Help Norton and Kaspersky can't find virus or worm!
Tarka Dal
I know nothing!
328
Help please Norton and Kaspersky can't find virus or worm! Can anyone think of a scan that will find this little begger on my computer :mad: Also Trend Micro does not work as java is disabled when it says enabled.and when you get Java enabled it still won't scan your computer...
    Intel Core 2 Quad Q6600 G0 St
    Asus STRIKER EXTREME 680I SLI
    Corsair 4GB Kit (4x1GB) DDR2 800MHz/PC2-6400 XMS2 Memory
    Point Of View 8800GT 512MB GDD
    Soundmax 5.1
    Samsung 46"
    1080P
    1x WD Raptor WD360ADFD 36GB SATA 10KRPM 16MB Cache
    1x WD Raptor WD740DFD 74GB SATA 10KRPM 16MB Cache
    Coolermaster 600W
    Coolermaster nVidia
    Arctic Cooling Extreme
    MS Wireless Laser mouse 8000
    MS Wireless Entertainment Keyboard 7000
    1.2mb & 10mb
Dwarf
The Contemplator
2,760
Location
Doncaster, UK
Hi Trax1963,
What is it that you are looking for?
    Dwarf Dwf/11/2012 r09/2013
    ASRock Z77 Extreme4-M
    ViewSonic VA1912w Widescreen
    Iomega 1.5TB Ext USB 2.0
    WD 2.0TB Ext USB 3.0
    Gigabyte IF233
Tarka Dal
I know nothing!
328
I have a bug in this computer and it is able to stop all kinds of security scans. All this just after a reinstallation of windows. It is also trying to burn out my cpu and memory... Its a computer killer as i like to call it...
    Soundmax 5.1
    Samsung 46"
    1080P
    Coolermaster 600W
    Coolermaster nVidia
    1.2mb & 10mb
Dwarf
The Contemplator
2,760
Location
Doncaster, UK
Hi Trax1963,
I understand that this is a big problem for you, but please do not bump your thread. This sounds as though it could be a worm that is prevalent at the moment.
When you reinstalled Vista, were you still connected to a network? I recommend that you should disconnect completely from the network whilst reinstalling as without any form of security active on your system it is extremely vulnerable.
The best solution that I can think of is for you to reinstall again. If you have access to an old Win98 or Win98SE disk, then insert it and boot from that. This might sound silly, but what you are going to do is to use that disk to format your hard drive with a completely different file system structure. Make sure that you choose the full and not the quick format option (if you get the choice). Once the disk is formatted, delete the partition. Remove the 98 disk and insert the Vista disk and reboot. Install Vista as normal. Before you connect to a network of any description, install your AV software. Please note that you should only install one as having more installed can actually cause problems because they can conflict with each other. Don't worry about it being out of date as it will update itself when you go online.
    Gigabyte IF233
Tarka Dal
I know nothing!
328
No i don't have Old 98 disks.
I did not have 2 antivirus systems running together i tried them seperately. And have now tried a third called Trend micro. To no avail so i will have to reboot and also loos 1 TB of data with it...Unless someone has a better idea!
    Soundmax 5.1
    Samsung 46"
    1080P
    Coolermaster 600W
    Coolermaster nVidia
    1.2mb & 10mb
SIW2
2,741
You could try running the free Malwarebytes.org.
If you need to reformat completely, as Dwarf suggests, you can do it by booting in with Gparted free.
SourceForge.net: GParted: Downloading ...
D/l iso , burn to cd with isoburner - do not format cd, if autoplay pops up , just close it.
http://www.ntfs.com/downloads/Iso-burner.zip
Edit: If it is preventing scans in Windows, you can use these bootable anti-malware apps. -Avira includes an iso burner - the FSecure you need to burn as above
http://www.free-av.de/en/tools/12/avira_antivir_rescue_system.html
http://www.raymond.cc/blog/archives...d-300-to-clean-virus-from-unbootable-windows/
http://www.f-secure.com/linux-weblog/files...elease-3.00.zip
Hope it helps
SIW2
    Intel E8400
    ASRock1333-GLAN R2.0
    2gb DDR2 800
    nvidia 9500GT 1gb
Tarka Dal
I know nothing!
328
Thanks for the suggestion SIW2. I have Trojan Remover as Malware Bytes does not work on my 64bit. But will use the rest of the info Cheers mate!
Little fed up now after days of problems. Tired and just want to go to bed ZZZZZZzzzzzzzzzzzzz!
