"Driver Installation Module Stopped working and was closed"
libymed90
I have an HP dv2915nr with Windows Vista Home Premium 32bit. Recently when I was trying to upload some pictures from my camera to my laptop via my SD card, it came up with the error "Driver Installation Module Stopped working and was closed".
I tried reinstalling drivers and such and have had no luck at all. Can anyone help me? :(
    HP dv2915nr
americancritic
Hello and welcome to the forum.
Click Start...
Click control panel...
Click system & Maintenance...
Scroll down to Device Manager and click update Device drivers...
Click View...
Click show hidden devices...
Make sure there are no yellow warning flag next to any drives
    a6530f Desktop
    HP-PAVILION
    M2N68-LA (Narra3)
    LG W40 series widescreen
    1600 X 900
    300W
    Mid-Size ATX
    Microsoft Wireless Mouse 5000
    HP Multimedia Keyboard
    Processor: AMD Phenom X3 8450 Operating speed: Up to 2.1 GHz, Number of cores: 3, Socket: AM2+, Bus speed: 3600 MHz HT3 (clocked down to 2000 MHz)
    Modem: 56K WinModem/
    Supermulti: 16X DVD(+/-)R/RW 12X Ram (+/-)R DL Lightscribe SATA Drive
    Menory Card Reader: 15-in-1 Multimedia Card Reader
    Media Drive
Arvinwebb
Vista Lover
Hello Libymed,
After driver updates as Americancritic suggested, I would next suggest you to try putting your system in clean boot state helps in identifying if any third party applications or startup items are causing the issue. If yes, you may have to contact the program manufacturer for any updates or uninstall and re-install the program.
How to troubleshoot a problem by performing a clean boot in Windows Vista or in Windows 7?
Can you tell me what were the changes you made before the issue occurred?
Thanks. Arvin
    HP dv2519tu pavillion Laptop
    1.50 GHz
    Winstron
    2.5 gig RAM
    intel onboard
    Conexant HD Smart Audio HD2
    HP Brightview Display
    1280X800
    SATA - 160 + 500 GB
    HP
    HP Laptop
    Air
    HP
    HP Laptop
    4 MB/SEC-Download, 2 MB/SEC-Upload
libymed90
Click Start...
Click View...
I tried it, and it downloads the new, updated driver, but it can't instal. When my computer tries to update the drivers, that's when the error pops up.
    HP dv2915nr
libymed90
Hello Libymed,
Thanks. Arvin
Oh, okay. I think the problems started when I changed from Windows 7 back to Vista.
    HP dv2915nr
americancritic
    a6530f Desktop
    HP-PAVILION
    M2N68-LA (Narra3)
    1600 X 900
    300W
    Mid-Size ATX
    Media Drive
libymed90
[/QUOTE]
Oh, okay. I think the problems started when I changed from Windows 7 back to Vista.[/QUOTE]
Do you think it's possible that since I was once upgraded to 7 that the drivers might only be compatible for that version of the OS?
    HP dv2915nr
americancritic
Did you do a full reformat and then vista, do you have a full version of vista or recovery disk's...
    a6530f Desktop
    HP-PAVILION
    M2N68-LA (Narra3)
    1600 X 900
    300W
    Mid-Size ATX
    Media Drive
americancritic
Have you checked the device mamager to make sure there are no yellow flags next to any of the drivers.
Click start...
In the search box type device manager...
Click view...
click show hidden devices...
Then make sure they are all up to date...
    a6530f Desktop
    HP-PAVILION
    M2N68-LA (Narra3)
    1600 X 900
    300W
    Mid-Size ATX
    Media Drive
