help others and by all means, check out the tutorial section for tips and tricks. http://www.vistax64.com/tutorials/139940-tutorial-index.html?filter[11]=General%20Tips
    Emachine ET 1161-05
    1280x768 pixels
    Tower
    Fan Speed 1247 RPM
Jageraid
Yep thank you very much.
Had this machine since 2009 it needed a fresh install kinda hurt in my school situation but ill be back on track in time thanks for the fast response times and the quick helpful links from the forms .
    Gigabyte
    8189 MB GSkill
Yard Dog
Your most welcome.. all users here are volunteers and all enjoy seeing an issue resolved..
    Emachine ET 1161-05
    1280x768 pixels
    Tower
    Fan Speed 1247 RPM
