Issues relating to build 6003
Machinerto
I am running Windows Vista x64 build 6002. When I try to install the platform update that's for server 2008, it just says either "This update is not applicable to your system." or "Some updates were not installed: [update id]". I have tried multiple things but I just can't get it to work. I want to update to build 6003 so I can use the Vista Extended Kernel.
    Windows Vista Ultimate x64
    Hewlett Packard/ HP Pavilion a6250z
    AMD Live! x64
    2 GB
    NVIDIA GeForce 8300 GS
    Creative Sound Blaster X-Fi Xtreme Audio
    HP 2011 Series Wide LCD Monitor
    1600x900 60hz
    Hitachi HDT725025VLA SCSI Disk
    Is not to factory settings; came with a clean install of vista when bought
    Dell Optiplex 7010
    Intel Core I7 3770
    Uses two firewalls (COMODO and Windows Firewall)
Vistaar
Another recent post of yours states, “The Vista PC has every official update installed.” It follows that Platform Update for Windows Vista is installed, and therefore Platform Update for Server 2008 would not be applicable to your system.
Here’s a recent thread at MSFN: extended kernel compatibility with server 2008 updates? (Part 2)
    Vista Home Premium x86 SP2
    HP Pavilion Elite m9150f
    Intel Q6600
    3 GB
    NVIDIA GeForce 8500 GT
Machinerto
Ok thank you. I should update the post that states that it's up to date. There are probably straggler updates that I omitted.
    AMD Live! x64
    2 GB
    1600x900 60hz
    Dell Optiplex 7010
    Intel Core I7 3770
Vistaar
I wouldn’t be concerned about the possibility that a few old security patches might be missing (it’s not like they would keep you secure in 2023), but you might want to search Installed Updates to see if you have all four Platform Update components from 2009 installed:
KB960362
KB971512 (Graphics, Imaging, and XPS)
KB971513
KB971514
Also the Platform Update Supplement from 2011 (which, along with KB971512, was included in the IE9 standalone installer):
KB2117917
(I think the “Server 2008” versions would have the same KB numbers and file sizes.)
    Intel Q6600
    3 GB
