Solved ExpressCard 54 (USB3.0) Wont work on Vista (Error 10 on Device Manager)
Joadix100
Active Member
I recently bought an ExpressCard54 to add USB 3.0 to my old Windows Vista 2007 Laptop (I was intending to use it to clone hard drives with high Speed USB 3 Equippment) and when i installed it everything was fine until i tried to install drivers, the system crashed, it seems that the drivers in the CD included were for Windows 7 and above, so i looked up in the Microsoft Catalog and found Windows Vista drivers, installed them and the system didnt crash, but it gave me Error 10 and it wasnt Working even after restarting and trying with Fresco Logic (Brand of the Card) Generic Drivers for Vista
I have Windows Vista SP2 6003 x86 (I installed All Windows Vista and Server 2008 Updates i could [I have over 500 Updates installed including updates for Office 2010 and .NET])
All drivers up to date in their Windows Vista version
    Windows Vista SP2 x64 (with Extended Kernel)
    Acer Aspire 5315
    Intel Core 2 Duo T7700
    Acer Arcadia
    3GB DDR2 SODIMM 667MHz (1+2GB)
    Intel 965 Express Chipset Family
    Realtek ALC268
    AU Optrionics B154EW02 V7
    HP S600 120GB SSD
    Liteon PA-1650-02
    Integrated
    Integrated
    Trust Primo Black
    802.11g
    https://www.acer.com/us-en/support?filter=global_download&search=AS5315
    Windows 11 Home
    Me
    Intel Core i7-11700
    Asus Prime B560 Plus
    Kingston Fury 32GB DDR4 3200MHz (2x16GB)
    Nvidia GTX 1660Ti
    Redragon ZEUS 2 (USB)
    Comstar SY190HV
    Crucial BX500 SSD SATA3 1TB
    WD Blue WD10JPVX 1TB
    Toshiba HDWD110 1TBx2
    Cougar XTC500
    Thermaltake V100
    Corsair H55
    Redragon Griffin M607
    Genius GK070008/U
    1Gbps
    https://www.asus.com/Motherboards-Components/Motherboards/PRIME/PRIME-B560-PLUS/
SIW2
Install the driver framwork update windows6.0-kb2864202-x64.msu ( if you already have it, it will just say not applicable )
Then install the xhci and ( optionally) the uasp drivers. All in the attached zip file.
    Vista
    Intel E8400
    ASRock1333-GLAN R2.0
    4gb DDR2 800
    nvidia 9500GT 1gb
    win7/vista
    intel i5-8400
    gigabyte b365m ds3h
    ballistix 2x8gb 3200
Joadix100
Active Member
I couldnt install the xHCI Driver, gives me error that there is no compatible device (i run 32 bit WinV and tried both 32 and 64 bit drivers)
    Acer Aspire 5315
    Acer Arcadia
    Realtek ALC268
    HP S600 120GB SSD
    Liteon PA-1650-02
    Integrated
    Integrated
    Trust Primo Black
    802.11g
    Windows 11 Home
    Me
    Intel Core i7-11700
    Nvidia GTX 1660Ti
    Comstar SY190HV
    Cougar XTC500
    Thermaltake V100
    Corsair H55
    Genius GK070008/U
    1Gbps
SIW2
    Vista
    Intel E8400
    4gb DDR2 800
    nvidia 9500GT 1gb
    win7/vista
    intel i5-8400
    gigabyte b365m ds3h
Joadix100
Active Member
DISM++ does not show me any "Driver" option in te pane
    Acer Aspire 5315
    Acer Arcadia
    Realtek ALC268
    HP S600 120GB SSD
    Liteon PA-1650-02
    Integrated
    Integrated
    Trust Primo Black
    802.11g
    Windows 11 Home
    Me
    Intel Core i7-11700
    Nvidia GTX 1660Ti
    Comstar SY190HV
    Cougar XTC500
    Thermaltake V100
    Corsair H55
    Genius GK070008/U
    1Gbps
SIW2
No, dism++ cant install drivers on vista. It can only do drivers for win7 and newer. Dism++ can install updates on vista.
Did you try browsing to the drivers from device manager?
    Vista
    Intel E8400
    4gb DDR2 800
    nvidia 9500GT 1gb
    win7/vista
    intel i5-8400
    gigabyte b365m ds3h
Joadix100
Active Member
Yes, i tried, that was the first thing i tried
    Acer Aspire 5315
    Acer Arcadia
    Realtek ALC268
    HP S600 120GB SSD
    Liteon PA-1650-02
    Integrated
    Integrated
    Trust Primo Black
    802.11g
    Windows 11 Home
    Me
    Intel Core i7-11700
    Nvidia GTX 1660Ti
    Comstar SY190HV
    Cougar XTC500
    Thermaltake V100
    Corsair H55
    Genius GK070008/U
    1Gbps
SIW2
I used peimg to install drivers in vista boot.wim and vuisetup for install.wim
I am not sure how you would coax them into an already installed vista image.
