Solved Explorer crashes on right click!
orihuelac
Hi everyone!!
I have a problem sometimes when i made a right click on random items on my computer, because while vista tries to display the right click menu an error appears saying that EXplorer has enconter a problem and must be restarted.
Sometimes does this, and sometimes not, but always when i right click an item.
Any ideas??
Thanks in advance...
DRX
Brink
Staff member
mvp
    1TB Samsung 970 EVO Plus M.2,
    250GB Samsung 960 EVO M.2,
    6TB WD Black WD6001FZWX
    Linksys EA9500 router,
    Arris SB8200 cable modem,
    Lumia 1520 phone
orihuelac
Thanks a lot. I took a while to determine which shell extension was causing the problem, it was the WinAce 2.5. But now my vista is working fine.
Thank you!!
Brink
Staff member
mvp
Your welcome DRX. Thank you for posting your results back.
Yeah, it can take a bit of hunting to find it with so many of them.
    Lumia 1520 phone
Brink
Staff member
mvp
Hello Mynaito,
If this has just recently happened to you, then you might consider doing a System Restore using a restore point dated before this happened to see if it can fix this for you automatically.
If this is not an option for you, then the 2 links in my post above will help explain what to do the the ShellExView program. You will basically be disabling the listed Context Menu items one by one until you find out which one is causing the issue.
    Lumia 1520 phone
gorankx
Start>>Search>>eventvwr.msc
Navigate to Application section and find & read all error messages concern explorer.exe
there you find detailed info about problem
for example, my problem was imageshack uploader
so i deinstaled aplication and all go back to normal.
mynaito
Thank you so much for that info! I found the application and tried to find where those error messages are but am not sure where to look! How do I find this?
Grateful for your help,
M
AsusRoG
I have the same problem. Sometimes I get the error every time I right click on the desktop, other times it happens once and doesn't do it again. I looked into the shell extension program to help identify my problems source but there are so many things to disable. Seem like my effort become futile. I did however get a message after it happened a few times. I'm not sure if this helps identify the source or not. Any information would be greatly appreciated!
C:\Users\xxxxx\AppData\Local\Temp\WERF038.tmp.version.txt
C:\Users\xxxxx\AppData\Local\Temp\WERFEE8.tmp.appcompat.txt
C:\Users\xxxxx\AppData\Local\Temp\WERFF37.tmp.mdmp
Spartan111792
Thank you so so much! I have been having the right click problem for months, It's whenever I right click .exe Files... i Disabled and reinables files for the past hour and i found the one that messed it all up! The File name is CmdLineContextMenu Class its SecuROM from sony, might be from a Video Game, anyways thank you so much Brink... I Your post really helped me and i am very thankfull for you
Brink
Staff member
mvp
You're most welcome Spartan, and welcome to Vista Forums. :)
    Lumia 1520 phone
Koosh
I just started having these issues this morning and this was a great stroke of luck to find so easily. Thanks Brink.
Problem: Right-clicking .exe files in Windows Explorer would cause Windows Explorer to crash and restart.
Solution: Using ShellExView, I determined the cause to be 'Adobe PDF Link Helper'. Uninstalled Adobe Acrobat, re-downloaded and re-installed. Working great.
Brink
Staff member
mvp
Hello Koosh, and welcome to Vista Forums.
I'm happy to hear that you got it sorted as well. :)
    Lumia 1520 phone
iNuXs
My issue was with .jpg images :mad:. Thank You so much for this thread. I was about to reinstal my os >:(.
Btw mine was: NeroCoverEdContextMenu Class
Brink
Staff member
mvp
That's great news INuXs and Wheelthru, and welcome to Vista Forums. :)
    Lumia 1520 phone
kagmcc
Hi
their are some great suggestions here and i have tried them all however i am still getting the issue, does any one have any ideas pls?
stevebobs
I've had the right click crash issue for two years now and the shell viewer mentioned helped me find the culprit. It turned out to be a raw viewer developed by Arcsoft. I disabled it and the right click is back again and doesn't crash windows explorer. It takes a while to sort through the non-system shell files but I shut off 10 at a time and then was able to narrow it down until right click works. Very strange , these computers. Very happy to have the right click back again!!!