    Soundmax 5.1
    Samsung 46"
    1080P
    Coolermaster 600W
    Coolermaster nVidia
    1.2mb & 10mb
SIW2
2,741
#8
That's strange - malwarebytes works perfectly on all my 64 bit operating systems , including Windows 7. Whatever you have on there may be blocking it - try the bootable Avira.
Good Luck
SIW2
    Intel E8400
    2gb DDR2 800
    nvidia 9500GT 1gb
Tarka Dal
I know nothing!
328
#9
Norton, Kaspersky and PcCillin or Trend Micro didn't work although each of them found crap on my computer that i never knew i had...The best was Trend Micro. But i am afraid that i am about to loose 1Tb of info that took me many years to accumilate. The reason for this is that PcCillin found 10 bits of crap in that drives recycle bin...Ah well i'll do it tommorow i think!:cry:
    Soundmax 5.1
    Samsung 46"
    1080P
    Coolermaster 600W
    Coolermaster nVidia
    1.2mb & 10mb
Poseidonas
22
Location
New York, U.S.A.
#10
Why don't you download SUPERAntiSpyware? Its better than all 3 you mentioned (I own all of what you tried). Kaspersky is only better in the anti-virus department (picks more up traces) but SuperAntiSpyware does pick up the nasty original files.
Lifetime free - if u don't want it to autoupdate or autoprotect (onetime $20 lifetime license otherwise). Make sure you set it , in the Preferences, to NOT ignore file locations.
BTW all anti-malware products are set to ignore specific locations on a computer , to "speed up" the process. That is 50% of the reason why most A/V software misses a lot of stuff. They often ignore the System Restore folders (where most powerful malware reside to "reinstall" themselves - NORTON specifically ignores this location).
The other 50%? It's a crappy software !
If you doubt my opinion, get rid of Norton (download their Norton Removal Tool), keep Kaspersky and install SuperAntiSpyware FREE edition to scan after Kaspersky to see what it missed - and it will be a lot !
    AMD Athlon 64 X2 4800+ S939 2MB cache
    DFI LanParty UT nF4 SLI-DR EXPERT
    Crucial Ballistix TRACER DDR PC4000 1024 x 4
    BFG GeForce 6600 GT O.C. 128MB PCI-E [upgrade soon to 9800]
    SoundBlaster Audigy Platinum [upgrade soon to X-Fi PCI-E]
    ViewSonic G70fmb 17" CRT 0.21mm [upgrade soon]
    1280x1024x32 @ 60Hz
    250GB Seagate Barracuda 7200.9 8MB ST325082
    500GB Seagate Barracuda 7200.11 32MB ST350032
    (will obtain 3 more 500GB drives to enable RAID 5)
    Antec QUATTRO 1000W, 80+ Certified
    Antec SX1040B 10-bay 1.1mm steel [upgrade soon to Antec 900]
    4 x 80mm Antec fans, VGA air duct [upgrade soon to 120mm]
    MS SideWinder Mouse & MS Wireless Laser Mouse 6000
    MS Wireless Laser Keyboard 6000 v2.0
    56K, Satellite, WiFi Hotspot
    Plextor PX-810SA SATA DVD+/- R/RW Drive
    HP dvd1070 Lightscribe SATA DVD+/- R/RW Drive
    MS X360 Wireless Controller (Black)
    MS Wireless Receiver (for X360 controller)
    MS X360 HD-DVD Drive (to PC)
    HP PhotoSmart C7280
    HP LaserJet 3380
    HP ScanJet 4670 w/ Negative Adapter
    MicroTek ScanMaker 5950
Tarka Dal
I know nothing!
328
#11
Superantispyware is the first thing i tried. Nothing works..Not even the recovery disk.
Ok Iv'e tried..
Superantispyware
Trojan Remover
Kaspersky
Norton IS
Trend Micro (PcCillin)
Trend Micro Housecall
Avira AV
Avira Reboot disk
Any suggestions...any
    Soundmax 5.1
    Samsung 46"
    1080P
    Coolermaster 600W
    Coolermaster nVidia
    1.2mb & 10mb
Tarka Dal
I know nothing!
328
#12
Just to let you all know i had to delete everything and reformat all drives. There are some real dangerous viri out there and i would not want anyone to have to spen at least 40 hours on trying to kill a virus and have to do a complete system reboot. So my advice is steer clear of all those nasties by not having a computer in the first place. If you do then remember 'I told you so...'
Oh and the Viri was in D:$recycle bin How it got there hell knows?
    Soundmax 5.1
    Samsung 46"
    1080P
    Coolermaster 600W
    Coolermaster nVidia
    1.2mb & 10mb
Tarka Dal
I know nothing!
