Solved MUlti BSODS bad pool caller and reference by pointer
14
Location
canada
So recently, pritty sure after I installed divx and a psp manager, I started getting bsods, I ran ram tests defrag men diagnostics tools and still I randomly get them.
Info. Vista 64 bit servicepack 2.
Aside from this, I have no IDea what the causes could be, I will post pics of the error- if any. Othe info is needed please tell me and I will respond asap . I will post more info shortly as I am on my phone
    amd anthon dual core processor 3800
    m4a785-m asus
    kingston 2gb x2
    nvidea Gts 450
    Vga/ Dvi/hdmi 2 despays one hdmi tv
    250gb main, 500gb slave, 500 gb external,seagate 500 gb external seagate/vilosity
    vilocity
    fans,4
    logitech G5 gamer
    logitech gamer g11
    100 mb fiber optic, (cannot utilize full speeds
Yard Dog
2,169
Location
Central Florida in a small town
    Emachine ET 1161-05
    AMD Athlon 64 LE-1640
    1280x768 pixels
    ST316081 5AS SCSI Disk Device
    Tower
    Fan Speed 1247 RPM
    PS/2 Compatible Mouse
14
Location
canada
before i do that, do i just have to run that? and quick question, will a formatt/reformatt solve the problen?
    m4a785-m asus
    kingston 2gb x2
    nvidea Gts 450
    vilocity
    fans,4
    logitech G5 gamer
    logitech gamer g11
Yard Dog
2,169
Location
Yeah, just run the program to get the logs, and the logs will help solve the issue, a reformat would in fact work , unless if the issue is hardware. That is reason for the logs. They will help figure out what the issue causing your BSOD'
s.
    Emachine ET 1161-05
    1280x768 pixels
    Tower
    Fan Speed 1247 RPM
richc46
Staff member
20,105
Location
Fairfield County, CT
90 percent of the time its a driver, memory or other software. Do not be quick to reformat, may not be necessary. Even if format will help, if it is software, there are usually much easier ways to solve the problem.
14
Location
canada
i havnt installed any new hardware, except i got a second HD enclosure, for backups mainly
and i got a power supply i have yet to install,,, there is alot of dust in my system, specally the processor.
other info before i post logs,
full retail verson, i installed it about a year ago, never really had any major problems till now
my system is almost 4 years old, having said that ive replaced every component except the case and processor/heatsync- which i want to do ASAP
hardware m4a785-m asus motherboard
amd anthon x2 dual core 3800
vista home premium sp 2
4gb ram kingston
geforce Gts 450
currently im preforming the logs you told me to do- i just got a burst of like 5 bluescreens or so,,, i have a feeling my processors overheating,,,
cottonball of dust under the fan and i just ran outta air a month ago
    m4a785-m asus
    kingston 2gb x2
    nvidea Gts 450
    vilocity
    fans,4
    logitech G5 gamer
    logitech gamer g11
14
Location
canada
um,,, how do i attach the file??
    m4a785-m asus
    kingston 2gb x2
    nvidea Gts 450
    vilocity
    fans,4
    logitech G5 gamer
    logitech gamer g11
richc46
Staff member
20,105
Location
#8
14
Location
canada
#9
i did not know the GO ADVANCED button ment that,,,, anyway here is the report and other thing you needed,, i hope i did it right
    m4a785-m asus
    kingston 2gb x2
    nvidea Gts 450
    vilocity
    fans,4
    logitech G5 gamer
    logitech gamer g11
14
Location
canada
#10
it says i dont have antivirus, i was just running it though when the bluescreen came.
missing event log, i cleared up some free space and did a cleanup
and for some odd reason i cannot access the command prompt
im using microsoft security essentials, but i have windows defender off because i play live on xbox
    m4a785-m asus
    kingston 2gb x2
    nvidea Gts 450
    vilocity
    fans,4
    logitech G5 gamer
    logitech gamer g11
14
Location
canada
#11
also,, thankyou for your amazingly fast responses. is there anything you would like me to add?
    m4a785-m asus
    kingston 2gb x2
    nvidea Gts 450
    vilocity
    fans,4
    logitech G5 gamer
    logitech gamer g11
richc46
Staff member
20,105
Location
#12
If you post the BSOD reports, that is all we need to start. When you post, additional questions/information may be required.
