internet not working....sorta
orb
running vista64 home, and i can't surf the web with firefox or explorer 32bit. i can however get new email messages, and surf the web using explorer 64bit. i can't get the newsgroups to work, and my online games, COD4 and rfactor, don't show any available servers in the online portion.
i dual boot w/xp and everything is ok in xp. i didn't change anything that i know of in vista for everything to stop working. i just came home yesterday and was having this problem. i ran the windows defender and avg, and neither reported any viruses.
also i can ping everything in cmd promp, but can't even log onto my router (wrt54gs).
everytime i use either explorer 32bit or firefox, the page doesn't even try to load-it just goes straight to "exploer cannot open this webpage". when i try to repair the network connection, vista says that there is no problem.
i tried putting in the repair disk, but it looks like i can only transfer files or install the os.
not sure what to do, other than a complete reinstall.
please help :D thanks, lawrence
64 bit works, but 32 bit does not??
Try this:
Start - in the search box type: CMD
In the dialog box that comes up type: netsh winsock reset
Then press the enter key to execute the command
Restart your computer
    Proudly Built by Me!
    Intel Q6600
    DFI UT LP P35 T2R
    8GB OCZ Reaper DDR2 800 C44GK 4-4-4-12 2T
    Sapphire Radeon 4870x2
    AuzenTech Prelude 7.1
    1 Acer P243 24" and 1 Samsung T260 26" Monitor/HDTV
    Both are running at 19x12
    Seagate 1TB 7200.11 (Vista x64)
    Seagate 500GB 7200.11 (Win 7 x64)
    OCZ GameXtream 900w
    FSB at 400 (1600) Mhz, CPU Multi @ 8 for 3.2Ghz
that did it!!!!! thanks a bunch Scott. what does that command actually do? and did i do something in my computer to cause this to happen? thanks again. lawrence
What that does is reset the communications (TCP/IP) stack.
Search The Knowledge Base
Just a user here, so it's hard to say off the top of my head what might have happened on your comp to cause it. I have a little notebook I write useful tidbits in, and I thought I saw your issue before. I did, and that was the solution I had written down... There's some MCSE types on the site here who could explain better.
Just glad it worked. :)
    Intel Q6600
    DFI UT LP P35 T2R
    OCZ GameXtream 900w
