My laptop freezes whenever it overheats/idles for a while
Flamzeron
I've got a problem with my laptop. Whevener it idles for a while, the whole thing just freezes. I've noticed that my laptop gets pretty warm around the same time, so I assume that the two are connected. I'm having to take the battery out of my laptop just to restart it. This didn't start happening until I got an update from Norton. Is there anything I can do to fix this? Thanks in advanced.
brummyfan
Brummy
Try another AV program after uninstalling Norton, see any difference in Temps. Use HWMonitor or any temperature monitoring utility to keep an eye on the temps. How old is your laptop? if it's more than a year old might as well check the fans for any dust and blow them out with a can of compressed air.
It helps if you fill up your system specs.
    Biostar
    Biostar MCP6P-M2
    NVIDIA GeForce 8400GS
    CIBOX
    Hitachi 160GB
brummyfan
Brummy
Yes, you have to open the back cover to inspect the fan, it all depends on what model,how old and how you use it(do you use the laptop in bed).
You can also try blowing compressed air in to the vents from outside without taking off the back cover.
This is only an example and there are many guides in Youtube:
YouTube - Laptop cleaning with compressed air
    Biostar
    Biostar MCP6P-M2
    CIBOX
    Hitachi 160GB
Blueblaz
Be careful when using compressed air to clean out your computer, the U-tube shows that you use very little air to blow it out. If you use full pressure you could over spin the fan and seize it. When I do mine, I always use a small pin (paperclip) to hold the fan in place.
    Home Built system
    3.20 gigahertz AMD Phenom II X4 955
    ASUSTeK Computer INC. M4A79T Deluxe
    4094 Megabytes
    NVIDIA GeForce GTX 280
    ASUS VW193T and ASUS VW246
    500 Gigabytes Hard Drive Seagate ST3500418AS
    1000 watt Can't remember what it is XFX I think
    Cooler Master 926 HAF
    Air, 4 case fans
    Logitech G5 lazer
    Merc Stealth
    Broadband, comcast. Decent
    Soon to build a new system.
richc46
Thank you for the astute advice. To be honest, I did not even think of that.
richc46
Glad that it worked out the way you wanted.
