Laptop will not sleep/standby!!
KitKat
I know some of u guys have had problems making ur computers go to sleep and i've tried most of the previous suggestions, but i still cant make my computer sleep.
When i click the sleep button, everything starts shutting off (screen, wifi...) but then my cd/dvd drive makes a noise, like it wants to eject a disk and everything comes back on. I have my sleep set to 30 min so basicly it this happens every half hour and it get really annoying unless i turn the computer completely off.
I've only had the computer for a couple of months and i dont think the drive made any noises before going to sleep then so i dont what could have caused this.
I hope someone can help!
    Dell Studio 15 Laptop
    Intel Core 2 Duo T8100 2.1 GHz
    3 GB
    256 MB ATI Mobility Radeon HD 3450
    15.4 WXGA w/ TrueLife
KitKat
So I narrowed it down and turns out that the S1 sleep is not enabled. But when i go into BIOS, power management...there is no option to change the sleep setting. There is only 'USB wake support'. uuugh :/
    3 GB
potosh
I had a problem with mine going to sleep and freezing up when I tried to get it up.
Spent 4 hrs with 3 diferent PH Techs before we got the problem corrected. Sorry I'm too much of a newbe to know what they did. For what it's worth I would go to
Control Panel\Hardware and Sound\Power Options - and re check your settings and
and look a little deeper by clicking some of the headings on the left side of window.
Also interesting that one of the tech's mentioned a possible issue with VISTA and sleep. I wish you luck.
Potosh
Brink
Staff member
mvp
    3 x 27" Asus VE278Q
    1920x1080
    1TB Samsung 970 EVO Plus M.2,
    250GB Samsung 960 EVO M.2,
    6TB WD Black WD6001FZWX
    Logitech MX Master
    Linksys EA9500 router,
    Arris SB8200 cable modem,
    Lumia 1520 phone
KitKat
Thanks for the link, unfortunatelly it didnt help. i tried everything but the last couple of things.
It seems like the cd/dvd drive is preventing the computer from going to sleep but i didnt see a wake up option for that device in the device manager.
I'm pretty sure that all the settings in the power options are okay. I checked those like a hundred times.
I also unchecked all the start up programs in system configurations and that still didnt help.
    3 GB
lordbob75
Lord of Bobs
Vista Pro
Try disabling the drive in Device Manager, and then try to sleep. If it doesn't work, then we know its not the drive.
~Lordbob
    ASUS P5QC
    2x2GB
    NVidia GeForce 9500GT 1Gb
    Mobo
    Samsung SyncMaster 206bw
    Samsung SP2514N ATA 250Gb 7200RPM
    Samsung [Model] 1Tb 7200RPM SATA2
    Razer Lachesis
    Razer Tarantula
    not fast enough
KitKat
~Lordbob
AAAHHHHHHHHH! Disabled it and still no sleep. :(
    3 GB
Extensa
Pusher of Buttons
Vista Pro
Do you have a wireless mouse?
If so, follow the pictures below:
Deselect the checked box.
Maybe this will help
Extensa
    Acer Extensa 5620-6396
    Intel Core 2 Duo 5750
    4GB DDR2
    ATI Radeon HD 2400 XT
    Laptop 15.4 LCD
    1280*768
    Logitech G11 Gaming Keyboars
lordbob75
Lord of Bobs
Vista Pro
Well, if disabling the Drive still had the problem, then its not the drive causing it....
~Lordbob
    ASUS P5QC
    2x2GB
    Mobo
    Razer Lachesis
    Razer Tarantula
    not fast enough
KitKat
quick question....
does this happen when its on battery, plugged in or both?
okay, i'll try to make this as least confusing as possible...
the sleep doesnt at all when its plugged in. when its running on battery, its a whole different story. it will only sleep when i let the time take its course and after that i can do it manually too. or atleast it let me a couple of times.
PS: the keyboard doesnt wake up the computer. :/
    3 GB
KitKat
I'm using a wacom tablet and i've been leaving the mouse and pen off the pad. Also, when i went into the device manager, there is no power management tab in either the mouse or keyboard devices.
    3 GB
