cod4 freezing
broot22
hi all pleased to have joined you
this is my spec
1 x 500 GB SATA HDD UDMA 300 7200 16MB
1 x SAMSUNG DVD+/-RW 18x6x18x8 D/LAYER BLACK (IDE)
1 x 10 X USB 2.0 PORTS
1 x SAMSUNG 16x DVD-ROM BLACK (IDE)
1 x ONBOARD 6 CHANNEL 5.1
1 x FAST 10/100 ETHERNET LAN (BROADBAND READY)
1 x THERMALTAKE BLUE ORB II (CL-P0257)
1 x ASUS 768MB NVIDIA GeForce 8800GTX 2xDVI PCI-E SLI
1 x ThermalTake W0116RB 750W TOUGHPOWER CABLE MANAGEMENT BLK RET
1 x ThermalTake CASE SHARK VA7000BWA BLK
1 x ASUS SKT-AM2 M2N32-SLI DELUXE W/L S/L 2000MT/s
1 x GEIL 4GB DDR2 800 CL5.0 DUAL CHANNEL BLACK DRAGON RET
1 x AMD ATHLON 64 X2 6400+ 2MB SKT-AM2 (Black Edition)
the problem is that cod4 freezers i ve installed the patches in order, all drivers are up to date, directx up to date but still it freezers can any 1 help thanx
FightingScallion
Enthusiast
Hmm...I might be able to help out a bit. Can you give me a complete, step-by-step to recreate the problem? When/where does it freeze? Always?
Looks like a pretty decent system, so I doubt that's going to be the issue. But, we'll have to see. My guess is software setting somewhere.
roy69
47,65,65,6B
What other programs are running in the background?
What scheduled task have you got.
Are there anti virus programs running in the background.
Look in your error logs;
Left Click on Start Menu.
Right click on Computer and choose manage.
Click on the event viewer.
You now have loads of options to try and pin down what is happening.
Expand the error tab.
Look for things in the last 24 hours.
Put your system specs in your sig as it will save you having to type it out every time.
    I5 3570K
    Gigabyte Z77-DS3H
    Gigabyte Geforce GTX 660 TI
    creative x-fi
    Both 1680 x 1050
    Technika TKOPTM2
    Logik
    Creative Inspire 7.1 T7900 Speakers
    Trust Graphics Tablet
broot22
checked for the background programs thats fine
it happens just has i start to play after i pick my perks and gun set up
by the time i ve typed hi all the game freezes
its fine on fuels of war and unreal 3
roy69
47,65,65,6B
Have you tried to run it in compatability mode?
It sounds like the main game file may be causeing the problem, however as fightingscallion said it may be a punkbuster issue.
    I5 3570K
    Gigabyte Z77-DS3H
    creative x-fi
    Both 1680 x 1050
    Technika TKOPTM2
    Logik
roy69
47,65,65,6B
Navigate to the exe file and right click --> properties.
The compatability tab will be on the top o the menu about 3 along.
    I5 3570K
    Gigabyte Z77-DS3H
    creative x-fi
    Both 1680 x 1050
    Technika TKOPTM2
    Logik
deltatux
Maybe running the game in Administrator Mode might help. Sometimes Punkbuster gets cranky if it doesn't get admin access.
    AMD Athlon 64 X2 4200+ 2.53GHz
    ASUS M3A AM2+
    4 GB Kingston DDR2-667
    Sapphire ATi Radeon HD 3650
    Hitachi 320 GB SATA HDD w/ 16MB cache
broot22
it is vista compatable so u dont get that option just for older versions of windows thanx any way
deltauk thanx ii noticed admin setting when i lkooked at what roy69 told me to try
so i cliked and tried it
it worked even with macaffe runing virus scan
thanx guys i will try again later tonight when i get back in
deltatux
the admin thingy seems to have done the trick
a big thank u to all that helped me solve this
cheers
No problem, glad it worked. It's usually the solution to most game issues on Vista ... lol =)!
    ASUS M3A AM2+
