HELP
What is the name of your hard drive mfg? It probably is not the hard drive, but lets check it out.
HARD DRIVE
TOSHIBA MK2555GSX ATA Device
Manufacturer: TOSHIBA
Interface: IDE
Capacity: 244.20 GB
Real Size: 250,059,350,016 bytes
    HP Pavilion
    AMD Athlon X2 QL-64 Griffen 65nm Technology
    Wistron 303C (Socket A)
    4.0GB DDR2 @ 333MHz 5-5-5-15
    256MB GeForce 8200M G (HP)
    High Definition Audio Device
    1280x768
    244.20GB Toshiba MK2555GSX ATA Device (IDE)
Richard could heat affect the computer and make the bsod happen
    HP Pavilion
    1280x768
YES most defin. Do you know what temps you are running at.
CPU and graphics were running at about 95 when the crash happened but i have them down to 65 going by speccy
    HP Pavilion
    1280x768
Seems rather high. You should shot for about 45 when idle and 65 when running (centergrade). Might be a good possiblity that is the cause of the problem.
Any sugestions on how to keep a laptop that is always running cool. Funny thing is, I have it hooked up to a 40 inch 1080p tv and I use that as my monitor.
    HP Pavilion
    1280x768
Thanks buddy...goodnight
    HP Pavilion
    1280x768
Upload the last dump file and we will take a look, it could be something straight forward.
    Self Build
    Asus P5Q Premium
    2 x ASUS EAH 4870 X 2 (Quad)
    Supreme FX 2
    CoolerMaster 1000
    Logitech G5
    Logitech G15
    20Mbps
Really, great support on your part Stu. If I did not tip the scales before, I would now.
hope i remembered this right
    HP Pavilion
    1280x768