    Vista
    Intel E8400
    4gb DDR2 800
    nvidia 9500GT 1gb
    win7/vista
    intel i5-8400
    gigabyte b365m ds3h
Joadix100
Active Member
So.... which are my options? I Won´t give up on Vista
    Acer Aspire 5315
    Acer Arcadia
    Realtek ALC268
    HP S600 120GB SSD
    Liteon PA-1650-02
    Integrated
    Integrated
    Trust Primo Black
    802.11g
    Windows 11 Home
    Me
    Intel Core i7-11700
    Nvidia GTX 1660Ti
    Comstar SY190HV
    Cougar XTC500
    Thermaltake V100
    Corsair H55
    Genius GK070008/U
    1Gbps
SIW2
Working on my vista - I had previously integrated them into installation media.
You could try pnputil command example
pnputil.exe -i -a c:\usbcam\USBCAM.INF -> Add and install driver package
    Vista
    Intel E8400
    4gb DDR2 800
    nvidia 9500GT 1gb
    win7/vista
    intel i5-8400
    gigabyte b365m ds3h
SIW2
Vista x64 Seems to run ok on 365 mobo with 8th gen cpu. No igpu drivers, so just using the basic vga graphics.
Separate graphics card should work fine.
    Vista
    Intel E8400
    4gb DDR2 800
    nvidia 9500GT 1gb
    win7/vista
    intel i5-8400
    gigabyte b365m ds3h
Joadix100
Active Member
"Error adding driver package: invalid INF file was transmitted as parameter" (Text in spanish translated for you by me)
    Acer Aspire 5315
    Acer Arcadia
    Realtek ALC268
    HP S600 120GB SSD
    Liteon PA-1650-02
    Integrated
    Integrated
    Trust Primo Black
    802.11g
    Windows 11 Home
    Me
    Intel Core i7-11700
    Nvidia GTX 1660Ti
    Comstar SY190HV
    Cougar XTC500
    Thermaltake V100
    Corsair H55
    Genius GK070008/U
    1Gbps
SIW2
You could run double driver and see if you can restore from the backed up usb3 I have included.
    Vista
    Intel E8400
    4gb DDR2 800
    nvidia 9500GT 1gb
    win7/vista
    intel i5-8400
    gigabyte b365m ds3h
Joadix100
Active Member
When i try to restore it gives me the Error: Cannot find the specified module: "dd.dll"
    Acer Aspire 5315
    Acer Arcadia
    Realtek ALC268
    HP S600 120GB SSD
    Liteon PA-1650-02
    Integrated
    Integrated
    Trust Primo Black
    802.11g
    Windows 11 Home
    Me
    Intel Core i7-11700
    Nvidia GTX 1660Ti
    Comstar SY190HV
    Cougar XTC500
    Thermaltake V100
    Corsair H55
    Genius GK070008/U
    1Gbps
Vistaar
    Vista Home Premium x86 SP2
    HP Pavilion Elite m9150f
    Intel Q6600
    3 GB
    NVIDIA GeForce 8500 GT
Joadix100
Active Member
    Acer Aspire 5315
    Acer Arcadia
    Realtek ALC268
    HP S600 120GB SSD
    Liteon PA-1650-02
    Integrated
    Integrated
    Trust Primo Black
    802.11g
    Windows 11 Home
    Me
    Intel Core i7-11700
    Nvidia GTX 1660Ti
    Comstar SY190HV
    Cougar XTC500
    Thermaltake V100
    Corsair H55
    Genius GK070008/U
    1Gbps
SIW2
dd.dll put it next to dd.exe
    Vista
    Intel E8400
    4gb DDR2 800
    nvidia 9500GT 1gb
    win7/vista
    intel i5-8400
    gigabyte b365m ds3h
Joadix100
Active Member
The good news is that i could install the drivers (DD did it) , the bad ones is that they are not visible in device manager and the ExCard54 is still not working
    Acer Aspire 5315
    Acer Arcadia
    Realtek ALC268
    HP S600 120GB SSD
    Liteon PA-1650-02
    Integrated
    Integrated
    Trust Primo Black
    802.11g
    Windows 11 Home
    Me
    Intel Core i7-11700
    Nvidia GTX 1660Ti
    Comstar SY190HV
    Cougar XTC500
    Thermaltake V100
    Corsair H55
    Genius GK070008/U
    1Gbps
SIW2
does the excard show in devmgmt
    Vista
    Intel E8400
    4gb DDR2 800
    nvidia 9500GT 1gb
    win7/vista
    intel i5-8400
    gigabyte b365m ds3h
Joadix100
Active Member
    Acer Aspire 5315
    Acer Arcadia
    Realtek ALC268
    HP S600 120GB SSD
    Liteon PA-1650-02
    Integrated
    Integrated
    Trust Primo Black
    802.11g
    Windows 11 Home
    Me
    Intel Core i7-11700
    Nvidia GTX 1660Ti
    Comstar SY190HV
    Cougar XTC500
    Thermaltake V100
    Corsair H55
    Genius GK070008/U
    1Gbps