14
Location
canada
#13
i did post them
    m4a785-m asus
    kingston 2gb x2
    nvidea Gts 450
    vilocity
    fans,4
    logitech G5 gamer
    logitech gamer g11
richc46
Staff member
20,105
Location
#14
The reports that I requested do not usually give definitive answers, but rather clues. Yours seems to indicate a driver. Use the driver verifier and submit all the new BSODs reports that you receive, while using the verifier.
I'd suggest that you firstbackup your data and then make sure you've got access to another computer soyou can contact us if problems arise. Then make a System Restore point (so youcan restore the system using the Vista/Windows 7 Startup Repair feature).
In Windows 7 you can make a Startup Repair disk by going to Start....AllPrograms...Maintenance...Create a System Repair Disc - with Windows Vistayou'll have to use your installation disk or the "Repair your computer"option at the top of the Safe Mode menu .
Then, here's the procedure:
- Go to Start and type in "verifier" (without the quotes) and press Enter
- Select "Create custom settings (for code developers)" and click"Next"
- Select "Select individual settings from a full list" and click"Next"
- Select everything EXCEPT FOR "Low Resource Simulation" and click"Next"
- Select "Select driver names from a list" and click "Next"
Then select all drivers NOT provided by Microsoft and click "Next"
- Select "Finish" on the next page.
Reboot the system and wait for it to crash to the Blue Screen. Continue to useyour system normally, and if you know what causes the crash, do thatrepeatedly. The objective here is to get the system to crash because
Driver Verifier isstressing the drivers out. If it doesn't crash for you, then let it run for atleast 36 hours of continuous operation (an estimate on my part).
If you can't get into Windows because it crashes too soon, try it in Safe Mode.
If you can't get into Safe Mode, try using System Restore from yourinstallation DVD to set the system back to the previous restore point that youcreated.
DriverVerifier - Enable and Disable
14
Location
canada
#15
so if i understand correctly you want me to back up my data, do a system repair and then
run the verifier? as for contacting you i can use my iphone, atlest for most of it,
i can usually run my computer for some time before it crashes too, so hopefully my pc wont crash till tomorrow... heh.
    m4a785-m asus
    kingston 2gb x2
    nvidea Gts 450
    vilocity
    fans,4
    logitech G5 gamer
    logitech gamer g11
richc46
Staff member
20,105
Location
#16
That is correct. What the verifier does is to put stress on the drivers and causes the weak ones to cause a BSODs. When you do BSOD, we will see which driver was the cause and then update it, good luck.
14
Location
canada
#17
Alright here's the deal, I blew out my system namly processor for dust, and I havnt had a blue screen since! But I'm taking ur advice still because I got so many. The system repair detected no problems and I'm currently running the verifier. Is it likely dust caused the problem, and thus caused other driver problems? ( my processor was CAKED with dust. Another question- my pc freezes whenever i try to use my webcam after hibernation, any ideas?
    m4a785-m asus
    kingston 2gb x2
    nvidea Gts 450
    vilocity
    fans,4
    logitech G5 gamer
    logitech gamer g11
richc46
Staff member
20,105
Location
#18
Dust prevents the fan from doing its job, bad fan = overheating. Overheating does cause BSODs
14
Location
canada
#19
gotcha. thankyou for all your help. my pc hasnt crahed for about 3 days and ive ran the verifier for 10 hours so far. still though any idea why my command prompt wont work? also i found a suspitious program through the driver tester, spvj.sys
these are completly different problems. so should i perhaps make a new post?
    m4a785-m asus
    kingston 2gb x2
    nvidea Gts 450
    vilocity
    fans,4
    logitech G5 gamer
    logitech gamer g11
