Context Menu - Take Ownership
ByLine
How to Add Take Ownership to the Context Menu in Vista
Synopsis
This will show you how to add Take Ownership to the Context (right click) menu for all folders, files, and drives in Vista and Windows 7. This will make it easier to take ownership of items and all subfolders and subfiles in a folder to.
This will add Take Ownership to the Context (right click) menu for all folders, files, and drives in Vista and Windows 7.
Application files, (EX: EXE, CMD, MSI) will still have Run as administrator instead of Take Ownership in the context menu.
When you use take ownership on a folder, it will take ownership of all the files and subfolders inside the folder to.
This Take Ownership context menu item needs to be used while logged on to an administrator account for it work.
EXAMPLE: Before and After Context Menus
STEP ONE
Add or Remove Take Ownership
1. To Add Take Ownership
Add_Take_Ownership.reg
download
B) Go to step 3.​
2. To Remove Take Ownership
Remove_Take_Ownership.reg
download
5. Click on Run, Continue (UAC-Vista) or Yes (UAC-Windows 7), Yes, and OK when prompted.​
After you have taking ownership of the file, you may still need to "Allow" your user account "Full Control" of the file before you will have full permission to access it. See steps 11 to 22 in the tutorial below for how.
STEP TWO
How to Use Take Ownership
1. Right click on a folder, file, or drive.​
NOTE: When you use Take Ownership on a folder, it will take ownership of all the files and subfolders within that folder to.​
Do not take ownership of the drive that you have Windows installed on. If you do, you will end up having to reinstall Windows.
2. Click on Take Ownership. (See Example at top)​
4. You will see a command window pop-up and then go away when it's finished. (See example screenshot below)​
5. The folder or file has been taken ownership of.​
NOTE:
A) You can verify from METHOD TWO step 7 here: How to Take Ownership of a Item in Vista
B) It will have your user name listed as the owner.​
Related Tutorials
  • Add_Take_Ownership.reg
  • Remove_Take_Ownership.reg
Brink
Staff member
mvp
Your welcome Not liking Vista.
Welcome to the forum. :party:
    1TB Samsung 970 EVO Plus M.2,
    250GB Samsung 960 EVO M.2,
    6TB WD Black WD6001FZWX
    Linksys EA9500 router,
    Arris SB8200 cable modem,
    Lumia 1520 phone
Brink
Staff member
mvp
Hi Salpap,
Yeah, this can come in handy if you need to take ownership alot, or need to take ownership of a bunch of sub folders and files.
    Lumia 1520 phone
Clark1221
Does this work for individual files, or just folders?
Example.....I have a back-up (file) of my favorites on a CD/RW disk, and when I wanted to overwrite it with a more recent version, Vista wouldn't let me do it, even with Admin privs.
    Q9550
    EVGA 790i Ultra
    4 gigs Patriot Viper EP @ 1600mhz
    EVGA GTX 280
    X-Fi Fatality Pro
    Samsung 2493 24"
    1900 x 1200
    WD 640g SATA 3.0 16 AAKS
    PC Power & Cooling Silencer 750w Quad SLI
    Antec 900
    Asus Silent Knight 2 CPU
    Logitech G5 Laser
    Saitek Eclipse 2
    Now @ 15mps down
Brink
Staff member
mvp
Hi Clark,
It works for either one. ;)
    Lumia 1520 phone
Thales
Hi Clark,
I'm trying to run an application, and have tried all that I can think of to get permission for it to run a dll, but it continues to tell me I don't have permission. It's my machine, for crying out loud. I'm supposed to not have to ask for permission.
Anyway, I tried the "takeownership" thing, and it tells me I have ownership. When I look at the permissions, it says I have full acess, yet I still can't run the dll.
This is not a system file or directory, it's just a graphics program by Ogre.
Why can't I get permission? This is confusing!
Thanks for any feedback.
Brink
Staff member
mvp
Hi Thales,
Is the program by Ogre compatible with Vista?
You may need to right click the program and use "Run as Administrator" on it to open the .dll file.
    Lumia 1520 phone
Thales
Hi Thales,
Thanks, Shawn.
"Run as Adminstrator" did the trick!
Great!
Brink
Staff member
mvp
Your welcome Thales. Glad to hear that it worked for you. You can check the Run this program as an administrator box in Compatibility mode so you do not have to right click on the Ogre program everytime you want to open it. You can see how here if needed in step 7.
http://www.vistax64.com/tutorials/75909-compatibility-mode.html
    Lumia 1520 phone
Brink
Staff member
mvp
Your welcome taco-man, and welcome to Vista Forums. :party:
I'm glad to hear that it was helpful to you.
    Lumia 1520 phone
sidney1st
For those who don't want the trick on the context menu and find a bit complicated the way to do it manually, they can do it this way:
Copy those 2 lines in notepad and save as for example: takeownership.cmd
Put the file in your windows directory.
takeown /f %1 /r
icacls %1 /grant yourusername:F /t
Now when you want to take ownership of a file or folder, run the command prompt as administrator and type in:
takeownership C:\folder for which you want to take ownership (or file)
If the entry is a folder, you will have ownership on all files within the folder.
Brink
Staff member
mvp
    Lumia 1520 phone
admles
This was fantastic, thanks a lot for this!
    Intel E8400 CPU
    Asus P5N-D
    4gb (2 x 2gb) DDR2
    Gigabyte 1gb 9800GX2
    Sound Blaster F4tal1ty
    Samsung 22" LCD
    1680 x 1050
    1 x 150gb Raptor SATA-2
    2 x 750gb Western Digital SATA-2
    730w Antec TruePower
    CoolerMaster CM690
    Logitech G9 Laser Mouse
    Logitech G15
Brink
Staff member
mvp
Your welcome Admles, and welcome to Vista Forums. :party:
    Lumia 1520 phone
Brink
Staff member
mvp
Hi Bukavu,
What is the name and location of the file that you are trying to delete?
The file may be in use. You might try booting into Safe Mode and see if you can delete it from there. This tutorial will show you how to boot into Safe Mode if needed.
http://www.vistax64.com/tutorials/123496-safe-mode.html
    Lumia 1520 phone
