Iwant to Buy a GPU Card Between £100 to £120 With VGA Port & DirectX 11.0 Pls Help
B
bally303
So i want to get a new Graphics Card So i can play Crysis 3 I have found a GPU that i like but dont know if it will work in my HP rig the GPU i want to buy is
Asus GeForce GTX 650 Ti Nvidia Graphics Card (1GB GDDR5, HDMI, VGA, 2x Dual-link DVI-D, PCI Express 3.0, OpenGL 4.3, GPU Tweak, DIGI+ VRM with Super Alloy Power Technology)my PC is HP Pavillion p6109uk
MY Motherboard is IPIEL-LA3 (Eureka3)
here is my PC specs Site:-
HP Pavilion p6100 Desktop PC series -  HP Pavilion p6109uk Desktop PC Product Specifications - c01792607 - HP Business Support Center
& here is my motherboard specs Site:-
Motherboard Specifications, IPIEL-LA3 (Eureka3) | HP® Support
so the GPU i want to buy says its PCI Express 3.0 & i only have PCI-E x16 i think its 1.0 not shore as i cant find it out anyware on the web, if you could pls let me know..
so can you help & tell me if this will work with my pc
PS
i have done a few mods with HP Pavillion p6109uk PC by placing it in a new mid-tower case & a new PSU has also been added corsair 650w PSU & a 2 month old GPU GEforce GT240 Has also Been added, nice card but its only DirectX 10.1 Compatable, Bit of a buzz kill if you ask me... as crysis 3 needs DirectX 11 to play..
Patonb
Re: Iwant to Buy a GPU Card Between £100 to £120 With VGA Port & DirectX 11.0 Pls Hel
That card will be just fine in your mobo, only possible issue is physically fitting in your case as you didn't mention what you switched too.
Your mobo is pci-e 2.0, which is perfectly compatible with pci-e 3.0.
The 240 came out before dx11 so what do you expect? It actually is a fairly old card.. Probably 3 yrs or more as it was "replaced" by the gt540.
    Dual L5639 // i7 950 @ 4.0Ghz
    gtx 560 ti // gtx 260-216
    Dual 22" // Headless
B
bally303
Thanks for Your reply, & to anwser your question my new case is Corsair 600t white, I really wasnt complaining about 240 card only about the newly released games, By the way, As i only paid £20 for it as a temp replacement for a faulty Geforce G210 card, i mean a 3 year old card & it plays almost all games except for all the Crysis games, i mean all the crysis games work but theres a lot of lag on it which makes it unplayable in my opinion I knew at the time of purchase it didnt have direct x 11, But now with most games demanding directx11 I thought its about time i invest in a better card as the 240 was only a temp card.
Also another Question? would the Radeon series cards work in my PC, Because i like this card it looks good & has great reviews its called
{ Radeon HD 7850 1 GB..} or am i bound to only Nvidia GPUs, Pls reply
townsbg
~~тσωηsвg~~
You will undoubtedly have to get a more powerful PSU. 300 watts isn't much. Keep in mind that the Crysis games are very resource intensive.
    Windows 7 Pro x64
    Mid 2010 iMac
    Quad core 3.2 Ghz Intel I3
    8 gb
    ATI Radeon HD 5670 512 mb ram
    1920x1080 and 1440x900
    1 TB
    N/A
    Windows 2008 R2 Enterprise
    Compaq Presario SR5350F
    Pentium 2.0 gHZ Dual core E2160
    2 gb
    1440 x 900
    300 GB
B
bally303
As I metioned in the first post i have a 650w corsair PSU
Patonb
Ah yha sorry I forgot you went with the 600T.
AMD cards are good, but they are notorious or having driver issues. The 7850 is a better card, but by 10fps-ish. The question to you becomes is the increase in cost worth the gains.
Both cards will do you just fine, its up to you if the £40-60 is worth it.
