Installed RAM Displayed Incorrectly?
Mr Smiley
And a very Good Morning to you all at 2:24am from Sydney, Australia!!!
I draw your attention to the image attached below which I have extracted from Lavalys Everest Ultimate Edition's Memory Benchmarking Test.
As I only confess to having no more than an intermediate computer knowledge, could someone please answer my following query:
Why in the image does it display my Memory Type as being Dual Channel DDR2-667 SDRAM (5-5-5-12) when what I have installed is Dual Channel DDR2-800 RAM (4-4-4-12)?
Any information and assistance would be much appreciated.
With Kindest Regards
Neil
    Intel Core i7-920
    Gigabyte GA-EX58-UD3R
    Gigabyte GV-N26OC-896H-B
    N/A - On Board via SPDIF
    BenQ 24" E2420HD
    1920 x 1080p Full HD
    Western Digital
    1 x TB Sata
    1 x 320GB Sata
    Zalman 1000 Watt
    Antec Twelve Hundred
    2 x Liteon DVD Burners Sata
Brink
Staff member
mvp
Hi Neil,
Do you have any DDR2 667 MHz RAM sticks installed with the 800 MHz ones? If you do, the 800 MHz will step down to 667 MHz automatically. You should also double check your motherboard memory jumpers and BIOS settings to make sure that they are correct.
See if you get the same results with CPU-Z.
CPUID
    1TB Samsung 970 EVO Plus M.2,
    250GB Samsung 960 EVO M.2,
    6TB WD Black WD6001FZWX
    Linksys EA9500 router,
    Arris SB8200 cable modem,
    Lumia 1520 phone
Mr Smiley
Hi Shawn
Thanks mate for your response.
When I added the extra 2GB of G-Skill RAM recently, I made sure that they were identical to the existing 2GB being: G-Skill F2 6400 PHU2 2GB HZ DDRII 1GB PC2 6400 444/12)
Can you take a look at the attachments below from CPU-Z when you get a chance (no rush please ... you have larger fish to fry I'm sure) and let me know if all appears to be okay.
Regards
Neil
    Intel Core i7-920
    BenQ 24" E2420HD
    Western Digital
    1 x TB Sata
    1 x 320GB Sata
    Zalman 1000 Watt
Brink
Staff member
mvp
Neil,
CPU-Z is showing that you are using 800 MHz RAM, but it looks like the RAM in slots 2 and 4 are using EPP set at the 667 MHz setting instead of it's 800 MHz rating. I would look at the BIOS settings for them to adjust them to their 800 MHz settings (JEDEC#2) in CPU-Z.
    Lumia 1520 phone
Mr Smiley
I was just saying to 'Sharp' who also sent me some valuable advice on this matter and whose instructions I just followed ie:
I went into Setup and under 'Jumpfree Configuration' chose Manual and selected 800MHz for DRAM Frequency and Memory Voltage to 2.0.
Result? Unable to Boot. Screen read 'Overclocking or Over Voltage Failed'
I uninstalled the Asus Software called Ai Booster which only gave me the option to increase it to 711MHz.
Current Status: Everything in the Jumpfree Configuration settings is on Auto other than the DRAM Frequency which I've been able to increase to 711MHz and the CPU Frequency which says 266 and in a window next to this it says Valid Input Value 100 - 550.
I'm sure that will all make alot more sense to you and Sharp than it does to me.
Neil
    Intel Core i7-920
    BenQ 24" E2420HD
    Western Digital
    1 x TB Sata
    1 x 320GB Sata
    Zalman 1000 Watt
Mr Smiley
Hang on hold your horses ... I think we might of done it!!!
Under 'Jumpfree Configuration', instead of going to DRAM Frequency I went to Overclocking Options and it gave me the following options:
FSB960 / DDR2 800
FSB1200 / DDR2 800
FSB 1280 / DDR2 800
The first one booted up with a CPU speed of 2.16MHz, the second one booted up with a CPU speed of 2.70GHz, and the third option did not allow me to boot up at all.
