crysis warhead problem
happyhillbilly
im running 64bit vista and i bought warhead over steam and when i try to play the game it doesn't let me change out of 1024x768 resolution... i can click any other and it will bring up the message asking if i want to keep it and i say yes and it goes right back to 1024... crysis wars goes into the highest resolution fine its just warhead... i have a nvidia 9800 gts so i know it will run it
sygnus21
Here to learn
Hmmm...Have you tried updating your video drivers? And which mode are you playing in - DX9 or 10? Try switching to the other - "Games", right click "Crysis:Warhead", and choose either DX9 or 10. See what happens.
For what its worth, I have a ATI Radeon 4850 on Vista 64 and can run the game just fine @ 1280x1024.
    Intel D975XBX2
    ATI Radeon HD 4890 (1GHz)
    hp w2207h (22" widescreen)
    1680 x 1050
    Antec Neo HE 550
    Antec P182
    Zalman CNPS9500 AT
    Logitech MX Revolution
    Logitech Wireless Wave
happyhillbilly
yes i have the latest laptop nvidia drivers... i believe im running dx10 but i dont know how to run dx9...(new to vista) when i right click it the game doesnt give me a option to play in dx9
MrNeeds
PC Geek
hiya happyhillbilly, hes referring to the games folder, when you right click crysis warhead in the games folder it will come up with the options for DX9
heres a screenie
    Intel Q6600 @ 2.8GHz
    Evga NF78-CK-132-A 3-Way SLI
    EVGA 560 GTX SC FTW 1GB
    Samsung 7200rpm 250Gb SATA,
    Samsung 7200rpm 750Gb SATA,
    WD 7200rpm 1TB SCSI SATA.
    Antec 900 Gaming Case
    Logitech generic keyboard
    16Mb Sky bb
sygnus21
Here to learn
heres a screenie
Thanks MrNeeds.
Everytime I try to right click something and use the snip tool, my right click option disappears. :) I obviously haven't figured that part out yet - :confused: LOL
And yeah, I should have said Game Folder instead of Games.
Thanks
    Intel D975XBX2
    1680 x 1050
    Antec Neo HE 550
    Antec P182
    Zalman CNPS9500 AT
AstaLaVista
Lost in Cyberspace
Vista Pro
Something tells me you didn't install it correctly. If you don't mind, why don't you try uninstalling the game, reboot, run a registry cleaner (CCleaner is good) and Install it again using the "Run as Administrator" by right clicking on the executable file instead of letting the wizard start as soon as you insert the cd.
    Intel Q9650 w/CM V8 Cooler...
    EVGA GTX260
    Realtek High Def Onboard
    Acer 22" LCD Widescreen
    1680 x 1050
    WD Velociraptor 160GB
    Samsung Sata 750GB
    Maxtor External 160GB
    Thermaltake Speedo Advance
    Air Cooled... See CPU
    Logitech G7
    Logitech G15
    Comcast 6MB Broadband
    Linksys WRT54G router
AstaLaVista
Lost in Cyberspace
Vista Pro
well i downloaded the game through steam so it doesnt install it just does it by itself...
I have never downloaded anything from steam before but I would imagine that what you download is a file that you must save on your hard drive, am I correct to assume that? If so, go to that file and if compressed, uncompress it, if this is a .exe file, right click on it and use "Run as Administrator"
    EVGA GTX260
    1680 x 1050
    Samsung Sata 750GB
    Logitech G7
    Logitech G15
sygnus21
Here to learn
Steam doesn't work that way - which is why I like having a physical disk. Steam based games tend to act a little different (don't ask as I don't have a why answer), even with patches. If you download a steam based game, you'll have also have to use a steam based patch...if one is required.
Since I don't have the steam version of Crysis:Warhead, my suggestion to him would be to check the steam forums on how to enable or swap DX options. My guess however is that this can be done through the games launch options in steam. (right the game's icon, choose properties, choose launch options, then type in DX 9? I guess??? - not sure though)
I'm sure someone here who has the steam based version of Crysis can help out.
I will add that the one benefit of having steam is you can play your steam based games on any computer by simply loading up steam and it will download the files required to run the game(s). Bit of a nice convenience I might add. However I like having physical disks so that's what get when purchasing new games. It if wasn't for HL2, I'd never have used steam.
My 2 cents.
    Intel D975XBX2
    1680 x 1050
    Antec Neo HE 550
    Antec P182
    Zalman CNPS9500 AT
happyhillbilly
ok i tried running as admin and i tried typing in dx9 and neither worked... i forgot to mention this but everytime i launch the game this pops up...
could the redistribution thing have to do with anything?
it says write on drive d which is my cd drive which i think is weird since i dont even have the cd lol
MrNeeds
PC Geek
heres a screenie
Thanks MrNeeds.
Thanks
lmao sygnus, i pressed print screen and cropped the image with paint, paint FTW
you could try and download the c++redist from microsofts website and see if that works but if its trying to install it and its saying that your cd drive is the hard drive then you may need to manually install it.
linky here > http://www.microsoft.com/downloads/...71-e2d6-4230-b809-9a8d7548c1b6&displaylang=en
    16Mb Sky bb
sygnus21
Here to learn
    Intel D975XBX2
    1680 x 1050
    Antec Neo HE 550
    Antec P182
    Zalman CNPS9500 AT
MrNeeds
PC Geek
    16Mb Sky bb
happyhillbilly
i tried redownloading it but it didn't work... the 2005 is the one that is messed up and i tried to redownload that and it didn't install it gave me the same error
MrNeeds
PC Geek
ok, when you try and install it, do you install default? or will it let you get far enough to choose a custom directory to install it to?
    16Mb Sky bb
MrNeeds
PC Geek
the 2005 doesn't get far enough for that it just unpacks everything then never comes back
very strange indeed, ive never encountered anything like this before, lemme check into it more, i believe it maybe something to do with the installation directory.
    16Mb Sky bb
