Solved Lost Admin Privilege! Please Help Me!
eldron
Hi!
Sorry if this is not a right place to post.
I got my laptop from my school, and it's Windows Vista Business.
After 4 months using my laptop and using internet explorer, IE started to mess up! Everytime i opened my homepage: Google, it will redirect to a dating site. And every sort of pop ups appeared... the pop up blocker were turned on, homepage was set to google.co.uk, security setting was at the highest, blocked all cookies, and all sort of things i did. Also, it makes my startup , and performance become 6X time slower than usual.
After doing some searching on google, i found this tutorial site, there's a tutorial that exactly i have, it says that my User Account/profile is infected or something, it says to delete the account that's infected. I backed up all my files, and created a new admin account, and deleted that "infected" account.
It really worked, IE was fine, performance and such. But that was just temporarily, after 2 days, All the pop ups and stuff come back. So, i deleted the admin account i'am using, BUT I FORGOT TO MAKE ANOTHER ADMIN ACCOUNT!!
And i'am still using a guest account. I can't install, create a user account, use windows update, and all the admin Privileges.
There is one Administrator account, but i don't know the password. Oh the laptops is Toshiba, and i think the admin account is created by toshiba.
Is there another way of retrieving, or whatever method to be an admin for my laptop again WITHOUT reinstalling my Windows Vista.
Why do Vista have a high security!
Thank you.
    Toshiba Satellite Pro A200
Bare Foot Kid
R.I.P. August 13th 2014
    * BFK Customs *
    Intel C2Q 9550 Yorkfield
    ASUS P5Q Pro
    8GB Dominator 8500C5D
    XFX ATI 1GB 4870 XXX
    Realtek HD 7-1
    1920x1080P & 1920x1200
    Corsair 620HX
    CM Cosmos RC-1000
    Razer Diamondback 3G
    HP Enhansed Multimedia
    18.6Mb/s
    My First Build ;)
eldron
But, all those requires me to be on Admin Account... exept boot from DVD, and i prefer not to use that option.
And i only want to access admin account, so i can update my laptop and stuff.
Brink
Staff member
mvp
Hi Eldron,
Since you do not remember the password, your options are very limited. Using the boot DVD from Method Three in that reset link is the only easy option other than doing a clean reinstall of Vista. Anything else would involve having to take it to a professional and lots of money. :(
Sorry,
    3 x 27" Asus VE278Q
    1920x1080
    1TB Samsung 970 EVO Plus M.2,
    250GB Samsung 960 EVO M.2,
    6TB WD Black WD6001FZWX
    Logitech MX Master
    Linksys EA9500 router,
    Arris SB8200 cable modem,
    Lumia 1520 phone
eldron
Ohh.... :( oh well, i don't want to boot from DVD. Oh well, guess i'll stick to the Guest Account,
Thank you.
johngalt
Antidisestablishmentarianist
Kinda curious - how can you delete the account you are logged into? I could ahve sworn all those other tutorials ask you to make a new profile, *log out and log into the other profile* and then delete the old profile....
    The Beast Model V (homebrew)
    Realtek HD Audio (onboard)
    2 * 1920 x 1080
    Logitech MX Master (shared)
    Logitech G15 (gen 2)
    Lenovo ThinkPad E545
    AMD A6-5350M APU
    Lenovo
    Radeon HD (Embedded)
    Conextant 20671 SmartAudio HD
    Lenovo 15" Matte
    1680 * 1050
    Lenovo
    Lenovo
    Lenovo
    Lenovo
Brink
Staff member
mvp
    3 x 27" Asus VE278Q
    1920x1080
    Logitech MX Master
    Lumia 1520 phone
eldron
Lol and that what makes me wondering about it.. i really deleted it while using that admin acccount...
@Brink, I didn't backed up the password to a USB or CD...
Brink
Staff member
mvp
Eldron,
Method Three shows you how to create a boot DVD with a editor tool that clears the password at boot. It is not the one from Method Two that you had to create (backup) at a earlier point. Method Three (Editor Tool) should do what you are wanting so you can gain access to your administrator account. Sorry for any confusion about this.
http://www.vistax64.com/tutorials/102005-reset-user-account-password.html
Hope this helps :geek:
    3 x 27" Asus VE278Q
    1920x1080
    Logitech MX Master
    Lumia 1520 phone
acadamis2000
IT Consultant
Vista Pro
Sounds like you have a tid bit of spyware on the laptop as it is by the home page redirecting you. I would just start over from scratch with a reload, that way you can get the full experience of installing Vista. Don't forget about some Anti-Spyware or Anti-Virus programs too, sounds like that could be an issue.
    Intel Core 2 Duo e8400
    EVGA 680i SLI
    4GB Buffalo Firestix
    EVGA 8800 GT - 2x XFX 8600gt
    Seagate 300gb 7200 rpm
eldron
I don't think it's a spyware...
First, IE becoming really slow, so i decided to reset it... that's when all the pop ups and redirecting happened.
Bare Foot Kid
Hello again eldron.
What are the anti-virus and anti-spyware programs that you are using?
Also what firewall are you using?
Later :shock: Ted
    * BFK Customs *
    ASUS P5Q Pro
    Realtek HD 7-1
    Corsair 620HX
    CM Cosmos RC-1000
    18.6Mb/s
    My First Build ;)
Bare Foot Kid
    * BFK Customs *
    ASUS P5Q Pro
    Realtek HD 7-1
    Corsair 620HX
    CM Cosmos RC-1000
    18.6Mb/s
    My First Build ;)
eldron
Wow cool...
I'll try the Comodo Antivirus and Avast ... But, how do i uninstall the built-in firewall?
EDIT,Comodo: It's 30 days free trial :(
Bare Foot Kid
Wow cool...
You just have to go in "Control Panel", "Security Center" and disable W. F/W
before you install Comodo, no it's not a thirty day trial. That's the paid version.
Later :shock: Ted
    * BFK Customs *
    ASUS P5Q Pro
    Realtek HD 7-1
    Corsair 620HX
    CM Cosmos RC-1000
    18.6Mb/s
    My First Build ;)
Bare Foot Kid
    * BFK Customs *
    ASUS P5Q Pro
    Realtek HD 7-1
    Corsair 620HX
    CM Cosmos RC-1000
    18.6Mb/s
    My First Build ;)
eldron
Wow cool thanks.. :D
Oh and i have 1 more question, why is it sometime Vista stopped working? Like Windows is not responding and then it restart the windows...
Oh and is this software safe to use many times? explorestart .From Nirsfot.
I used it when Windows not responding.
