Fan Speed
50
So I took a look through this section and found SpeedFan. Thought about how my computer sometimes can gets very hot and can edge on overheating (according to CoreTemp) so I decided to give it a go.
But it doesn't list my motherboard. I dig some digging and my motherboard is an Intel GL40. So any alternative programs to do a similar goal as SpeedFan?
    Intel Petnium Dual Core T3400
Patonb
2,245
What are you trying to do? That mobo part is for overclocking.
Speedfan is for possibly controlling the fans.
    Dual L5639 // i7 950 @ 4.0Ghz
    gtx 560 ti // gtx 260-216
    Dual 22" // Headless
50
Trying to reduce overheating. I been monitoring my temperatures with Temp Core and all that and it edges close to overheating on good occasions (Single digits or low teens to TJMax).
americancritic
1,554
Location
Arizona
    a6530f Desktop
    HP-PAVILION
    M2N68-LA (Narra3)
    LG W40 series widescreen
    1600 X 900
    300W
    Mid-Size ATX
    Microsoft Wireless Mouse 5000
    HP Multimedia Keyboard
    Processor: AMD Phenom X3 8450 Operating speed: Up to 2.1 GHz, Number of cores: 3, Socket: AM2+, Bus speed: 3600 MHz HT3 (clocked down to 2000 MHz)
    Modem: 56K WinModem/
    Supermulti: 16X DVD(+/-)R/RW 12X Ram (+/-)R DL Lightscribe SATA Drive
    Menory Card Reader: 15-in-1 Multimedia Card Reader
    Media Drive
50
I currently have tired both of those actually. I am using Core Temp right now to monitor what is up with it. (Typoed it as Temp Core).
I also deicded to open up the panel covering up the motherboard and bit a bit of cleaning to it. Blew at it and quite a bit of dust came out. I blew at the vents on the side and there was a lot. SO far that has as far as I can see improved the performance of the fan a bit. I'll try more to see what happens.
Patonb
2,245
youre not going to use a program to do what you want.
Youre best option will be a cooler.
50
It seems this did quite a bit of magic. It is sometimes the simpliest of solutions that you overlook and completely disregard that gets results (It is now like ~20 degrees cooler)
Patonb
2,245
#8
Yha, i had my acer shutting down because the gopu overheated.
Cleaning helped it go bye bye.
americancritic
1,554
Location
Arizona
#9
If you use compressed air do it in short bursts not full out.
    a6530f Desktop
    HP-PAVILION
    M2N68-LA (Narra3)
    1600 X 900
    300W
    Mid-Size ATX
    Media Drive
