Event ID 100 - cannot solve problem
LoganC
Hello,
I am having trouble with a Windows Vista Home Premium SP2 installation. Boot times are exceedingly slow, and I keep receiving Event ID 100 in the Event Log.
I have tried the following...
Deleting temporary files, etc. using CCleaner.
Running a full CHKDSK which reported no errors.
Defragmenting the drive. I even tried PuranDefrag's boot defrag, but that did not fix the issue.
+ System
- Provider
[ Name] Microsoft-Windows-Diagnostics-Performance
[ Guid] {cfc18ec0-96b1-4eba-961b-622caee05b0a}
EventID 100
Version 1
Level 1
Task 4002
Opcode 34
Keywords 0x8000000000010000
- TimeCreated
[ SystemTime] 2012-09-28T08:51:56.229Z
EventRecordID 5190
- Correlation
[ ActivityID] {00000000-9B8C-0001-AF75-52B7559DCD01}
- Execution
[ ProcessID] 1684
[ ThreadID] 3284
Channel Microsoft-Windows-Diagnostics-Performance/Operational
Computer Vista
- Security
[ UserID]
- EventData
BootTsVersion 2
BootStartTime 2012-09-28T08:46:13.702Z
BootEndTime 2012-09-28T08:51:50.342Z
SystemBootInstance 561
UserBootInstance 548
BootTime 291198
MainPathBootTime 86898
BootKernelInitTime 48
BootDriverInitTime 1863
BootDevicesInitTime 6049
BootPrefetchInitTime 61800
BootPrefetchBytes 321318912
BootAutoChkTime 0
BootSmssInitTime 5152
BootCriticalServicesInitTime 1234
BootUserProfileProcessingTime 1654
BootMachineProfileProcessingTime 7574
BootExplorerInitTime 1633
BootNumStartupApps 2
BootPostBootTime 204300
BootIsRebootAfterInstall false
BootRootCauseStepImprovementBits 0
BootRootCauseGradualImprovementBits 0
BootRootCauseStepDegradationBits 0
BootRootCauseGradualDegradationBits 0
BootIsDegradation false
BootIsStepDegradation false
BootIsGradualDegradation false
BootImprovementDelta 0
BootDegradationDelta 0
BootIsRootCauseIdentified false
richc46
LoganC
Creating a new user account does not solve the problem.
A full MalwareBytes scan found no malware.
Clean boot does not solve the problem either.
richc46
Not good
Try in safe mode, if it does not work, its a hardware problem. Most likely hard drive.
Post back either way.
richc46
Sounds like a basic driver like, graphics, audio etc
Can you get to system restore?
Go back to before the problem
Event 100 just means a boot time problem. It means that you are slow.
and
Go to search by the start button. Type device manager. In manager look for small yellow arrows. It means that driver is corrupt.
You are welcome
richc46
OK that means the drivers are not corrupt. Do you know how to update the basic drivers; audio, internet, graphics etc?
wither 3
I found this old description of the Event 100- Event ID 100
However, I'm hesitant to say this is the cause of the slow boot times. If you run msconfig.exe and look at the Startup tab, you may notice things that don't need to be there (disabling them doesn't make them inoperable). My bootup takes all of 4 minutes because of the anti-virus, back up scheduler, etc. Since I put my system to sleep rather than shutting down, I don't worry about the boot time.
    Vista Home Premium 64 bit SP2
    Cyberpower
    Intel Quad CPU Q6700 2.67 GHZ
    NVIDIA 780i
    MSI GTX 560 TI Twin Frozr
    Sound Blaster SB Audigy
    Viewsonic VG2436
    1920x1080p
    Samsung HD 105SI
    WDC WD20
    Apevia XJupiter
    air
    Logitech MX 600
    Logitech MX 3200
    30 Mbps
richc46
We already disabled all that is not necessary with the clean boot and it did not help.
On a side note my boot takes 45 seconds. Nothing is disabled or on delayed boot.
richc46
How do you update them and how do you know they are up to date?
richc46
Thats what I thought. Using that method to find updates very rarely gives the most up to date. For the primary drivers, network, graphics, audio, go to the website and check for the most up to date. Most large companies have a scanner on their website that will scan your computer and give the "true" most up to date.
richc46
You are very welcome. If you have problems, let us know and maybe we can help.
richc46
See, not sure if it will solve your problem, but its best to have the most up to date driver.
LoganC
RichC, that was for the integrated graphics. I apologize for not pointing that out.
Boot time is still slow. It is driving me up the wall.
richc46
Ok, thats fine, lets take it slow so its done right. Did you update all the vital drivers (network, audio etc)
