Dymo DiscPainter
miclauren
Sorry if this has been asked before, new to this forum, but is there a way to run Dymo DiscPainter's 32bit only driver and software on Vista 64? Any help you can provide is much apprecated.
    The Beast Model V (homebrew)
    Realtek HD Audio (onboard)
    2 * 1920 x 1080
    Logitech G15 (gen 2)
    Logitech MX Master (shared)
    Lenovo ThinkPad E545
    AMD A6-5350M APU
    Lenovo
    Radeon HD (Embedded)
    Conextant 20671 SmartAudio HD
    Lenovo 15" Matte
    1680 * 1050
    Lenovo
    Lenovo
    Lenovo
    Lenovo
    Dwarf Dwf/11/2012 r09/2013
    ASRock Z77 Extreme4-M
    ViewSonic VA1912w Widescreen
    Iomega 1.5TB Ext USB 2.0
    WD 2.0TB Ext USB 3.0
    Gigabyte IF233
So, the answer ends up being:
No, but get the new drivers, which include the 64bit drivers, and then your device will work on Vista x64.
Oh, and the other answer is egg on my face as I (lazily) did not bother looking to see if 64bit drivers even exist.....
    2 * 1920 x 1080
    AMD A6-5350M APU
    Lenovo
    Lenovo 15" Matte
    1680 * 1050
    Lenovo
    Lenovo
    Lenovo
    Lenovo
Dymo doesn't have 64 bit drivers for this printer. I had to create a partition and install a full 32 bit Vista to get this printer to work.
I have a number of other devices that I needed to control with the laptop. All of them only had 32 bit drivers.
It's been an expensive lesson, but the 64 bit Vista does come in handy for performing some other complex tasks at much greater speed. The main drawback has been the reduction in disk space to get all this done.
I will have to connect an external drive to compensate for this: mainly it will be used for archival purposes.