Therefore, I have selected the second option and I hope this is what I was meant to do in order to have my 4 RAM sticks correctly setup.
Is it right now???!!!
Neil
    Intel Core i7-920
    BenQ 24" E2420HD
    Western Digital
    1 x TB Sata
    1 x 320GB Sata
    Zalman 1000 Watt
Brink
Staff member
mvp
Neil,
Is it showing the same CPU-Z settings in slot 1 screenshot above in for all 4 RAM sticks now?
The DRAM frequency should be 400 MHz with timings of 5-5-5-15 at 1.8 V for all 4 sticks.
    Lumia 1520 phone
Sharp
Does it allow you to do this,
(ignore the memory voltage in this screenshot)
[media]http://img.hexus.net/v2/motherboards/intel/asus/P5WDH/P5W-DH_Deluxe_BIOS_jumper_free-big.jpg[/media]
And at this section set the SPD option to enable
[media]http://img.hexus.net/v2/motherboards/intel/asus/P5WDH/P5W-DH_Deluxe_BIOS_chipset1-big.jpg[/media]
Dragor
Power User
I would suggest Mr Smiley to swap the sticks around. I would also urge you to carefully go through your printed motherboard manual. There are specific positions required for RAM sticks.Make sure you have followed them.
The screenshots shown by sharp are very much similar to what i find in my bios setup and if Mr Smiley looks at the first of them, he'll find his answer right there.
    Custom Built Gigabyte-Intel-ATI-Transcend-SONY combo
    Intel Core2 Duo E6300 1.86GHz
    Gigabyte G31M-ES2C [Intel G31]
    1.5 GB DDRII 667 MHz [512+1024]
    Sapphire ATI Radeon HD 4770 512 MB GDDR5
    Realtek HD Audio [ALC882 codec onboard]
    Samsung SyncMaster 2033SW+ (20" Wide)
    1600 x 900 x 60Hz @ 32bpp
    1 x 40 GB P-ATA
    1 x 160 GB S-ATA [Win7 with Win XP SP3 dual boot]
    1 x 1 TB S-ATA
    VIP 400 W
    Zebronics Elegance
    All fan [2 on case side and 1 behind]
    i-ball i-key Multimedia keyboard
    Logitech Standard Optical Tilt-Wheel Mouse
    256 kbps Cable
Mr Smiley
Hi Shawn & Sharp
I think I've figured it out now, but I would appreciate it if you could review my CPU-Z & Everest attachments when convenient for confirmation that my RAM configuration is now correct.
I went into Jumpfree Configuration and Disabled DRAM Frequency which allowed me to change the numbers from 5-4-4 /15 I think it was from memory (no pun intended) to 4-4-4 / 12 and it then allowed me to change the DRAM Frequency to DDR2 800 without having to go into Overclocking Options as I had done earlier.
I look forward to receiving your valued feedback at your convenience.
Many thanks once again for your support.
Neil
    Intel Core i7-920
    BenQ 24" E2420HD
    Western Digital
    1 x TB Sata
    1 x 320GB Sata
    Zalman 1000 Watt
Brink
Staff member
mvp
Neil,
It looks good to me. It does look like you have a slightly different type of memory in slots 2 and 4, but they are compatible with the others in slot 1 and 3.
Great job,
    Lumia 1520 phone
Sharp
You have done well :)
For the images you can use the insert image button when posting, then paste the address of the image.
Or use the image tags around the address.
EG,
PHP:
[img]http://www.vistax64.com/attachment.php?attachmentid=2905&d=1203587393[/img]
And it will look like this,
attachment.php
Mr Smiley
Thanks again for your help Shawn & EG!
Hey Sharp, thanks for the image tip, but I was also wondering how I can display images like you did on the first page of this post ... the setup screenshots where you click to enlarge.
How do I do that?
Neil
    Intel Core i7-920
    BenQ 24" E2420HD
    Western Digital
    1 x TB Sata
    1 x 320GB Sata
    Zalman 1000 Watt
Sharp
I just linked to it from the website using the img tags, not sure if it is the forum or Hexus have the feature on their image.