328
#13
This gets worse...After formatting all drives re-installing of windows. Then put Kaspersky on before anything else whilst not being connected to a network...in D: the viri is still there. As you can see below Kapersky scans over D:$recycle bin and starts to burn out my memory. It gets worse as you as time goes by...
I am going to format the drive a few times and try again!
50+ hours lost...in time.
    Soundmax 5.1
    Samsung 46"
    1080P
    Coolermaster 600W
    Coolermaster nVidia
    1.2mb & 10mb
dk70
Vista Pro
213
#14
Seems like Kaspersky is working on a backup you have? So how you expect it to remove? may be not possible - if it even detects something that is.
You said virus stops scans and yet you are scanning. Story is confusing :)
Try get some details of claimed virus. Why are you so sure there is an infection? You are not saying a rescue/live-cd "dont work"? You spend many hours but seem to move too fast somehow. If you really have a virus living a life on its own even when separated from OS! I suggest you give those live-CDs another try. Good ones are Aviras, Kasperskys and Bitdefenders
Also post RSIT log - run this http://images.malwareremoval.com/random/RSIT.exe after it is done you have 2 log files in c:\rsit - attach them to a post so people have better chance of evaluating mystery virus.
This is a Vista forum, mainly - may be this is out of normal peoples league and you should contact a dedicated anti-virus/malware removal forum? Just a suggestion. Try http://www.bleepingcomputer.com/forums/ there are lots to chose from. Be sure you read rules etc. before posting or you risk not getting help.
    AMD X2 6000
    Gigabyte GA-MA790FX-DS5
    Corsair 4x1gb 6400C4
    XFX 8800GTS XT 320mb, Generic Nvidia 6200 PCI 128mb
    Onboard Realtek ALC889A
    24" Samsung 245b, 20" Dell 2007WFP, 19" Samsung 193P
    WD Raptor 74gb, Maxtor 300gb, WD Caviar 16SE 500gb
    Corsair 520W
    Cooler Master Centurion 532
    Logitech MX1100R
    Logitech G15
    20mb down, 1mb up
sassofalco
What bad, bad,habit?
    nVidia GeForce Go 7300, 128MB
    1280x800x60Hertz [max.]
Tarka Dal
I know nothing!
328
#16
DK70
Thanks for your comments. I'm sorry it's so confusing but i am working fast trying to get rid of this bug. Have been at it so long now little sleep and quite fed up...Might be cheaper and easier to install new drives...Never thought of that before. It's cheaper than taking it to a specialist....If all else fails i'll do that!
    Soundmax 5.1
    Samsung 46"
    1080P
    Coolermaster 600W
    Coolermaster nVidia
    1.2mb & 10mb
Tarka Dal
I know nothing!
328
#17
    Soundmax 5.1
    Samsung 46"
    1080P
    Coolermaster 600W
    Coolermaster nVidia
    1.2mb & 10mb
dk70
Vista Pro
213
#18
Onecare on Vista 64bit can be a bit buggy so I would not put too much into that. Ive had it freezing as well.
If I were you I would like to see what Kaspersky live-cd pick up.
Specialist? Yeah good luck with that, like you cant scan on your own. Try one of the many removal forums if you want a specialist to have a look. Cost you nothing.
    AMD X2 6000
    Corsair 520W
    Logitech MX1100R
    Logitech G15
    20mb down, 1mb up
Tarka Dal
I know nothing!
328
#19
Tried Avira Boot CD and guess what...It didn't find anything although it did say unable to scan $recycle bin... Oh! and it would only scan half of D: It didn't bother with E: I: H: J:K: X: or Y:
Oh! by the way, i bought a new Drive 250Gb 16Mb for only £43 at a well known site in the UK. Cheaper than taking it to a specialist eh...;)
    Soundmax 5.1
    Samsung 46"
    1080P
    Coolermaster 600W
    Coolermaster nVidia
    1.2mb & 10mb
dk70
Vista Pro
213
#20
Yeah possible you have to select/scan drives one at a time in "Directory - Search path" box.
Unable to scan recycle bin sounds a bit weird. Recycle bin works? you can empty it?
The idea of a live-cd is no matter how infected computer is it will still be scanned - I would continue to scan away until problem is solved.
Seems like the only way you can be infected now is because you restore virus through backups? - and somehow activates it while remaining undetectable.
I thought bios virus died like in the 90s, yeah they did ;)
    AMD X2 6000
    Corsair 520W
    Logitech MX1100R
    Logitech G15
    20mb down, 1mb up
