grasshoper
Yeah I saw his sfc log earlyier, I was stating he could have solved the problem a long time ago by just doing a clean install.
Yep, but it is a school case and the cause is surely in front of us....
I resolved many weird problems except those where the faulty install has been cleaned, of course.
@Grasshopper,
Can you name the last 5 or 6 progs that you have installed or uninstalled before this problem occured including ActiveX?
BTW, can you deinstall activex or any third party things you could have installed in IE.
Have you checked for any mallware? As i saw you have too many programs opened, You could also make a registry scan and disable the services you dont need.
If that wont help, STFW, otherwise, i would format my PC.
No indeed, but all suggestions have already be covered, new ones are welcome.
@ Grasshopper,
Did it happen before or after SP1 ?
ctrl + does nothing, there is a lot of addons in internet explorer, but they all seem to be fine.
I have a program you could try but it might break Vista if you use it.
Do you want to try it?
there does not appear to be any bad or unknown addons in IE
