Solved Intel GMA driver for mobile failed and doesn't recover
Bacterius
Hello,
I recently encountered an error with my Intel GMA driver for mobile, which is quite unusual. I believe that happened after a game crash (somehow my whole computer got really slow for a couple of minutes after I force-rebooted the computer - out of options).
But since, it seems the driver can't recover from this error, as I can see two things happening :
- if I attempt to access my GMA configuration panel, it fails to respond, and if I kill the actual "tray" process, it comes back up properly, except it doesn't have a proper configuration - for instance, the listboxes with "refresh rate" are empty, same for resolution, ... somehow the driver couldn't load the presets.
- if I attempt to access the Windows Display Configuration, it fails with a "The system has started with the standard VGA driver", but still brings up the configuration panel with the options all messed up (-1, -1 screen resolution, ...).
I've been doing some screenshots to show you what happens in order to solve it more easily, however I fear it might not be as useful because my OS is in french :o.
This is the failing driver configuration panel.
This is the failing Windows Display Configuration.
This is the configuration dialog box.
For some reason Windows tells me the driver is incompatible with my system (Vista x64), but it worked fine before. My diagnostic is that the driver is somewhat corrupted and incorrectly reports to the system that it can't run due to some incompatibility, so Vista starts the standard VGA display driver.
But I don't want that to happen. I tried to reboot, I downloaded the latest drivers but it didn't work, and the computer is having problems since then. I considered uninstalling the driver, doing some cleaning up, then reinstalling it, but I'm freaked out I should fail and the computer not be usable again. But if there is no issue, I'll have to do it though.
What do you think ? Has anyone ever encountered such a problem with his GMA (or possibly other) driver ?
stoneys-nutz
Gamerholic
Hello Bacterius,
I would re-install the video driver first, as this is most likely to be at fault.
Un-install the old driver first, then install the new one, reboot when prompted and see if there is any improvement.
Hope this helps, good luck and post your results.
    Self Build
    Asus P5Q Premium
    2 x ASUS EAH 4870 X 2 (Quad)
    Supreme FX 2
    150 Gig WD Raptor
    300 Gig Maxtor
    300 Gig Maxtor, (External)
    CoolerMaster 1000
    Logitech G5
    Logitech G15
    20Mbps
Bacterius
Hello,
sorry for being so long to reply,
I tried to reinstall the driver twice, on the first attempt it didn't change anything and on the second attempt Vista would actually crash after displaying the Orb (the nice & shining Vista logo).
Being computerless, I finally decided to revert to factory settings (Dell makes it pretty easy and quick, and the drivers are even included :cool:), and now it works just fine, if not better.
Thanks again for your help, this forum is very useful and I appreciate it.
stoneys-nutz
Gamerholic
Glad you got it fixed, good luck.
    Self Build
    Asus P5Q Premium
    Supreme FX 2
    150 Gig WD Raptor
    300 Gig Maxtor
    CoolerMaster 1000
    Logitech G5
    Logitech G15
    20Mbps
