DEP and iTunes
las121
please don't judge i am only 15 i have a vista home premium my computer has a dep program on it i download itunes so i can use my ipod touch how ever the dep program is blocking it i tryed to block by turning it off then it wasnt working still i was pretty mad so i left it i need it to work more now because its more efficiant at my house to use so i really need help to fix it. and again please excuse if i didnt give any information needed but ask its my first time posting
lordbob75
Lord of Bobs
Vista Pro
Whoah..... That was a little confusing there. Try using capitalization and punctuation. And don't worry, no one on here will judge you, and if they do for something that stupid then i am sure Brink would have something to say about it. And don't worry about being young, I'm only 17 (soon anyways) and you would never guess. (I hope)
Anyways.... Your problem. What is a DEP program? It is the windows "security feature" that everyone hates? I looked it up and it looks like it. So, you are trying to use iTunes and Vista is DEPing the program? It blocks it when you open it correct? When does the problem occur? We do need a little more information on the problem, such as: When it occurs, how often, any other programs? That sort of thing.
Ok. So is it the UAC blocking it? Or it is the DEP like this:
~Lordbob
    ASUS P5QC
    2x2GB
    NVidia GeForce 9500GT 1Gb
    Mobo
    Samsung SyncMaster 206bw
    Samsung SP2514N ATA 250Gb 7200RPM
    Samsung [Model] 1Tb 7200RPM SATA2
    Razer Lachesis
    Razer Tarantula
    not fast enough
las121
Ok sorry for late reply I'm on my iPod ATM. So when I try to open programs like realplayer or winamp it show the dep icon indicating it's blocked. This happends if I click on one of those programs or if I connect my iPod then it d
Shows the message I hope that helped and thanks
lordbob75
Lord of Bobs
Vista Pro
Ok so let me see if i can figure out the problem....
You are trying to run a program (such as Winamp and iTunes) and when you double click, the box (like the one up above right?) displays? Or is it a different box? That could be different dependant on which box it is (I think there are two or three different ones) Does it say "Closed" or "Blocked"?
~Lordbob
    ASUS P5QC
    2x2GB
    Mobo
    Razer Lachesis
    Razer Tarantula
    not fast enough
lordbob75
Lord of Bobs
Vista Pro
    ASUS P5QC
    2x2GB
    Mobo
    Razer Lachesis
    Razer Tarantula
    not fast enough
lordbob75
Lord of Bobs
Vista Pro
    ASUS P5QC
    2x2GB
    Mobo
    Razer Lachesis
    Razer Tarantula
    not fast enough
lordbob75
Lord of Bobs
Vista Pro
ALL RIGHT.
Great pictures thank you.
Ok, so its not the DEP blocking your programs, its a problem with them.
Try reinstalling both of them, and see if that helps.
~Lordbob
    ASUS P5QC
    2x2GB
    Mobo
    Razer Lachesis
    Razer Tarantula
    not fast enough
Rhonda
I am having the same problem. I just bought a new laptop which is running Vista Home Premium x64. I have installed iTunes 8 -- the 64 bit version. The DEP does not allow the program to load when I try to open it. Now I know Bill doesn't allow anything Apple in his house, but I am a bit more open minded. I really would like to use my iTouch & iTunes with this computer. Has any one come up with a way to disable the DEP if it doesn't allow iTunes to be added to the exceptions list? The problem is not with the program (iTunes) since I am running it on my desktop too. The desktop runs a 64 bit version of Vista as well. iTunes runs fine on that one. Apparently it has to do with the processor being able to support hardware-based DEP. Thanks for any and all suggestions.
    Acer Aspire 5535
    AMD 64 x2 ZM-80
    4 Gb
    ATI Radeon 3200
    320 GB SATA
    This is a new laptop. I also have a desktop that features AMD 64x2 5400 balck edition, 4gb ram, 512 Mb nVidia 8600 GT, /w 2 hd (320 & 500 Gb), 650W PS. Also running Vista Home Premium x64, Windows XP Pro 32 bit and Ubuntu x64.
lordbob75
Lord of Bobs
Vista Pro
Rhonda,
You could turn off Windows Defender (I think) or turn off UAC by going into User Accounts.
~Lordbob
    ASUS P5QC
    2x2GB
    Mobo
    Razer Lachesis
    Razer Tarantula
    not fast enough
Rhonda
Thanks for your reply, LordBob. The Windows defender and UAC don't have anything to do with the DEP. I did try those things though. The good news is that I had success by uninstalling iTunes and re-downloading the program and installing from that file. The program setup files I had used were a couple months older ( I save everything I download, eventually, to optical media) and the new file must have been an updated version with a patch to make it compatable with the DEP. In anycase, iTunes is up and running now. Once again, I think you very much for your reply. :D
    Acer Aspire 5535
    AMD 64 x2 ZM-80
    4 Gb
    ATI Radeon 3200
    320 GB SATA
lordbob75
Lord of Bobs
Vista Pro
Actually, I just figured it out last night.
Press [windows]+Pause/Break to open the system menu (or control panel -> system) and press advanced systems settings on the side. Go to the advanced Tab, and press settings. Go over to the D.E.P. (Data Execution Prevention) tab, and press add, then add in iTunes and whatever else you need.
Sorry it was too late.
~Lordbob
    ASUS P5QC
    2x2GB
    Mobo
    Razer Lachesis
    Razer Tarantula
    not fast enough
Rhonda
Lordbob,
Thanks for checking it out. I had actually done that. But if your processor is DEP capable and there is no way to toggle the feature off in the BIOS, you're kind of out of luck. I couldn't change the setting and add iTunes to the list of exceptions. If you happen to find a way to do that, I would love it if you let me know about it. I really do appreciate that you took the time to check it out. That was an awesome thing to do. Thanks again.
Rhonda
    Acer Aspire 5535
    AMD 64 x2 ZM-80
    4 Gb
    ATI Radeon 3200
    320 GB SATA
lordbob75
Lord of Bobs
Vista Pro
You couldn't? I had no trouble. It didn't fix my problem, but still...
~Lordbob
*Calls Brink*
    ASUS P5QC
    2x2GB
    Mobo
    Razer Lachesis
    Razer Tarantula
    not fast enough
Rhonda
Yeah. I tried several times and I would get a message that said the program could not be run without DEP. It was frustrating. As long as the DEP is enabled only by the software (OS) you can change the individual programs. But the cpu/hardware DEP would not allow it. It's very strange. I am hoping to learn whether it is possible to bypass that somehow -- in case another event is not solved so easily.
    Acer Aspire 5535
    AMD 64 x2 ZM-80
    4 Gb
    ATI Radeon 3200
    320 GB SATA
lordbob75
Lord of Bobs
Vista Pro
Well, you can get around it if you set up a task, but I have found no other way... :(
~Lordbob
    ASUS P5QC
    2x2GB
    Mobo
    Razer Lachesis
    Razer Tarantula
    not fast enough
Rhonda
If I set it up as a task? I'm not certain I know how to do that. I am guessing it's a bit like setting up a scheduled scan or defrag, etc.
I wanted to commend you for being very helpful and willing to teach me. Thanks a lot.
    Acer Aspire 5535
    AMD 64 x2 ZM-80
    4 Gb
    ATI Radeon 3200
    320 GB SATA
