Context Menu - Add COPY TO FOLDER and MOVE TO FOLDER
ByLine
How to Add COPY TO FOLDER and MOVE TO FOLDER to the Context Menu in Vista
Synopsis
Copy To Folder allows you to right click on a item and copy it to another location immediately.
Move to Folder allows you to right click on a item and move it to another locatation and remove it from it's current location immediately.
How to Add "Copy To Folder" and "Move To Folder" to the Context Menu in Vista
Copy To Folder allows you to right click on a item and copy it to another location immediately. Move to Folder allows you to right click on a item and move it to another locatation and remove it from it's current location immediately.
This is also under the EDIT menu in a Explorer window. (See Example screenshot below)
EXAMPLE: Default Edit Menu Location:
NOTE: These are the keyboard shortcuts to use the Menu bar location while having the file or folder selected that you want to Copy or Move to another folder.
  • Copy To Folder - Press and hold Alt then press E and F
  • Move To Folder - Press and hold Alt then press E and V
EXAMPLE: Copy To Folder and Move To Folder Added to the Context Menu:
NOTE: Right click on a file or folder to see your new additions. You can see what happens when you click on each one beside the context menu screenshot. You can select a different drive to.
METHOD ONE
Using a REG File Download
1. To Add Copy/Move To Folder
NOTE: You can add one or both of these.​
Add_CopyMove.reg
download
B) Go to step 3.​
2. To Remove Copy/Move To Folder
Remove_CopyMove.reg
download
METHOD TWO
To Do Manually in Registry Editor
1. Open the Start Menu.​
HKEY_CLASSES_ROOT\AllFilesystemObjects\shellex\ContextMenuHandlers
5. To Add Copy To Folder
A) In the left pane, right click on ContextMenuHandlers and click on New and Key.​
B) Type {C2FBB630-2971-11D1-A18C-00C04FD75D13} and press Enter.​
NOTE: To Remove Copy To Folder - Right click on this key and click on Delete.
6. To Add Move To Folder
B) Type {C2FBB631-2971-11D1-A18C-00C04FD75D13} and press Enter.
NOTE: To Remove Move To Folder - Right click on this key and click on Delete.
7. Close regedit.​
Related Tutorials
  • Remove_CopyMove.reg
  • Add_CopyMove.reg
Brink
Staff member
mvp
Your welcome Hgjazz,
Welcome to the forum. :party:
    1TB Samsung 970 EVO Plus M.2,
    250GB Samsung 960 EVO M.2,
    6TB WD Black WD6001FZWX
    Linksys EA9500 router,
    Arris SB8200 cable modem,
    Lumia 1520 phone
Brink
Staff member
mvp
Your welcome Janelte.
    Lumia 1520 phone
Badcam
Thanks Brink. I've been looking for just this very option, as after dabbling in Linux I find it an extremely useful feature. I tried installing using Method 1. It hasn't worked for me, even with a restart. I'm using Vista Home Premium 32bit. What do you suggest I try next to get this working? Method 2?
Brink
Staff member
mvp
Hi Badcam,
It will work for all Vista version. I would go ahead and do Method Two. You can Copy and Paste the codes from the tutorial to make it easier to do.
    Lumia 1520 phone
Brink
Staff member
mvp
Hi Manteca,
The Move To Folder will act the same as Cut To Folder would. It will remove the file or folder from the original location and move it to the folder you selected. ;)
    Lumia 1520 phone
Brink
Staff member
mvp
Your welcome manteca,
Anytime.
    Lumia 1520 phone
Beladan
I registered simply to thank you for this. The reg file merged perfectly with my 32bit version and I have exactly the functionality I was looking for.
Perfection would be if there was a way to finagle the 'send to' function to move by default instead of copying.
Anyway - kind thanks
David
Brink
Staff member
mvp
Your welcome David,
That would be nice.
    Lumia 1520 phone
Brink
Staff member
mvp
Your welcome LengIeng.
    Lumia 1520 phone
Bare Foot Kid
R.I.P. August 13th 2014
Hello Brink,
I thought I had this on my last install but maybe not.
I wanted it back! Method Two was a piece of cake; I did copy/paste the key without incident.
I already used Move To, worked like a charm!
Thanks Shawn.
Later :shock: Ted
    * BFK Customs *
    Intel C2Q 9550 Yorkfield
    ASUS P5Q Pro
    8GB Dominator 8500C5D
    XFX ATI 1GB 4870 XXX
    Realtek HD 7-1
    1920x1080P & 1920x1200
    Corsair 620HX
    CM Cosmos RC-1000
    HP Enhansed Multimedia
    Razer Diamondback 3G
    18.6Mb/s
    My First Build ;)
Brink
Staff member
mvp
Your welcome Ted.
    Lumia 1520 phone
Silent_Guardian
thanks Brink, that link is important..
    Intel 2140 3.2GHz
    Intel (R) 946GZ
    2.0GB
    Intel Graphics Media Acclerato
    160GB
Brink
Staff member
mvp
Your welcome Silent_Guardian.
Thank you,
    Lumia 1520 phone
